Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-14-2010, 02:14 AM   #21 (permalink)
My Trex 550 is not built yet, but hearing about all these OWB lockups is BS in my opinion. I can't believe Align made such a bad quality bearing. The only other heli I had a OWB lockup problem was, was my Synergy N5. It locked up a few times, so I took it out and oiled it very generously, and it never did it again.
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!
XL 700 Specter V2. Xera 500kv motor, Tesla cyclic servos, Tesla tail, HW 200amp ESC, Ikon 2 FBL. XL Protos 380, Torq servos, HW esc, Egodrift motor, Ikon 2
Blades345 is offline        Reply With Quote Quick reply to this message
Old 10-14-2010, 03:01 AM   #22 (permalink)
I always start in idle1 and then fly. Nice soft start with the Jive. Not had a huge amount of flight yet with this heli either and mainly fly big sky stuff with a lot of inverted thrown in, no serious 3D, so I think this bearing sucks. Got some Boccas on the way.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote Quick reply to this message
Old 10-14-2010, 05:47 AM   #23 (permalink)
I also start in Idle 2 and fly the entire flight...when im done hit TH and cross my fingers that the main stops before the auto gear. Yes you can free the auto from main gear on the ground but it doesnt make a difference as soon as you spin the head up it locks again.
Chris_M is offline        Reply With Quote Quick reply to this message
Old 01-31-2011, 09:20 AM   #24 (permalink)
Just to update, I removed the original OWB and cleaned it very well. I then re-greased it with the Align grease and so far so good, problem solved.
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 01-31-2011, 10:02 AM   #25 (permalink)
Same experience here. If there is inadequate grease, it'll lock up. I actually went ahead and purchased the new KDE one way and replaced the Align stock. It was BRUTAL to press out the old OWB, and put the new one in. I didn't apply any grease, and it locked up the first flight! Of course I was doing an auto, but the 550 autos fine even with the motor turning. I then applied some lithium white grease and 10 more flights without a lock-up.
So in my experience, it just comes down to keeping the OWB properly lubricated. Even a very high quality OWB from KDE locks up if not greased properly.
I just ordered some tri-flow clear synthetic grease. Hopefully this will last a bit longer then the Align formula.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 01-31-2011, 05:07 PM   #26 (permalink)
I also had the Align OWB lockup on me and decided to go replace it with the KDE bearing. As far as getting the old one out I have a simple solution. Take a large C clamp and two apropriate sized sockets (for a socket wrench). One should have a size slightly smaller than the bearing, and one larger than the bearing on the inside. Then use the C clamp to press the two together, pressing the bearing out of the metal hub. To replace with the new one just press it in with the clamp from one side. I also used a vice to hold the clamp and help with the process. Then I lubed up the new bearing very very well with Align grease and it has been perfect for quite a while now.
jpinn is offline        Reply With Quote Quick reply to this message
Old 01-31-2011, 07:20 PM   #27 (permalink)
I dont have the heli. But I am guessing the bearing is pressed in aluminum. If thats the case. Then you should be albe to remove it easily like you do bearings in a nitro motor. Put the assembly. Providing it doesnt have any peices that will melt on it. In the oven set at 425 degrees f for about 15 minutes then just tap it out with a wood dowel. That should do the trick. put your new bearing back in it before it cools off. Hope this helps.
Martinshelis is offline        Reply With Quote Quick reply to this message
Old 01-31-2011, 08:00 PM   #28 (permalink)
My align OWB assembly was well greased with the align grease at assembly as per the instruction manual. No problems so far.
Crash549 is offline        Reply With Quote Quick reply to this message
Old 02-01-2011, 07:29 AM   #29 (permalink)
I have played the Align OWB game for close to 200 flights now. I have used about every type of grease and oil known to man. I replaced bearings, bearing shafts, hubs and main shaft, still in three or four flights the OWB will lockup.
After a hammering flight the OWB would lockup so bad I would not be able to brake it loose. When this happens It is a fight to remove the main shaft. I have even broken a gear once tiring to remove the main shaft before.
One day at the flight field I swapped complete main gear assembly from a 600ESP that had never had a OWB problem. With my assembly in his 600 there was not a problem, his assembly in the 550 locked up on the first flight.
Last week I installed the Boca OWB...after 16 flights no lockup...yet!
halfcab is online now        Reply With Quote Quick reply to this message
Old 02-01-2011, 09:26 AM   #30 (permalink)
I wonder what it is with the 550 that causes this? Maybe the high head speed compared to a 600 for which it was designed?
Old 02-01-2011, 09:34 AM   #31 (permalink)
Oh this happens on the 600e a lot also, though maybe not as much as the 550e. Some blame the flexy frame on the 550e, others blame the main shaft ... there seems to be no real answer from what I have read, only random solutions.
- Chris
Old 02-01-2011, 09:38 AM   #32 (permalink)
Maximum rpms for these kind of bearings is in the 10000 - 15000rpm range.. we arent getting those rpms.
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote Quick reply to this message
Old 02-01-2011, 10:49 AM   #33 (permalink)
I'm sure that in most cases locking is happening because of to less play between the main shaft an the upper bearing holder.
had the same issue and replaced the original owb by a second one without getting the prob solved. tried relube both with different lubs/oils but without getting it working properly.
INA owb's are of very good qualtity so i tried changing the 0.5mm spacer against the 0.3mm and the problem was solved!
T-Rex 450 PRO C3X-100 YGE-40, HK II 2221-8
T-Rex 550E BEASTX CC Phoenix Ice 100
T-Rex 600 PRO VBAR 5.2 ROXXY 9120-12
PitchFella is offline        Reply With Quote Quick reply to this message
Old 02-01-2011, 01:18 PM   #34 (permalink)
Are you guys cleaning out the OWB with alcohol letting it dry ,then pushing in the align grease with your fingers?
rcuser is offline        Reply With Quote Quick reply to this message
Old 02-01-2011, 02:14 PM   #35 (permalink)
In the progress of making an own hub. just fits. but, it can house a 12x32x10 SPRAGUE!! owb together with a 12x18x4 to keep things lined up.
Going to lave it next week. will try. if it does work, NO more lockups! EVER!
Look at the hole for the bearing! HUGE!
Bottom(radial) bearing space:
Old 02-01-2011, 02:42 PM   #36 (permalink)
I must be one of the lucky ones. About 50 flights and no one single lock -up. I just assembled the heli lubed the bearing with the lube included in the kit, checked everything is lining up correctly, made sure that all is smooth and tight but not too tight, just right and I have no issues with OWB, none. Reading all these threads I just think that I am either extremely lucky or you guys are doing something wrong. No offence intended but if two people are using the same tool and one needs to constantly replace it due to malfunction and the other one is using it day after day for months or even years without any issues there is usually a reason for it. If you guys are experiencing this issue on a almost daily basis there must be a good reason for it and the cause needs to be addressed before you start changing the bearings. That is just my 2 cents advice.
mmarian is offline        Reply With Quote Quick reply to this message
Old 02-01-2011, 02:51 PM   #37 (permalink)
I have the most simple reason. in extreme 3d, the bearing gets abused.. count a 12s setup into the mix, and it will lock up easily.
Old 02-01-2011, 03:44 PM   #38 (permalink)
If you overtighten the maingear bolt it will warp the one way bearing shaft. I would replace both parts if I were having problems. Also if the one way bearing shaft gets "grooved" or "galled" from the bearing it will cause lockups.
Old 02-01-2011, 05:18 PM   #39 (permalink)
Well, there you have it......Simple explanation and in your case,no doubt, you know what you need to do to address it. Good luck !!
Old 02-01-2011, 06:48 PM   #40 (permalink)
I have 30 flights on my 550 with no issues as of yet. But I was just curious if anyone has looked into upgrading your stock main shaft bearing block with KDE's Direct Thrust Bearing block. From their quote: "With the addition of the thrust-bearings to support all axial loads, more power will be available for hard pitch-pumps, 3D maneuvers, and auto-rotations; as well as protecting the integrity of the radial bearings". I'm sure this may also help the OWB especially for those doing hard 3d.
Luis
Luisito is offline        Reply With Quote Quick reply to this message
