Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 11-11-2015, 01:26 PM   #1 (permalink)
Default Main shaft play on my Whiplash Gasser
I have some up & down play in my main shaft on my Whiplash gasser. I don't remember when building it using any shims. Should i be concerned with this play. I pulled it apart & can't really find any cause of the play. I've had it since they were released & never been crashed.
ttaylor is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 02:16 PM   #2 (permalink)
the lowest bearing block on the whiplash can be adjusted up and down for removing any play, by design. Check that.. that bearing block is usually tightened after install of the main gear jesus bolt, and pulling the screws / block up, and tightening..
hope that made sense.. There should be NO play
if there is still play, check the lower jesus bolt on the main shaft.
Goblin Gasser TRM VX310TT Align MJ Design DTS 700N 91 HZ-R 3D Blackout Extreme Gasser #4 MCPX BL 2 iX12
Gaba
Rahulgaba is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 02:44 PM   #3 (permalink)
Ok will adjust the lower bearing block. Thanx.
Old 11-11-2015, 07:59 PM   #4 (permalink)
Adjusted the lower block & no play now... Thanx again..
Old 11-11-2015, 08:15 PM   #5 (permalink)
check the top and bottom of the main drive hub
the newer versions had a steel sleeve in them. The older versions did not
on the older versions the ends would deform into the bearings which created vertical slop
as noted, adjusting the lower block is how to address it but if its deforming you'll probably see the slop come back over time.
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 11:26 PM   #6 (permalink)
Default If it's the old design hub
You can add the steel washer between the hub and the bearing to prevent wear in the future. Glue the washer with goop to the hub using a spare mainshaft as a guide. Once dry then you can easily install it in the model.
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 11-12-2015, 12:25 PM   #7 (permalink)
Now that i think about it more. The slop came from when i changed out the one way bearing to the GMN bearing awhile back. I had to almost split the frames to get the clutch bell out & probably loosened up the lower bearing block.. I never had any play before i changed out the 1 way..
Old 11-12-2015, 01:05 PM   #8 (permalink)
do order the correct lubricating oil from Miniature for that GMN bearing.. as after around 50 flights.. this one will give up too.. there is just not enough lubrication in the bell for the OWB causes excessive wear and failure.. Mine failed and so did other few members.
Gaba
Old 11-12-2015, 08:30 PM   #9 (permalink)
Default I'm batting over 100 with mine
But I got a new bearing and that special oil on the way also. I'm using this one until it lets go and then will replace with the new one and use that new oil with it.
-=>Raja.
Old 11-13-2015, 09:15 AM   #10 (permalink)
Mine failed at 60. Raja went to 103 on his first and is getting close to 100 on his second I think???
I just got and installed the new one from Josef with the special oil. the oil is supposedly similar to ATF but its definitely a heavier viscosity than the thin redline ATF I was using before... Not quite 10w30 thick but similar to air tool oil id guess.
One other difference is that the bearing from Josef feels a lot tighter than the 422m I got from Rhodes. I dont know yet if there is a reason for that. I hope to fly it today.
As far as failure... I inspected mine after it failed, it wasn't sprag wear, a few of the tiny tension springs that hold them in broke away. Now maybe the oil will mean a softer engagement and put less stress on those springs?? I dont know... I'm just not convinced yet a different oil will solve it.
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | G500 Raw | Trex 450 Sport FBL | OMP M1
Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery
jharkin is offline        Reply With Quote Quick reply to this message
Old 11-13-2015, 03:29 PM   #11 (permalink)
Yeah it might not solve but elongate life for now till the new design is released
Gaba
Old 11-13-2015, 06:06 PM   #12 (permalink)
Default Yeah
The 2nd one is at 87 now and I got another on the way from Josef. Will keep this one in there until "EOL" or end of life and then put in the new one.
-=>Raja.
