KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum |
09-14-2009, 08:36 PM | #21 (permalink) |
Gear mesh was perfect. It strips down to the bottom of the gear. As well on some of my other gear, I striped like 10 gears. The most i got was 10 flights out of one. I would like to see a Delrin cnc 600 gear. perfectly round, and strong. The shaft doesn't stick out of the top of the pinion, so how would i put a counter bearing? Well one i got my Delrin 700 gear, i never had any issues again. Too bad that Microheli is no longer making them. Since it really didn't sell to good for the 700. I think it would be wise for a company to make one for the 600. I would love to see a company step-up and make one. I sure people would buy it. I know i would.
09-15-2009, 12:35 PM | #22 (permalink) | |
Duke
T-REX 600ESP, 12S, SCORPION 4025-630, JIVE 80HV, JR8717, BEAST-X, EDGE FBL LE-603, LE - 95, OUTRAGE LIPO. T-REX450 PRO, 6s. T-REX250, HK2206 - 3900. SCORPION 25A ESC V2, OUTRAGE LIPO. |
09-15-2009, 12:59 PM | #23 (permalink) |
I would like to see someone come up with a way to fit a Mikado herringbone main gear to a T600 drive. I heard one, barely, last weekend and from talking to the owner, it has the benefits of helical drive but without the axial loading on the motor.
09-23-2009, 11:06 AM | #24 (permalink) |
Just got my KDE Maingear mod installed this week had a few flights on it so far. I really love it. The bigger 700 gear will for sure help from stripping i beleive. Much taller and better mesh with my Mikado pinion on my Scorp 4025-1100.
Keep the good stuff coming KDE. Next purchase will be a 700 E kit from you guys! -Justin |
09-23-2009, 02:31 PM | #25 (permalink) |
Hi
my esp broken bacause kde direct not work good.
Pilot Peter Martin My Galery: www.rcpilot.hu |
09-24-2009, 07:35 AM | #26 (permalink) |
There is a short "shaft" in the kit, the instruction is to cut the motorshaft so it fits with the short in the middle of the pinion. But on a 600 you will need a 5 mm spacer between the motor mount and the counterbearing, with that the Mikado measurements need to be revised. With my Neu 1910 I just turned the short shaft around and had perfect fit with no cutting.
Trex 450 Pro Stretch Neu Scorp 1630, 8s, CC30HV. Mini V Trex 700 DFC V-bar |
01-24-2010, 05:04 PM | #27 (permalink) |
Is a stock 700 gear Mod 1 or something else? Thanks
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G |
01-25-2010, 08:56 AM | #28 (permalink) |
Stock 700 is Mod 0.7
01-25-2010, 09:19 AM | #29 (permalink) |
Thank you
01-26-2010, 10:11 AM | #30 (permalink) |
Hey Martin,
Sorry about the late reply on this thread, I didn't see it in my User CP. Can you please explain why the KDE Direct upgrade caused your ESP to break? The Main Gear Case upgrade has been a great success for many pilots pushing high-voltage, high-power setups on their 600E, so what occurred for you that you are unsatisfied?
-- KDE Direct, Inc. -- |
01-29-2010, 11:13 PM | #31 (permalink) | |
Oneway roller lubrication
I read your thougths on one-way grease. I am somewhat familiar with Mobilith SHC100 from my non-heli work as well. I am a reliability engineer at Dow Chemical Company, in which I work with specifying lubricants ocassionally to solve problems, or maintain the equipment as specified by the OEM's. Anyway, I can appreciate that a synthetic hydrocarbon grease would have sustained lubricant performance since the oil in the suspension won't degrade like others, but what about the suspension? I see Mobilith SHC100 is a lithium complex. I have been using Triflow Synthetic grease in my one-ways since a year ago or so. Not nearly as much experience as you in either heli or professional regards. From your experience, is there a reason SHC100 might outperform Triflow for this application? In some regards, we need the lubricant for the rolling elements, but we also need traction when driving. As I think of it, I almost think the PTFE in Triflow's suspension complex might allow a oneway assembly to slip when it should grab...Any additional thoughts?
Thanks! Quote:
= Rb43 = |
02-05-2010, 11:47 PM | #32 (permalink) |
For Sale New KDE Direct Main Gear Case 700 gear
Bought for use with 600 Nitro, only for electric, Paid over $20.00 , PP/Shipped $15.00 never mounted.
joemackconst@yahoo.com |
02-06-2010, 02:51 PM | #33 (permalink) | |
im doing this 12s conversion and i purchased th e kde hub and the kde bearing support. The bearing support doesnt look like it will come close in fitting on my 600esp. Is there any way around this of maybe the 600 doesnt really need the support. thanks
GOBLIN 700 SPEED-KOSMIK200-700XF-NEO-BK CYCLIC AND TAIL TREX 700E-NEU KDE 1917-12 PINION-NEO -JR 8717 HV CYCLIC-MKS990 TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT |
06-20-2010, 03:14 AM | #34 (permalink) |
well i just fitted the kde hub to my 12s 600e fitted a new oneway had three flights and its locked solid took main gear out and replaced with the original main gear and the birds good as new, tried to push the sleeve that the mainshaft goes into out of the kde hub and it wont budge! do i chuck it in the bin or has anyone found a solution to this?
trex 600 12s! 451, 760+251. trex450v2. 700 nitro, 760+251, 610,620,91h,hatori938,kasama header, 700 le gp750+650, 610,620,91h align pipe.12fg |
06-30-2010, 12:19 AM | #36 (permalink) |
KDE upgrades
I have install the KDE Thrusted metal bearing blocks, T700N main gear case, main drive gear, 115T, MOD1.0, and a Revco MOD1.0 Hardened steel pinion 12 tooth. Also have add a 2mm frame and a 3rd bearing block, 2 additional frame mounting bolts, one between the canopy mounts and on just behind the batteries. Very nice fit and works great thanks saitoking
[ame]http://www.youtube.com/watch?v=ykznCNQTqbo[/ame]
Align Trex 450 SE V2 w/ Super Frame Align Trex 500 CF Align Trex 600 ESP Quark Align Trex 710 Stretch 3G 4035 630 CC80HV 10s Last edited by cklking; 08-10-2010 at 07:50 PM.. |
08-09-2010, 07:29 PM | #37 (permalink) |
Whar size pinion, headspeed ? Thanks
08-10-2010, 07:48 PM | #38 (permalink) |
I am using a 12 now and the hs is 2032
Align Trex 450 SE V2 w/ Super Frame Align Trex 500 CF Align Trex 600 ESP Quark Align Trex 710 Stretch 3G 4035 630 CC80HV 10s |
08-29-2010, 08:28 PM | #39 (permalink) |
Align Trex 600ESP with all KDE upgrades
Align Trex 600ESP with all the KDE upgrades with new Universal Motor Mount.
08-30-2010, 11:57 AM | #40 (permalink) | |
Thanks for supporting the KDE Direct brand! Glad to hear you are enjoying the upgrades.
