Old 03-28-2015, 08:20 PM   #1 (permalink)
Default need good servos
i need to buy 3 new servos for my 250 they have to much slop makes it a little hard to level the plate i was looking at the DS416M but i think those might have a little bit of slop still and then i was also looking at the KST DS245S but those leave alot of gap i guess i don't really like that anyone got any suggestions?
FFXIJehuty is offline        Reply With Quote Quick reply to this message
Old 03-28-2015, 10:06 PM   #2 (permalink)
I'm flying my FBL HobbyKing 250 with plastic blades, a Mini Kbar controller and Hitec HS65HB ANALOG servos and it flies GREAT. I'm just a sport flyer, but it flies better than any other FBL heli I have flown. Totally smooth, stable and locked in. Very responsive with no observable deadband. Maybe a bit too slow for 3D pilots but those analog servos are plenty fast and precise for sport flying. Sure surprised me.
Paul
Paul Goelz
Rochester MI USA
www.pgoelz.com
pgoelz is offline        Reply With Quote Quick reply to this message
Old 03-28-2015, 10:17 PM   #3 (permalink)
I use the DS 430 with mine and the mini V Bar
Jim Hansen is offline        Reply With Quote Quick reply to this message
Old 03-28-2015, 10:37 PM   #4 (permalink)
i thought i saw some where the ds430m didnt work with the trex250?
Old 03-29-2015, 02:11 AM   #5 (permalink)
Lynx are just bringing out a set of 6g servos for the 180CFX which on paper look good for the 250 too, very lightweight and plenty fast enough.
They're due out any time now, but we're still waiting for the Lynx mounting adaptors for the 250.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 04-01-2015, 11:17 AM   #6 (permalink)
I am not sure about the ds430 but i've put three rjx0435 (they are bigger and heaver than the ds430m for sure) on my trex 250 dfc and they work great, i remove them because they are too heavy
Icerain29 is offline        Reply With Quote Quick reply to this message
Old 04-04-2015, 01:30 AM   #7 (permalink)
i ended up trying the ds430 on the trex250 only thing is the ball links dont work with the servo arms any way to get around this other then shorter ball links?
Old 04-07-2015, 03:40 AM   #8 (permalink)
Here you go ds430 with ball space
Old 04-07-2015, 04:54 PM   #9 (permalink)
you need space for your balls man, its a must.
Lee Griffiths
Griff1 is offline        Reply With Quote Quick reply to this message
Old 04-07-2015, 06:19 PM   #10 (permalink)
is the servos inside the frame?
Just a guy, tryin to Fly
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 04-08-2015, 02:58 AM   #11 (permalink)
i ended up doing some thing like that using the small swashplate ball links on the arms and using the stock long ball links from the arms on the plate maybes yours are longer what are the part numbers to those ball links your using and the rods?
Old 04-10-2015, 01:32 PM   #12 (permalink)
I installed MKS95 servos in both of mine and think they are perfect for this heli. You can see them in my photos.
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA
guyguerra is offline        Reply With Quote Quick reply to this message
Old 07-04-2015, 02:40 PM   #13 (permalink)
I just picked up a set of Mks ds92a+ Cyclics and a ds95i tail for my 250. Didn't get them yet but I think they will be a great match for it.
Align 250 pro DFC, Align 450 pro DFC, Align 450L Dominator, Align 550L Dominator, AR7200BX, Gpro, Bavarian Demon, DX9
rbei312 is offline        Reply With Quote Quick reply to this message
Old 07-04-2015, 05:42 PM   #14 (permalink)
If you're on a budget I use some cheap-*$$ Emax ES-08MD servos in mine and they work really well considering they're about $5 a servo. They're metal gear with plastic cases. They're a little on the sloppy side, but no worse than any of the other ones in this size.
I also have my SE set up with OMG H1-MR-IM20Q which are the hybrid metal/plastic servos to save weight, but they also have pretty decent specs for the price and gears sets are cheap if you managed to wreck them. They'll drop straight into the SE/Pro frames, but on an older 250 the frames need to be shaved a little bit. Using the medium frame balls on the front servos gets you exactly zero delta on the pitch links.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote Quick reply to this message
Old 07-06-2015, 09:50 AM   #15 (permalink)
I replaced my Align servos that were supplied in the kit with OMG servos. Before I had replaced them flying the 250 was like riding a bucking bronco, had to just hold on for dear life and fight the heli. After I replaced the servos with the OMG's it flies great with a lot less problems. Any decent set of servos though should render the same result. Good luck.
In the immortal words of Socrates... "I drank what?"
MrBrink is offline        Reply With Quote Quick reply to this message
Old 07-08-2015, 12:20 PM   #16 (permalink)
Flew 4 packs on my 250 with the Mks 92a's and the 95i last night. Flew great! A totally different heli. What a difference over the align servos.
Old 07-08-2015, 07:23 PM   #17 (permalink)
Deleted: sorry wrong thread
Nano cps,MCPXv2,130X(x3), 180 CFX, HK 250 DFC Hybrid, 450 SE, DX6i
Pilotrob is offline        Reply With Quote Quick reply to this message
Old 07-08-2015, 08:04 PM   #18 (permalink)
Deleted as well, lol
Tim
KBDD TEAM PILOT
Old 07-09-2015, 01:43 AM   #19 (permalink)
But what is the weight penalty?
Allan
Old 07-09-2015, 07:03 AM   #20 (permalink)
There seem to be two schools of thought for the 250, either build one up with quality components and accept the weight penalty, or drop as much weight as you can.
Both approaches seem to work, there are a lot of people with heavy 250's that now love the way they fly, and I suspect the weight and upgrades make for a very smooth model that handles the wind well.
I went for the opposite approach and dropped as much weight as I could. Mine is now well under 300g flying weight with stock Align servos. It's perfect for 3D flight and is very smooth and predictable in the air.
