4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support |
04-05-2014, 08:30 PM | #1 (permalink) |
3S / Tarot ZYX-S / Plushy 12a .. v120D02s
Tossed this together last year out of spare parts (130x and v120 and other).
Flies better then expected. Today it got kicked up a notch. |
04-06-2014, 04:21 AM | #2 (permalink) |
Wow
How can it even lift off with those skids installed! Bet it flies like a true 700 class bird now! Hamish
Goblin 700 Black Thunder-Xnova XTS 4525 560kv- BK7001HV/BK7006HV- Hobbywing 130a V4- Spirit Pro Citizen 828 |
09-29-2015, 03:06 PM | #3 (permalink) |
Hello SkyKraken,
How are you doing? What are your tail gyro gains on ZYX-s (1)? Or is it s2? I was playing around with ZYX (not ZYX-s) in 2013 and with the stock WK03-4 servo I could not get over 12-14% HH gyro gain Some other pilots wrote the same even for Trex250 ZYX setups. Are you maybe in any HH 52-70% gyro gain TX range (90-100% ZYX in PC setup slider open)? That would be my goal (as with 450er heli 52-56% without waggings. How well does your tail work outdoor with a little wind? My 12-14% tail didn't hold well. WK03-4 poti died - vibrations in mid servo stick... I may re-try with Spektrum DS76T at 0.03sec/60degree@5V (2s BEC). Is this the final V120 FBL (DSMx) solution besides microRondo: EZNov Neuron FBL? https://www.helifreak.com/showthread.php?t=714924 Linked up threads: https://www.helifreak.com/showthread...23#post6672423 Thomas |
03-23-2018, 04:42 AM | #4 (permalink) |
Nowadays I am thinking that the Tarot ZYX settings 333hz (digital/digital) for the WK-03-4 tail servo may have been the main problem.
Had you or any otherone success with setting the WK-03-4 tail to 250hz (214hz) with the ZYX Digital (tailI)/Analog (swash) setting and being able to set a higher gyro gain (>+12-14%) for a better working heading hold? I had NOT tried with the 250hz (real 214hz) tail setting. Nor have I tried the ZYX Analog (tail)/Analog (swash) setting (=71Hz for both).
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...XK K110...Blade 200QX quad...Ex-NanoCPX...Ex-120SR...StrykerQ (LEDs, M2 tuning)...Ex-MPX EGP...PPZ P51-D...PZ Wildcat (searching fuselage-firewall) |
