View Poll Results: Which of the following is true?
I have an OS105, the pin has always been fine and my engine has less than 10 gallons 7 21.21%
I have an OS105, the pin has always been fine and my engine has more than 10 gallons 2 6.06%
I have an OS105, the pin has always been fine and my engine has less than 20 gallons 7 21.21%
I have an OS105, the pin wore through before 10 gallons were through 9 27.27%
I have an OS105, the pin wore through between 10-20 gallons 6 18.18%
I have an OS105, the pin wore through after 20 gallons 2 6.06%
Voters: 33. You may not vote on this poll
Old 11-18-2015, 09:30 AM   #21 (permalink)
i have had this happen 5 times now. ranging from 20 gallons, to 2 tanks. I can tell immediately at this point when it happens by the way the motor is running. there are a few things that contribute, I think they are aware of it now. the last thing you want to do it put a solid pin in its place though IMO. heath expansion is drastically different from hardened steel and aluminum. I think the issue arose when O.S. moved their factory from japan to china.
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 10:11 AM   #22 (permalink)
My OS105 fly great after the solid pin mod to the piston. No problems doing that for me. But it must be done by a professional.
If OS don't fix the problem, I will go for a YS.
I really got fed up with my OS105. The last time the failing pin ruined a brand new sleeve, piston ring and piston. I was still busy with breakin. I had less than 5 tanks through it.
The OS suppliers in our country did nothing and ignored my emails.
I send them numerous emails complaining about the pin in the piston failing. I just gave up on them.
That's when I searched on helifreak and came across "sirolfs" thread and decided to do the same as I were desperate. It worked like a charm.
I really hope OS support are better in other countries.
Align T-Rex 600&700 Nitro Pro DFC
SAB Goblin 630 Competition
SAB Trioblin 500
Futaba 8FG Super
cmouton is offline        Reply With Quote Quick reply to this message
Old 11-22-2015, 06:33 AM   #23 (permalink)
OS will not help you even if you have tons of evidence backing it up.
Believe me i also bombarded OS with emails.
They claim it is from running lean... period.
Like talking to a wall.
Do the mod and you won't have to worry about it anymore.
I'm having a spare piston done right now.
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X
Sirolf is offline        Reply With Quote Quick reply to this message
Old 11-25-2015, 05:25 AM   #24 (permalink)
Hi .
I found this in Amazon , if the picture is OK, now the piston ring pin comes from top to bottom.
Part Number 28703200
http://www.amazon.com/Engines-287032.../dp/B007UQXFO0
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 11-26-2015, 05:46 AM   #25 (permalink)
Originally Posted by msallua View Post
Hi .
Amazon.com: O.S. Engines 28703200 Piston for 105HZ Engine: Toys & Games
What make syou say that? looks like a standard piston to me, the holes in the top are there on all of them.
Delarado is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 11:24 AM   #26 (permalink)
Looks like the piston pin runs vertically. Click on the image and zoom in.
abit late is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 12:00 PM   #27 (permalink)
+1
Old 11-27-2015, 02:29 PM   #28 (permalink)
You see the light through the hole on top. It's not a vertical pin. If that were really the pin, then it was also located at the wrong place.
Have a look at a 105 piston and you will see what I mean.
SAB Trioblin 500
Futaba 8FG Super
Old 11-29-2015, 10:51 AM   #29 (permalink)
Yep... it looks like a vertical pin if it is what you would want to see.
Only the gasser GT15 had the same problem and they where replaced with these vertical pins.
Old 11-30-2015, 07:39 AM   #30 (permalink)
What you see there is a lack of a shadow where the hole in the top of the piston is to put pressure on the ring improving the seal , that is the std piston in the pic , sadly OS yes to look at the problem!
cabeng is offline        Reply With Quote Quick reply to this message
Old 01-20-2016, 05:30 PM   #31 (permalink)
Hey guys I received a new 105 piston from RC Japan today and it's got a solid pin!!!! Looks like OS was listening :thumbup
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 01-20-2016, 05:32 PM   #32 (permalink)
Old 01-20-2016, 11:30 PM   #33 (permalink)
very good news indeed
Steve Graham is offline        Reply With Quote Quick reply to this message
Old 01-21-2016, 07:27 PM   #34 (permalink)
That is great news. Hopefully the new engines will come this way as well.
dbcaster is offline        Reply With Quote Quick reply to this message
Old 01-22-2016, 10:25 AM   #35 (permalink)
so much for "we are unaware of any pin related issues" lol I'll order one down the road once more people get them
blue92ehsi is offline        Reply With Quote Quick reply to this message
Old 01-22-2016, 10:38 AM   #36 (permalink)
Danny Dugger, the item has a special part number or is the same?
Please, Can you share with us the link in the website ( Rcjapan) of this part?
Thanks in advance
Old 01-22-2016, 01:22 PM   #37 (permalink)
Thanks in advance
Same part number
https://rcjapan.net/o-s-engine-parts...bbvj1tle4qjjd2
Old 01-22-2016, 10:22 PM   #38 (permalink)
I voted less than 20 gallons with no problem. I have 2 of these, went through 36 gallons this past season split equally between two helis, so 18 gallons without issue. Took engines apart, everything looks great. Rebuilding anyway, and just ordered new pistons from RC Japan a couple days ago. After seeing the above post about the solid pin, I will let you guys know what I get when my new parts arrive.
marc8090 is offline        Reply With Quote Quick reply to this message
Old 01-22-2016, 11:28 PM   #39 (permalink)
I ordered a new 105 yesterday. I will also post on the piston once it arrives.
Old 01-23-2016, 02:58 AM   #40 (permalink)
Hope to see this with 91hz pistons also...
