Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 255
Hurricane 255 Discussion and support of the Gaui Hurricane 255
Old 03-05-2012, 04:34 PM   #1 (permalink)
Default Anybody else have bad luck with 1 way bearings?
I just got my Hurricane 255 about 2 weeks ago and have not really even flown it yet. I have had just a few short setup/trim flights. About 1 and a half weeks ago I had a hard landing...really, not a crash just a hard, dig in to the dirt a little landing. After that I noticed my one way bearing wasn't holding/engaging correctly. It would get a very slight grip on the main shaft but with any force at all it would slip. So I made up a list and ordered a few spare parts to have on hand. I went ahead and put on a new main gear (because it looked a little warped) and pressed in a new 1 way bearing. Today I went out to fly, landed gently to add a little trim. When I applied throttle I noticed that same clicking sound and blades just barely spinning as before. The meshing between the main gear and pinion is good. Is there something I am missing? Has anyone else had a similar problem? Or do I just have bad luck?
Clay333 is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 06:02 PM   #2 (permalink)
Looks to be a case of bad luck, i haven't had to replace mine yet after 2 minor crashes, my old 200 on the other hand did have to have about 9 replaced. I went the route of buying the gear with bearing already pressed in.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 06:06 PM   #3 (permalink)
Yeah, I would have preferred to get the already assembled gear, but rick at clubheli.com was out of stock when I placed my order. I guess I will try another one. Hope it works out better this time. I really want to get this bird flying good.
Old 03-05-2012, 10:09 PM   #4 (permalink)
I think they are back in stock.
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 01:23 PM   #5 (permalink)
hi! I've had one way issues high head speed.actually for me it was the main gear that got loose.. I know some people use glue but that didn't work for me. I needed change the red gear so often that i decided to use the t250 one instead. That solved it because of the metal core.. The meshing was the the same..
djelom is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 05:18 PM   #6 (permalink)
is the Trex 450 main gear a perfect fit? Do you have to mod anything? When using a 250 gear you also use the trex one way bearing and holder correct?
Old 03-07-2012, 02:33 PM   #7 (permalink)
Here is a Trex 250 main gear in my X2. It sits lower than the stock gear so I have fitted an extra plastic pulley on top of the Trex gear.
I have done only a couple of flights with this setup so it is too early to estimate how it will last in a long run.
Goblin 420 Sport, Goblin Fireball Competition
HD FPV setups with DJI Ocusync video links.
Picofly is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 02:50 PM   #8 (permalink)
Very interested in this
Old 03-08-2012, 02:45 PM   #9 (permalink)
very nice indeed!
Good idea Picofly, looks more simple to implement than what I have
But how does the autorotaion behaves? is the uper-part pulley with the belt grinding the lower main gear when releasing throtle?
The T250 is otherwise straight fit, in that sens that the one way of the T250 is the same size, and shaft also is same.
Old 03-09-2012, 09:25 AM   #10 (permalink)
very nice indeed!
It is a snug fit but but the pulleys do do not grind each other.
I have just removed the CNC collar from the lower pulley and expanded the hole to ~9mm. At the moment I have CA'ed the pulley to the Trex gear but I may fix it with screws when I need to remove the gear next time (after the next crash, that is).
It was a very easy mod. It took less than 10 mins. accomplish.
Old 04-10-2012, 12:15 AM   #11 (permalink)
Nice mod, Picofly. How did it work out? Are you still using it?
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 07:06 AM   #12 (permalink)
I have just had another one way bearing fail. Not sure if it is spinning in the gear, or has failed. This little heli is getting tiresome. There is always something to sort out whereas my Trex 250 just flies straight out of the box.
So, I am after a good mod for the one way bearing now, If the Trex 250 gear fits easily, I will give that a try,
Flybar Helis mSR & B/H'd HBFP2. Guru-Z Neon. Trex 250 SE. Trex 450 Sport.
Flybarless Helis mCPX V2. Gaui X2. Tarot 450 Pro. Protos 500. Compass Atom 500.
Fubarred Helis Brushless Bee & Silverlit Chinook
CageyH is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 08:50 AM   #13 (permalink)
The bearing is fine. Turns out the bearing to gear interface is the issue. Do you think a one way bearing with a knurled outer surface would help? I see Boca do one - HF0306 KF R.
Old 11-25-2012, 10:44 AM   #14 (permalink)
It probably wouldn't hurt. But if it were me, I'd glue the bearing in instead. Prep the surfaces and use a quality epoxy and you should never have a bearing/gear issue.
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 11-27-2012, 01:44 PM   #15 (permalink)
I have just used a spot of CA on the bearing/gear interface, so time will tell if it holds or not.
If that does not work, I'll try some expoxy, and if that does not work, a trex 250 gear.
Old 11-30-2012, 02:25 PM   #16 (permalink)
CA seems to have done the trick so far.
Six batteries through the heli today, with no problems.
Old 08-11-2013, 04:53 AM   #17 (permalink)
Anybody found a definitive cure for this issue?
My OWB has just started spinning in the gear again.
