Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 03-25-2012, 02:04 AM   #1 (permalink)
Default Ice 100 has me totally stumped....
Last weekend (first time with new esc):
ESC under canopy. Idle-up1 LOTS of power. Esc 170 degrees and motor hot. Battery had over 30% left after 4mins (hyperion sentry).
This weekend (after having moved the esc and setup my beastX again):
ESC on side of frame. Idle-up 1...an even tried 2. Hardly any power, feels like it's bogging flying sport. Esc barely above body temperature and motor warm. Battery had 50% left after 4 mins (hyperion sentry).
Heli: KDS 550. 1200KV motor, 14T pinion, 150T main gear. Gens-Ace 5000mah 50c 6s
Throttle curve:
Normal: Straightline from 0-100
IU1: 90-INH-85-INH-90
IU2: 95-INH-90-INH-95
Pitch: Straightline +12 -12 (Normal mode -3 and +12)
Anyway, any help would be awesome. I have absolutely no idea what's going on.
Edit: I have added a spreadsheet. Left side shows the hot and powerful flight and the right shows today's.
The images I have attached are both from today. One of a 4min flight, one of a shorter flight before I gave up and went home....
Name:	4min flight.jpg
ID:	301834   Click image for larger version
Name:	Short flight before going home.jpg
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 03-25-2012, 03:20 AM   #2 (permalink)
I shouldn't have rebound my tx/rx right? That wouldn't cause it?
Old 03-25-2012, 06:11 PM   #3 (permalink)
Have you set up your throttle endpoints and auto bailout?
HiVolt is offline        Reply With Quote Quick reply to this message
Old 03-25-2012, 11:41 PM   #4 (permalink)
Hi, thanks for the reply.
I did the endpoints....ended at about what would be expected because I want to use the bailout. Would there be any reason that I should try rebinding the RX since resetting the esc the beastX also?
I'm thinking maybe I should try the old esc that seemed to work ok?
Old 03-26-2012, 03:36 AM   #5 (permalink)
Checked and I had the PWM rate on 12.
I have now changed it to 8 (which I think was what it was on when I had power)
We'll see how it goes!
Old 03-26-2012, 09:55 AM   #6 (permalink)
Maybe bad solder connections??
MCPX v2 - Trex 450 v2 - Trex 550e v2 - DX8
mmjl_ is offline        Reply With Quote Quick reply to this message
Old 03-26-2012, 12:34 PM   #7 (permalink)
Thanks, I'll fly it with the changed PWM,
Then I'll re-do the connections next....
Then if there's no change I'll swap out the esc.
Old 03-27-2012, 05:04 PM   #8 (permalink)
Changing the PWM made no difference. Motor is warm+ and esc is body-temperature or below.
Here's the latest graph. Maybe something slipping?
Old 03-27-2012, 05:22 PM   #9 (permalink)
Can't imagine your normal curve to be good. Only 50 throttle mid stick, something like flat 80 better. Start at 0 of course on normal mode. Check all connections, se if one hotter than others after running. That will be poor connection heating because of high resistance.
LARRY2716 is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 06:38 PM   #10 (permalink)
Ok so 0-80-80-80-80 for normal, will try that.
The thing that I don't get is that the amps spike up and sown so violently. The soldering seems fine but I think it may be worth another check?
Old 03-27-2012, 08:05 PM   #11 (permalink)
Ok are you useing governor mode or fixed endpoints... I input your spex in my cc link this is what i got.. In gov mode (hight) set your batt then set your motor/gearing Inf. Below that the 3 box. Box 1 is normal set 1800 throttel 1;522ms(about 52.8%) flat curve. Thats 0-52.8 -- -- --. Box 2 is IDL up 1 thats 1900 throttel 1.553ms(about 56.7%) flat curve 56 56 56 56 .And box 3 is IDL up 2 thats 2000 1.580ms(about 60%) flat curve 60 60 60 60. To me thats a nice setup for f3. But what ever HS you use use a tac on the head. For the gov will shot down if you overspeed the gov seting.
blackbeard is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 08:10 PM   #12 (permalink)
Fixed endpoints
# Castle Link Data File
# Created: Tuesday, March 27, 2012
# Do Not Edit This File By Hand
Hex55: 85
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Hard Cutoff (*)
Motor Start Power: 59
Direction: Forward (*)
Current Limiting: Normal (150A) (*)
Cutoff Voltage: Auto Li-Po (*)
Brake Strength: 0
PWM Rate: 8 Khz
Sample Frequency: 1 Sample / Sec (*)
BEC Voltage: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell (*)
Motor Timing: 5
Data Log Enabled: 255
Vehicle Type: Helicopter
Throttle Type: Fixed-Endpoints
Throttle Response: 5
Governor Gain: 15
Initial Spool-Up Rate: 5
Head Speed Change Rate: 5
Auto Rotate Enabled: True
Governor Mode Type: Simple
Old 03-27-2012, 08:45 PM   #13 (permalink)
Smile
Cutoff Type: Soft Cutoff (*)
Disable------- Current Limiting: Normal (150A) (*)
Old 03-27-2012, 08:53 PM   #14 (permalink)
Thanks for the info. The esc is only 100A so is it still ok to disable the current limiting??
My batteries are 50-90C
Old 03-27-2012, 09:02 PM   #15 (permalink)
Red face
Yes i am running a cc75 on a 50 class 8s 5000 30c for 6 months now all is ok .
Old 03-28-2012, 12:50 AM   #16 (permalink)
Did the current limiting to insensitive and the soft cutoff.
Here's the setup for tonight's flight:
# Created: Wednesday, March 28, 2012
Hex55: 85
Current Limiting: Insensitive (175A)
Brake Strength: 0
PWM Rate: 8 Khz
BEC Voltage: 5
Motor Timing: 5
Governor Gain: 15
I'll attach a pic of the log. Still no different.
Old 03-28-2012, 04:08 AM   #17 (permalink)
Hex55: 85
Brake Strength: 0
PWM Rate: 8 Khz
BEC Voltage: 5
Motor Timing: 5
Governor Gain: 15
You've selected auto rotate enable which is good.
Have you set the correct value for throttle hold? It is different for each transmitter.
After you have done that, test it on the ground. You will need to increase the Head Speed Change Rate to suit your heli or it will not help you if you need to bail-out from an auto. You will probably finish up with a value > 10.
Regards
Acrow
acrow is offline        Reply With Quote Quick reply to this message
Old 03-28-2012, 12:43 PM   #18 (permalink)
rebeltrousers, what version of the ESC firmware are you running? 4.0?
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
Old 03-28-2012, 01:52 PM   #19 (permalink)
Hi there!
Throttle hold is working fine. Haven't checked it doing a bailout yet though because the power I'm getting in general is so disappointing.
I'm running the latest firmware, the one before the 4.0 Beta.
Old 03-28-2012, 04:52 PM   #20 (permalink)
OOOoooooo you are looking ass hauling power. Your log looks ok for the setup you have, You are running 2300 hs you are peeking 100 amps you have 105 temp and it looks like you can get 5/6 mins flight time.
