Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-25-2010, 10:42 AM   #1 (permalink)
Default Fuel Line Grommets?
Can someone please tell me what the deal is here? Another Align mistake?
I'm trying to put in the grommets as suggested in the manual, one hole is clearly smaller than the other and when I put the grommet in the smaller hole it doesn't fit.
Any ideas on this? Misprint on the Carbon Fiber Frame?
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 10:54 AM   #2 (permalink)
They fit just squeeze it inthere
Sake is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 10:59 AM   #3 (permalink)
even though one hole is much smaller than the other? Or is my frame wrong? Should the upper holes be the same size?
Addicted to Helis
Old 01-25-2010, 11:04 AM   #4 (permalink)
I've had a similar issue, with one of the holes being smaller. I got the grommet in there but I'm a bit concerned that it's pinching the fuel line slightly. Haven't flown it yet though and perhaps I'll try and expand the hole a little bit.
J-S-Q is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 11:21 AM   #5 (permalink)
The frame is the same, one hole is bigger probably so the fuel line can slant
Old 01-25-2010, 11:37 AM   #6 (permalink)
Well I wouldn"t be too concerned they designed it that way for some reason
Old 01-25-2010, 12:56 PM   #7 (permalink)
The smaller hole is where the fuel line from the tank goes and this is the one that needs to slant so I kind of doubt that theory.
Old 01-25-2010, 01:56 PM   #8 (permalink)
had the same on my LE there was no way that the grommet was going in that hole so i drilled it out to the same as the larger hole.problem sorted
tony stevens is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 04:02 PM   #9 (permalink)
+1
Trex 600E PRO
Trex 700LE
edkoz is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 08:57 PM   #10 (permalink)
Originally Posted by edkoz View Post
+1
Guess that's what's going to happen because I can barley fit the fuel tube in there without the grommet.
Addicted to Helis
Old 01-26-2010, 07:29 AM   #11 (permalink)
Just use some some "human lube" like Bob says..., aka...spit. They fit, but tight.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote Quick reply to this message
Old 01-26-2010, 07:44 AM   #12 (permalink)
Yes but why are the holes different sizes? Mine did fit but before I've even flown it one of the grommets (in the small hole) has disintegrated just from adjusting the fuel tube. I'm going to drill it a bit larger because as pointed out above it's barely any larger than the fuel tube itself.
Old 01-26-2010, 07:57 AM   #13 (permalink)
well, I drilled it, I think with a 5/16's bit.
The hole came out slightly larger than the other hole but the grommet fits and the fuel tube fits nice and snug.
There was no possible way the grommet and tube was going to fit. There must have been a few frame mistakes shipped out there.
No worries, it looks great now.
Addicted to Helis
Old 01-26-2010, 08:09 AM   #14 (permalink)
I took a bit of silicone grease and covered the rubber grommet inside with it and the tube just went in very easy. I can pull the tube now, if it needs adjusting, easily. Scotty the tube fits just fine, it's trying to fit the grommet in the frame hole that is a pain in the butt.
Team GrandRC
Old 01-26-2010, 08:32 AM   #15 (permalink)
Why two different size hole for same tubing ?
Old 01-26-2010, 09:18 AM   #16 (permalink)
Good question. My take is, that the small hole is only for aspiration to the tank (keeping positive fuel pressure). I think you can use smaller diameter fuel tube, like a clunk line vs. the big hole where the fuel feeding tube goes through.
If you compare clunk tubes vs. regular fuel tubing, you'll notice a slight diameter difference.
Team GrandRC
Old 01-26-2010, 10:02 AM   #17 (permalink)
Surely if that was the case then the kit would come with a smaller diameter fuel tube? Anyway, the smaller hole on my frame is the one that the fuel flows through according to the manual so that certainly doesn't make sense to me.
Old 01-26-2010, 10:37 AM   #18 (permalink)
OK, my argument just collapsed. I guess their computerized CF cutters make mistakes then. A bit of silicone grease did the trick for me.
Team GrandRC
Old 01-26-2010, 01:26 PM   #19 (permalink)
I don't know, the whole thing is just screwy to me. So I expanded the whole and it seems like it's all going to work well.
Ready to Fly!!!!
Addicted to Helis
Old 01-26-2010, 04:07 PM   #20 (permalink)
Just did a 700le build and holes for the gromets are 2 different sizes.
I never use the fuel tubing that comes with kits because its junk replaced it with my favorite tubing, bagged the gromets because the tubing I use doesn't fit!!! Besides, it's a kit, build it the way you want it if it doesn't fit, do what you need to do to make it fit, short of using a hammer on it..
Whoa Bessy
Cowman is offline        Reply With Quote Quick reply to this message
