Old 03-06-2012, 02:10 AM   #341 (permalink)
I use deoxit myself and folow up with the gold. Makes my twitchy servos really smoothe.
Tasteles is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 10:42 AM   #342 (permalink)
I just bought that at radio shack it seemed to work really good got rid if my tail wag
timmyd463229 is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 12:33 PM   #343 (permalink)
Could my Xtreme head and grips cause shaking?
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 12:40 PM   #344 (permalink)
Yes, it's possible. I saw this with the early MH metal grips. Sloppy bearing fit...
ChrisH is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 12:48 PM   #345 (permalink)
Hmm, thanks. I did not have this problem with my previous Rakon MCPX. So, I might just get rid of the Xtreme head. I will probably switch back to the stock set and see if the shakes goes away.
I'm probably going to rebuild my V2 anyway once I get my TDR set. Thanks for the input!
Old 03-12-2012, 08:37 AM   #346 (permalink)
ChrisH,
Cheers for the tip. The mcpx started to shake, a servo has the problem. Will do as you sescribed.
|Michalis|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 12:27 PM   #347 (permalink)
Actually it's time to clean the servos on one of my mCPXs as well!
Old 03-12-2012, 12:42 PM   #348 (permalink)
yep, servo stuck in chicken dance full up. and that bent the aluminum main shaft I got to reduce the servo carbon uptake. Fun.
AlphaKilo is offline        Reply With Quote Quick reply to this message
Old 03-17-2012, 11:43 AM   #349 (permalink)
Cleaned all three servos and everything smooth again.
|Michalis|
Old 03-24-2012, 03:10 PM   #350 (permalink)
This thread is loooonnnngggg!!! Haven't seen much new information.
Tim
Blade MCPX BL stretched, full Rakon upgrades
mombawamba is offline        Reply With Quote Quick reply to this message
Old 03-24-2012, 09:39 PM   #351 (permalink)
There isn't much science in cleaning servos...
Old 03-26-2012, 12:37 AM   #352 (permalink)
Yup!
Tim
Old 03-27-2012, 02:10 PM   #353 (permalink)
Ok I just bought the deoxit and I read the instructions but it seems to be over kill to spray the servo! Should I spray a q-tip then apply and rub a bit?
How do you all use this stuff?
James
DX6i / Brushless MCPX / 2 stock MCPX / MQX / 120SR / Scout
jamesandyori is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 02:35 PM   #354 (permalink)
James
Papar match stick works best for me, I just give the torn part of the match stick a squirt.
Be very careful cleaning the fingers, they bend super easy, just brush them gently in one direction from the base to the tip.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is online now        Reply With Quote Quick reply to this message
Old 03-27-2012, 11:53 PM   #355 (permalink)
Cleaned all 3 servos. Should there still be chatter? My second mcpx has chatter from the box so I think yes. I have the 120 sr tail boom and motor! I also have a bit of tail wag. I cut the boom 1/2 inch and it's better. Tomorrow another 1/2 inch. I'm running brushless, and it hovers good it's just the darn wag!
James
Old 03-28-2012, 12:07 AM   #356 (permalink)
James
Yeah they will chatter when in the neutral position, the tail wag could be a bunch of different things.
Just a few things I can think of off the top of my head..
Main gear not aligned with the flat spot on the main shaft
Blades too tight or too loose
Bent feathering shaft
Loose screws in the main shaft
Cracked main shaft
Dirty or dry main shaft bearings
Old 03-28-2012, 12:15 AM   #357 (permalink)
Cracked main shaft
Ok I checked all except for the feather shaft. I will pick one up tomorrow.
thanks,
James
Old 03-28-2012, 11:43 PM   #358 (permalink)
Changed the feather shaft and it still like wobbles. I have noticed that the pinion that was installed on the motor has damaged teeth. That's next, I have another to swap it with!
Maybe my v2 board just doesn't like brushless!
I have read that success is decided board by board some like it while others don't.
James
Old 03-29-2012, 01:38 PM   #359 (permalink)
I know that these blades are little, but have you checked them for balance?
Heli Jim
Blade 120 SR, Blade mCP X, DX6i
"If you're not flyin, you're not tryin' "
Heli Jim is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 01:54 PM   #360 (permalink)
James
You will inevitably need a feathering shaft in the future so having a spare is a good thing.
For future reference you can check to see if the shaft is bent by removing a blade and spinning the shaft, if it is bent the remaining blade will move up and down while you turn the shaft, or of course you could take the shaft out and roll it on a flat surface.
