Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 06-05-2016, 04:45 AM   #1 (permalink)
Default Remove bearing from autorotation hub
Is there an easy way to remove a bearing from the autorotation hub? The one-way and one bearing are fine, one bearing is stiff. There's a recess on either end of the hub for the bearings so I can't just punch.
I have another hub to compare with and bearing. That I got the one-way and bearing out by punching, but one bearing was already removed.
Compass 6HVU, XLPower 520, Chase 380
cycled is offline        Reply With Quote Quick reply to this message
Old 06-05-2016, 08:26 AM   #2 (permalink)
I have yet to remove a bearing from an OW hub but the easiest way to do so is probably with an arbor press. I don't have an arbor press but I have removed bearings from housings using a combination of a heat gun, appropriate sized socket head (as the punch tool) and a rubber hammer. Check out this post on my 550U build thread for a bit more detail: https://www.helifreak.com/showpost.p...4&postcount=71
Pic below from that thread showing the tools I used... Most of these techniques I learned from Ah Clem.
XLP Specter NME | Oxy 5 550, 5 HF 560, 5 HF 610 | Compass Chronos, 7HVU, 550U, Atom | Gaui X3
cyclo is offline        Reply With Quote Quick reply to this message
Old 06-05-2016, 03:44 PM   #3 (permalink)
Oh, I've punched stuff out before (via a bolt or some suitable punch and a hole of some kind), but the one-way hub has a recess at either end for the bearing and a smaller diameter in the middle. I considered punching the centre of the bad bearing inwards, but the damage to other parts would be unpredictable.
Old 06-11-2016, 03:46 PM   #4 (permalink)
I ended up levering the bearing with a screwdriver a bit, then found it was turning easier. Weird. When I got the thing built, it rotated so smoothly... far the smoothest I've ever had (I since tightened the belt a bit, but still pretty good).
Old 06-29-2016, 09:31 AM   #5 (permalink)
Formerly BarnStormer
If you don't have a press the best way to remove the owb from the hub is to use two sockets and a big c-clamp. Works perfect.
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 06-29-2016, 05:03 PM   #6 (permalink)
Pressing is not the problem, it's "pulling" the first bearing out that's the problem.
