Old 07-19-2015, 06:20 PM   #1 (permalink)
Default Trex 450 pro FBL with microbeast settings for DX9
Picked up Trex 450 Pro FBL with microbeast . Trying to set it up on my DX9. Can anybody can share settings with me?
Thank you much
Andrejraca is offline        Reply With Quote Quick reply to this message
Old 07-19-2015, 06:55 PM   #2 (permalink)
Are you needing help setting it up or is it flying?
(I.Y.A.O.Y.A.S.)
Old 07-19-2015, 07:10 PM   #3 (permalink)
Bought it used and it was flying , just need to setup DX9 for it.
Old 07-19-2015, 11:06 PM   #4 (permalink)
Is it a bx or the ar7200bx? If you dont know the difference... is the unit orange or black?
(I.Y.A.O.Y.A.S.)
Old 07-20-2015, 05:13 AM   #5 (permalink)
Microbeast. Orange
Old 07-20-2015, 07:55 AM   #6 (permalink)
Ok thats a microbeast. You will need to buy a satellite receiver and the adaptor for the microbeast or a full 6 channel receiver in order to bind it to your radio. Most just use the sat because the wiring isnt much of a hassle and its alot cleaner look.
(I.Y.A.O.Y.A.S.)
Old 07-20-2015, 03:09 PM   #7 (permalink)
Binding is not a problem , I already bind it .It has satellite receiver. What I am looking for is setup for DX9.
Thank you
Old 07-20-2015, 07:42 PM   #8 (permalink)
Each heli is setup a lil different in means of radio settings because of the different turns of links, combination of servos, horns etc. If you haven't setup a heli before then I suggest you watch some videos on setting up the bx, theres quite a few of them out there.
(I.Y.A.O.Y.A.S.)
Old 07-21-2015, 03:03 AM   #9 (permalink)
DX9
On transmitter:
Normal mode:
Throttle: 0,40,70,85,100
Pitch: 40,45,50,75,100
Hold mode:
Throttle: 0,0,0,0,0
Pitch: 50,50,50,75,100
Stunt 1:
Throttle: 85,85,85,90,100
Pitch: 0,25,50,75,100
Stunt 2:
Throttle: 95,95,90,95,100
Gyro: start with 30%
Swashplate: normal
No trimm of servos !!!!!
Reverse settings: you have to test the servo directions !
Aileron,Elevator: Dual rate: start with 75% (later higher)
" " Expo: start with 30% (later lower)
Rudder: Dual rate: 100%
Expo: 0%
On FBL unit:
Below settings are for stock Align servos !!!!
Setup menu point B: 200hz servo frequency
Setup menu point C: 1520 us
Setup menu point D: 333hz " "
Setup menu point H: 120 degrees
The rest you have to find out by testing the directions (different LED's on FBL (for example: red,blue,purple light)
Have fun
Sven
lahannsven is offline        Reply With Quote Quick reply to this message
Old 07-21-2015, 07:16 AM   #10 (permalink)
Sven , Thank you sooooooo much for your help.
Old 07-21-2015, 05:23 PM   #11 (permalink)
Then check out Freddy can fly beastx set up videos on YouTube, helped me out a lot, and he explains steps very well...
hairymuffin is offline        Reply With Quote Quick reply to this message
Old 07-22-2015, 08:20 AM   #12 (permalink)
What I forgot is the point:
Channel assign on your Dx9.
If you only use a satellite receiver, the channel order is different.
Dx9 channels are usually preconfigured for a standard receiver.
So if you only use a satellite receiver, check carefully in the manual of the microbeast, how the channels are mapped.
Sven
Old 07-22-2015, 10:04 AM   #13 (permalink)
I already bind heli to my DX9 and everything is moving how it should so I thing channels are OK. I am right or wrong?
Old 07-22-2015, 10:53 AM   #14 (permalink)
If everything moves as it should then I would say yes, its correct. Make sure to check your correcting directions before you test hover or itll be the quickest crash youll ever have.
(I.Y.A.O.Y.A.S.)
Old 07-22-2015, 12:55 PM   #15 (permalink)
thanks
Old 08-09-2015, 02:50 PM   #16 (permalink)
Finally got time to work on it. On DX9 I have throttle cut -130%. Not very familiar what it means but throttle is not reacting to the stick. When I started moving it to 0% blade started spinning .Am I in some different mode on beastex? Appreciate any help.
Old 08-09-2015, 09:11 PM   #17 (permalink)
Is it a Ar7200bx or just a bx? And what esc are you using?
(I.Y.A.O.Y.A.S.)
Old 08-09-2015, 10:02 PM   #18 (permalink)
It sounds like you need the talents of a local hobbyist who is familiar with the BeastX setup procedures...there are specific steps to take to insure proper stick responses, and it seems you have one if not several things going wrong...
Flying the model under those conditions will be costly, if not dangerous
Contact a local club...ask for a favor and pay attention
I almost didn't...and I had several things wrong so it was well worth it
Old 08-10-2015, 12:00 AM   #19 (permalink)
You shouldn't be using throttle cut on electrics. That is for nitros. If your wanting to use a throttle cut off you should be using throttle hold which is set up when you do the model set up in your tx. Atleast this is how you activate it on my dx8, and I would imagine it would be close to the same in the dx9.
(I.Y.A.O.Y.A.S.)
