Old 07-19-2016, 07:44 AM   #1 (permalink)
Default Mix Set Up
I'm looking to have two TH for safety reasons. I'm running the Vbar NEO from a DX9. The NEO wants to see -100 on the gov channel for TH, which I already have set up. How do I create a mix to another switch to duplicate that?
[B]Phoenix Sim V5.5, Spektrum DX9, PowerLab 8, iKon 2 HD, SAB Goblin 770
gtrsteele is offline        Reply With Quote Quick reply to this message
Old 07-19-2016, 08:48 AM   #2 (permalink)
Just use 'Throttle cut', I set the value ridiculously low so there's definitely no chance of a signal passing.
Steve
Nano CPX || 130X || 230S II 450 3D converted to 450X || 360CFX || 480 Fusion II 550X || Oxy 5 MEG || ALeeS Rush 700 Evolution || Goblin 770 Sport 'My flight style, determines my crash style"
crashcopterman is offline        Reply With Quote Quick reply to this message
Old 07-19-2016, 04:44 PM   #3 (permalink)
TC on the DX9 is "hard wired" to the throttle channel. The NEO uses values from the gov channel. I believe it uses the throttle channel to change FM
Old 07-19-2016, 08:16 PM   #4 (permalink)
Let me see if I understand this correctly - you want to have a second switch that will also put -100% on the gov channel? Therefore, you'd have two switches that will activate TH, and you'd want both switches to be in a certain position in order to allow the NEO to spool up?
flightengr is offline        Reply With Quote Quick reply to this message
Old 07-19-2016, 08:20 PM   #5 (permalink)
Steve
I learned that you don't want to set Throttle Cut below -100%, the same level as the bottom of your throttle stick. If you leave TC at the default value of -130%, and if you accidentally have TC on when you plug in the battery on the heli, then turning off the TC may allow the motor to start spooling up even though your throttle stick is still at the bottom. That's because the ESC will see a change from -130% to -100%, which will look like you moved the throttle stick up. I've seen it happen, so it is possible and can be replicated.
For that reason, I always turn up the value of TC to -100%. The only reason I put it lower than -100% is for a quad that wants a signal below -100% as an indication to shut down the motors per the instruction manual.
Old 07-20-2016, 01:18 AM   #6 (permalink)
That's so highly unlikely that your ESC will be happy seeing those values. On over a dozen machines I've mucked with a throttle cut even at -100 they wouldn't spool up. I think I'd have to look at my radio and experiment or see an example to fully understand what you are saying. All my machines run Castle ESC's and are governed (30,70,100), with TC and TH I can move the stick wherever I want, nothing will happen. Anyway, this doesn't help the OP as he has a Neo, back on topic. Sorry my suggestion won't work for you OP.
Steve
Old 07-20-2016, 04:22 AM   #7 (permalink)
Yes, but I only want the switch as a "double redundancy" for TH whiles handling the heli while it's "hot"
Old 07-20-2016, 06:43 AM   #8 (permalink)
Steve
I'm not using a governor setup. I've had this happen on a stock Blade 450 3D. When TC is set below -100% and I power on the heli with TC on, then turning off TC will start the motor turning. Granted, it's not very fast - just a small amount of movement. It's almost like the ESC is recalibrating itself for the low throttle endpoint every time it's powered up. If TC is off and I power up the heli, then nothing happens - just like it's supposed to behave with the stick down. After I discovered that, I started setting TC to -100% and now everything works fine, regardless of whether TC is on or off when the heli powers up.
Old 07-20-2016, 06:48 AM   #9 (permalink)
I can envision a mix that will allow another switch to force a value of -100% onto the channel that the governor is watching, but then either switch will activate TH. Is that OK? The transmitter isn't smart enough to coordinate the function of two switches as a redundant safety feature. So either switch will activate TH, and flipping the second switch will have no visible effect. When both switches are set for TH, then you'll have to flip both switches in order to release TH.
Here's what I have in mind:
Mix 1
ON > (channel you're using for this function)
Rate: -100% 0
Offset: -100%
Switch: (switch and position of your liking)
Note that this will actually push the value of the channel down to -150% when the first switch already sets it to -100%. If that's an issue, then more creativity will be required.
Old 07-20-2016, 09:46 AM   #10 (permalink)
Default Mix Set Up
Mix 1
Rate: -100% 0
Offset: -100%
I want to have to release both TH so that's good. I'll try it out. Thanks!
Old 07-20-2016, 08:41 PM   #11 (permalink)
I had to the configuration in the pic to get what you suggested. Now to pull the blades off and test. Then rebind for failsafe. Thanks again.
Old 07-20-2016, 11:36 PM   #12 (permalink)
You could actually use two mixes, one to change the current value to zero, and a second to force -100. That way, you will never get that -150 from the combination of two switches.
I know it's possible but can't look for details at the moment
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 07-21-2016, 11:39 AM   #13 (permalink)
You have my attention. It may not even matter though.
Old 07-28-2016, 05:45 PM   #14 (permalink)
Default Mix Set Up
Update: this mix worked just fine. My NEO sees 150% the same as 100%.
Old 07-28-2016, 10:09 PM   #15 (permalink)
Yay! Glad to hear it.
