mCP X Blade Micro CPx Helicopters Information and Help |
08-15-2015, 01:01 PM | #1 (permalink) |
My mcpx cuts connection at 60/70% throttle?
Hi.
Im suddenly experiencing my mcpx to cut the connection at about 70% throttle. Ive tried brand new batteries, but no luck. Is there anyone out there that might know why this is happening ? |
08-15-2015, 01:04 PM | #2 (permalink) |
Mcpx cuts power at 70% throttle?!
Hi.
08-15-2015, 05:29 PM | #3 (permalink) |
How old is the motor? Brushed or brushless?
. . I have to turn the music down while driving so I can see better. |
08-16-2015, 01:53 AM | #4 (permalink) |
Its about 2 years old, mcpx v2 standard brushed motor.
Do i need to replace the engine? |
08-16-2015, 05:28 AM | #5 (permalink) |
Check the battery wires on the 3-n-1 at the board and at the battery plug. There have been problems in the past with the wire fraying and only a few strands making the connection at the solder joint. Peel off the white silicone encapsulating the wires at the board and remove the shrink tubing at the plug to inspect. The cause may just be wear and tear from plugging and unplugging the battery, shoddy soldering by the factory or a combination of both..
Team Newb pilot All my helis and quads were lost in a tragic boating accident. |
08-22-2015, 03:08 PM | #6 (permalink) |
Why is my posts deleted?
08-22-2015, 04:48 PM | #7 (permalink) |
I can see your original post, and the one you wrote about the age of the motor.
Did you write more??
08-22-2015, 04:51 PM | #8 (permalink) |
Hi.
I wrote that the wiring is OK. I resoldered the wiring from the 3n1 to battery connector just to make sure that wasnt the problem. Should I consider buying a new motor, or mainboard? |
08-22-2015, 04:55 PM | #9 (permalink) |
