Old 07-01-2015, 05:31 PM   #61 (permalink)
Originally Posted by OnTheSnap View Post
MSH is working on beefing up the skids a bit. Current ones are ok, but harder landings can pop them instead of bounce.
Just thinking out loud...maybe they could get the folks who did gorilla gear to make some up. They really held up well.
aterren is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 05:50 PM   #62 (permalink)
They tried it in the early V1 development and the plastic used in gorilla gear is not strong enough to support a 700 class machine.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 06:13 PM   #63 (permalink)
What about an internal spring steel frame with the gorilla gear molded over, it's possible it could bend if hit hard enough but you could bend them back
Also how about some love for the Protos and it's little sister the mini-p??? I'd love to see those updated as well If so ask for better swashes too please
jbaum81 is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 06:17 PM   #64 (permalink)
Interesting idea!
And, uh what do you expect MSH to announce? Everything at once?
Old 07-01-2015, 06:43 PM   #65 (permalink)
OTS your such a tease lol..
Any info on final drive ratios? I want to select an Xnova to go with this and want to start gathering up the goodies. I'm thinking just a 12s light weight setup 700 recommendations yet?
Old 07-01-2015, 06:55 PM   #66 (permalink)
https://www.helifreak.com/showpost.p...&postcount=241
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 06:58 PM   #67 (permalink)
I probably wouldn't use light to describe a max. :-D Prob about where your G700C is. Depending on setup
If you want ultra light loading, get the cheap 800 upgrade kit and go with >750mm blades.
Main gear is 190T. Pinions are 18-22.
If you go with a 800MX/4525 with a 120A ESC you are probably as light as you can get. MKS x6 servos I hear are light?
Old 07-01-2015, 09:18 PM   #68 (permalink)
Oh so it's made of Osmium? I'm not seeing it, that big o' chunk of transmission sitting atop my goblin with it's big heavy canopy and boom weigh in close to what a petite (looking) Max V2 will?
Edit: I'll admit, I like the loading light and floaty, not a deal breaker.. Any idea's if I'll be able to swing my rail 716's on it stock?
Old 07-01-2015, 09:27 PM   #69 (permalink)
Alex owns both, I'd bet he is speaking the truth on the weight, although I agree. Intuitively I don't see how it couldn't be a bunch lighter than my Goblin.
Eury is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 09:27 PM   #70 (permalink)
When you see one in person, you will not call it petite. Looks a lot larger vs a g700c. The bottom frame is probably what triggers your brain to think that. But the bottom frame is heavy duty to protect your packs.
Yes. Swings 716's with 115 tail blades no problem.
Old 07-01-2015, 09:29 PM   #71 (permalink)
Conveniently you own both. Would a side-by-side help them see it?
Old 07-01-2015, 09:30 PM   #72 (permalink)
It's a capable full blown 800 machine. Keep that in mind when calling it petite.
Old 07-01-2015, 09:33 PM   #73 (permalink)
I don't think so.
Old 07-01-2015, 09:36 PM   #74 (permalink)
I've always wanted one might wait for the V3. Lol
n8rloves2fly is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 09:40 PM   #75 (permalink)
What do you want changed? Not understanding the comment. (-:
Old 07-01-2015, 09:50 PM   #76 (permalink)
Will this be on display at IRCHA?
Llama v3, EXI 450 Pro, Nano CPX, 130X, Protos 500, various planks
Futaba 8FGH, Spektrum DX7s
18-channel scratch built tugboat controlled by modified Futaba Tx
R/C junkie for the past 25 years and counting...
kingmeow is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 10:02 PM   #77 (permalink)
I'm bringing my tools. You might have to help me put one of these together at IRCHA.
BL Nano CPX, 130x, Align 450 Pro, Gaui X3, Goblin 500, Protos Max V2
Spektrum Dx7se, Dx9 Black
j32driver is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 10:45 PM   #78 (permalink)
I'll have a couple with me at IRCHA.
Old 07-02-2015, 05:29 AM   #79 (permalink)
It has been moved to the main shaft instead of the motor shaft
So this has the one way on the main where it should be?
One reason I stayed clear of the Mini Protos was becasue of the one way pinions. That and 1.5mm allen heads in the frame.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 07-02-2015, 06:07 AM   #80 (permalink)
The 1.5mm allens on the frame are fine, I have never striped one but twice the head has broken off from overtightening. If you buy high quality tools no screw is an issue.
dedados is offline        Reply With Quote Quick reply to this message
