Go Back   HeliFreak > R/C Helicopters > New Member Introductions
New Member Introductions If you are new to HF, please tell us a little bit about yourself. What Helis do you fly? You will find our community very friendly, why not break the ice and introduce yourself.
Old 08-02-2012, 10:09 PM   #1
David Luko
Default Heli Virgin
Picked myself up a 450 sport v3 electric heli, and I have been flying a novus 250 heli max before I picked this hellicopter up.Started watching the videos on setting up everything, and tonight I was unable to access the videos for some reason.Does anybody have a run through set up for beginners I can us for my spektrum dx6i remote. If so that would be awesome. I have the pitch curve and throttle curve set up everything else got lost in translation. Thanks, Luko
David Luko is offline        Reply With Quote
Old 08-02-2012, 10:24 PM   #2
Wolfpackin
Welcome to HeliFreak.
Pitch and Throttle curves are really the only universal settings, most of the rest need to be tailored to your particular mechanical setup and personal preferences.
Where in CO are you?
Wow, that's the second time I've asked that question today.
...That's never happened before.
Try clearing all cookies and try the Finless videos again.
If that doesn't work, let me know and I'll ask Will and the other Support members about your video problems.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is online now        Reply With Quote
Old 08-02-2012, 10:33 PM   #3
geckgo
The finless bob forum has good videos and instructions. The DX6i isn't tough to set up, but the manual for it sucks. Basically, I set my travel endpoints first, for maximum throw without binding, then D/R, then my Pit/Thr curves last, make sure the gyro is set to 50% before setting up the tail rotor. Also put some standard curves in while doing testing. I like to do 0, 50, 50, 50, 100 to make sure that my centers are centered while setting up.
Welcome to the forum and good luck with the 450. I'm still a noob and my 450 can be intimidating to work on and fly.
Devo 10 with Deviation Firmware (One to rule them all!).
V120D02S V1 - Xtreme frame&landing gear, WK-metal head, KDBB Blades | V120D02S V2 - Stock | Blade 450-3D - Stock | mSRX - mcpx tailboom.
geckgo is offline        Reply With Quote
Old 08-02-2012, 10:48 PM   #4
Slyster
Here are some great videos for how to set up the DX6i for a CP heli. They are show with a Blade 400 but it's not different for any 450 other than the odd fact that the swash plate goes DOWN for positive pitch on the blade 400... so don't confuse that.. the Trex 450 goes up.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
