Hurricane 550 Discussion and support of the Gaui Hurricane 550 |
06-27-2007, 08:08 AM | #21 (permalink) |
Hi Tom, good news. Now stop teasing me
Maurice |
06-27-2007, 12:06 PM | #22 (permalink) |
Hello Tom,
Can the new Gaui motors still use the stock 50A Gaui ESC, or will they require a higher AMP ESC? I am interested in their efficiency/power compared to the stock one. Not that I fly any 3D yet (I use 2x 3s 18C 2200mah Extreme Power lipos BTW), but if I burn up my stock motor, I would probably buy one of these new ones. Looking forward to your report! Mark |
06-28-2007, 08:50 PM | #24 (permalink) |
Come on then Tom
Let us know how the new motor Flies!!!! we eagerly await your report! |
06-28-2007, 09:19 PM | #25 (permalink) |
If you want to see how it flies check out the vids on www.hurricane550.com
ReadyHeli has been testing the new 1500W 1100Kv Gaui motor for a few weeks.
www.RevCo-RC.com We make stuff that works like its supposed to! |
06-29-2007, 01:53 AM | #26 (permalink) |
I'm still to build mine yet but considering power options, I'm probably going to use the 600+ motor out of my Swift together with the CC P60 this has been using for 18 months. I've had a look at battery options as I have two 3300 3S packs as well as 2 2200 3S packs but the weight of the two 3300's combined is 560g and I have two 3700 6S packs used on the Swift that weigh 564g so using the 6S pack makes more sense just for an extra 4g! Just a bit of modification of the battery tray, i.e. saw the old one off and make a new one!
Steve H Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG |
07-02-2007, 09:57 AM | #27 (permalink) |
Pic to show chassis mod made to my Hurricane to allow use of 2x 3S3300 packs. Grey plastic plate is some scrap plastic I had... velcro fixes the pack in place.
Kev |
07-08-2007, 07:03 AM | #28 (permalink) |
Just wondering if the Align 75 amp ESC will do the job or is is junk?
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500 |
07-08-2007, 07:25 AM | #29 (permalink) |
Im using the Align 75 with the Stock GAUI motor and it seems to work well. I use it in Governor mode with High timing.
I cant compare it to the original GAUI ESC because my original Hurricane was built with a CC80 (which smoked after only a few flights). Kev |
07-08-2007, 07:34 AM | #30 (permalink) |
Hi Skarross,
Any idea why your cc80 smoked? I'm setting up one now with the stock Gaui motor. (Z30 will be ordered soon) I'm not sure about the PWM rate setting for this motor (13 kHz ??) thanks Maurice |
07-08-2007, 09:37 AM | #31 (permalink) |
13kHz is fine on just about everything...even Kontronic motors although Kontronic will tell you diffrently.
07-08-2007, 09:59 AM | #32 (permalink) |
Neu 1907/1.5Y & 8S
OK, I have a combo I really like.
Motor: Neu 1907/1.5Y (966 kV) Pinion and gear: Stock 14T and 61T as a primary w/RevCo 61T Main gear. ESC: Castle Phoenix 45HV Throttle curves: 70% (Phoenix set to Governor High, gain set to High (83)) HEAD SPEED: ~1900 Pack size: 2 x 4S TP 2200's Blade size: Mikado 500mm Carbon Flight times, and style of flying: 9-10min, sport Performance: Seems peppy to me, but I'm still learning. In order to get the control arms to fit around the motor, I had to change out the mounting bolt for a slightly longer one (3x15mm) and shim it with a couple of M3 washers per side. It would seem that this has resulted in more straight linkages anyway. I'd probably do this even if I didn't have the wider motor. I went 8S on the thinking that I wanted more flying time -- thinking I could gear down. Plus once you've made the jump to HV at 6 cells, what's two more? I tried to order the complete RevCo set, but somehow only ordered the pinions and a couple of 61T main gears. Cleverly I omitted the 68T primary that would make the pinions useful. By the time I realized my mistake, the 68T gears were gone. Sigh. I think this motor has more to give than the 14 tooth pinion can ask. The heli hovers at about 330 watts. This is my first post ever, so as soon as I figure out how to post pictures, I'll post my EagleTree graphs of the 14T setup. Today's project is 15T. Its not clear to me how the CC 45/HV sets head speed. One theory I have about the 14 T is that 1900 RPM is close to the absolute limit for the gearing. Given that, the head speed decays as the voltage drops, regardless of the governor. It would seem that a better setup would be to gear the target head speed for ~70-80% of the max and then regulate down so that any (reasonable) voltage drop can be absorbed. Hence the 15T... |
07-08-2007, 10:10 AM | #33 (permalink) |
Team Taco VP
Sounds cool..... keep up the testing and let us know the final results!
Thanks, Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
07-08-2007, 10:32 AM | #34 (permalink) |
Its good to know the 19xx motor fit. They are very efficient and powerful.
07-12-2007, 04:40 PM | #35 (permalink) |
Power Systems That Work...
Firstly thanks to Bob for all the videos they are great !
I have a stock motor and Castle Creations 80AMP Phoenix ESC. I am running a separate RX pack. I flew my heli with 2 x United Hobby Hextronix 11.1V 3S 2200 mah 20-30C packs...they got very hot and showed signs of swelling after the flight also only got 4 min. I have put back 1600mah which is almost 80%. They are not new and have been cycled many times in my Trex 450. I am looking for an economical solution to get me longer flight times, I am not flying radical (3D YET Smile ! everybody says, EVO 6s but then I could have just gone Trex600..I went Hurricane to keep costs down. Also if I stick to 2 x 3s I can at least use the charger I have. I am also considering the Century 600 Upgrade and the Revco 68 and 23 gears. I see the century motor runs max amps 55 but what is its constant draw ? back on the budget thing...United Hobbies now has 3s 4100mah, 15C packs for $64, I am thinking to try 2 of these...do you think they will cut it. If they are rated correctly they should be able to deliver 61amps constant but I suspect they are over rated so probably more like 45-60amp max ..would this be enough for the Century 600 ? I can also get some local packs that guys say are not bad and make up my own 4000mah 6s 4p 20C (2 x 3s 2000mah 20C parallel) x 2 hooked in series = 4000mah, 22.2V, 20C - for a total cost of $200.00. and able to use these single 2000mah packs in my 450 too ? Then my other thought is if I splurge on 2 x EVO 4900 25c 3s packs I could later use these in a Trex600...which seams to be the inevitable move in this costly addiction of electric helis ! I would like to get more power and min 7-8min flights on my Hurricane. EDITED - Batteries aside ! I just got back from flying my 550 again...my slightly bulging lipos worked fine again but I plan on disposing of them now. I now see why everyone is upgrading motors...the stock motor is great for basic flying but it lacks guts, as soon as you start pushing the heli a little it just bogs down! So I have decided for my flying to now progress I have to upgrade the motor pinion and gear....should I go Gaui Silver Bullet or Century 600 ? Would appreciate thoughts and advice on the motor choice and battery choice - Thanks. |
07-13-2007, 03:56 AM | #36 (permalink) |
nigel1, I have been using 2 x 3s 4000mAh 10C packs ($55 at TrueRC). My flying style is mainly sport, starting on loops etc now. I run the Zpower 1470kV Z20, stock blades and a 2000rpm headspeed. I get 9:20 on my timer, which allows me to stop just before they heat up. 10:00 minutes and they get quite hot. About 40 flights on them now with no problems.
Those packs from United Hobbies sound good, and I would like to try them myself. About 150g heavier but much better capacity. I find the hurricane balances well with the packs I am using. And you can mount these bigger packs easily (my picture is here https://www.helifreak.com/viewtopic.php?t=42447). You just need to move the ESC back on the frame as the wider packs won't allow it to mount at the front. I don't have a logger but the packs I use seem to work for me. Hope this helps! |
07-13-2007, 08:44 AM | #37 (permalink) |
Thanks for your feedback Ian. I looked at the truerc packs too...I just figured they may not deliver enough juice. I see you run the Z20 motor with these..now you have thrown me a curved ball...I have to choose motors...your set up would give me the flight time I want and the battery price point I want...but how the does the heli fly, if you could have more power would you want it ? How aggressively do you fly for the 9 min ?
Do you need to upgrade the pinion and gear with this motor ? My options are now : Z20 1470, Z30-1100, New Gaui or Century 600 and I think battery wise I am going to go trueRc or hextronic...the price point is just too good and I am hooked on the size of the Hurricane. |
07-13-2007, 02:56 PM | #38 (permalink) |
Interesting review of motors includ Neu 1907 & Century 6
07-13-2007, 11:29 PM | #39 (permalink) |
nigel1, I am just starting on doing loops, and more aerobatics will follow. I notice straight away this is taxing the batteries a bit more. I will monitor the batteries over the next few flights and let you know. I'm guessing the united hobbies batteries may be better for more aggressive flying. I think my setup has enough power for my current skills.
I have to say on a fresh set of batteries the full power climbout is much better than my Trex 450 could manage. But never having experienced a high power setup I can't compare to anything else. Watch how the power/weight goes, the z30 is a fair bit heavier than the z20. I'm at 2.3kg already. I have a very early frame (very flexible) with matching gears and there has never been a problem with stripping gears. I will upgrade these soon though. |
07-14-2007, 01:17 PM | #40 (permalink) | |
