Register | FAQ | PM | Events | Groups | Blogs | Calendar |
MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
04-02-2014, 02:56 PM | #1 (permalink) |
Brain Gov Settings?
Hi,
On the governor setup tab, what should I put for the gear ratio, sensing divisor and speed1/speed2? What's the range of normal head speeds? 2600-3500? Where should I start out? Thank you! |
04-02-2014, 05:24 PM | #2 (permalink) |
Also, my blades seem to be spinning the wrong way. They spin counter clockwise. When I switch two of the motor wires the motor spins, but then does not spin the blades.
Do I have something backwards? |
04-02-2014, 05:28 PM | #3 (permalink) | |
As for the gov setup, what sensor, ESC and motor are you using ? the settings depend on that.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE "Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615 FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F |
04-02-2014, 05:58 PM | #4 (permalink) | |
I've got the hobbywing rpm, yge 60, and scorpion 6s. All stock units that ship with the 6s kit except the rpm meter...that was ordered separate. It's the 6s stretched version. |
04-03-2014, 05:05 AM | #5 (permalink) |
Since this is a new kit, then you don't even need the hobbywing rpm sensor at all as the YGE60 in the latest kits has an external phase output.
You need this card : http://www.hobbyking.com/hobbyking/s...ming_Card.html (or the 5 times more expensive YGE card) to use it though. The card also makes it much easier to setup the YGE. Check out this thread for how to set the YGE up for external governor : https://www.helifreak.com/showthread.php?t=485879
04-03-2014, 07:21 PM | #6 (permalink) | |
Thanks for the info! I'd like to run the brain gov though. Can you give me some pointers of where to start from that angle? |
04-03-2014, 07:30 PM | #7 (permalink) |
Brain Gov Settings?
You'll use the brain gov, but use the rpm output from the yge rather than the hobby wing sensor. Default gov setting worked for me. If I tried anything like increasing the gain, etc, I got oscillations and overspeeding. I have the exact setup you have.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis Thanks to Oxy Heli and MSH-Direct.com Former Username: Code3Medic |
Tags |
gear ratio, head speed, mini protos |
