Old 02-20-2012, 04:12 PM   #161 (permalink)
Looking at those pics, do you actually need a new swash to use the rear A/R bracket? Or are they just going to replace the ball in the rear socket with one that has a pin attached?
Andrew73 is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 04:18 PM   #162 (permalink)
Looks like you can choose on the frame where to mount it and yup looks like same swash to me
Link to photos laid out
https://www.helifreak.com/showpost.p...&postcount=157
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 04:30 PM   #163 (permalink)
Good point. I wonder if they will offer just the ball and pin.
Hello, my name is Pakk and I'm addicted to heli's.
pakk is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 05:45 PM   #164 (permalink)
I just noticed that the frame appears to come with 2 styles of servo mounting stand offs. If you look at the flipped servos picture, the standoffs are noticeably longer to allow clearance for the bigger motors.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 05:50 PM   #165 (permalink)
None of those pictures show any detail on the rear of the swash. I bet they changed it a little for the rear pin, it's probably got a little hole inset, like it does on the side, to glue your pin into.
Tasteles is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 05:51 PM   #166 (permalink)
It was instock and available this morning.
+1 it was when I looked (if it had been tomorrow [payday] I would have pressed buy) then was not 10 mins later
From the images the rear a/r pin looks an aluminium extension to the swash; not an extended ball screw and pin, also the spot on the side of the swash is a mouthing point for a/r pin or is the a/r pin removed as using the rear guide. I think they may have put some real thought into people upgrading; i.e. I can only afford the swash this month so I’ll get that and can use it right away (the a/r pin on my old swash is wearing away anyway), then next mouth I can get the main bearing hub (so I don’t have to think about the a/r pin wearing anymore, plus I get more control).
Yep I think they have been reading the HeliFreak forums very carefully on this!
First address a big weak point, the tail mount (hopefully they have increased the thickness/strength of the rear sides as well, if not you could still use RKH mount and sides or the RKH mount and Dylan’s sides), then correct a control and wear issue with the rear a/r, next reduce vibrations with dampers (I kind of think that RDLohr's mount would be the better solution, but have not had a vibe issue so not had to deal with that), then there is the reversed servo mounts (I missed that thread until people started speculating over what they hoped mh would do with the X frame); there are obvious advantages to the reversed servos and as for the straight servo links, all three servo’s are mounted at about the same height, just get two extra sets of servo links and just use the elevator links if you don’t want to modify servo links, of course it would be good if there was a straight servo link set available ( funny that people was trying to put bends into the elevator link at first to overcome the weak swash ball on the stock swash and now there is the need for all straight servo links ).
I think mh is on to a winner with these updates, I know I’m sold! now I just want to get my hands on them
T-rex 500ESP - DFC (Scorpion 3026-1900Kv, 6s, CC Ice 100A, AR7200BX, SAB430), 130 X (EOX1101), mCP X BL, Nano CPX,
mCP X (XP-12a, HP05s, Dual Tail), mSR X, mSR, DX8
salsaketchup is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 06:09 PM   #167 (permalink)
Did anyone actually win the "beta" frames?
Would have thought the purpose was to get some analysis....seems they only wanted to generate hype.
Amp
Ampdraw is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 06:33 PM   #168 (permalink)
Amp
Would also like to know
Sent from my thumbz
Cartrixx is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 06:41 PM   #169 (permalink)
i also noticed this.. it looks like the "reverse" option you have to use a straight servo arm to attatch all 3 servos to the swash.. pretty cool
ToyMchn is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 07:14 PM   #170 (permalink)
hmmm i was just about to order a rakon frame but now I am contemplating waiting on this frame hmmmmm decisions...
Originally Posted by Ernie Mccracken View Post
My worst 10:
10) A grown man flying one around in a park is like driving a windowless van with a "free candy" sign on it. Chris Hansen immediately puts you on watch.
ballisticevo is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 07:16 PM   #171 (permalink)
Does anyone know when they will be back in stock?
fr34k is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 09:54 PM   #172 (permalink)
I'm guessing no one was able to place an order?
Old 02-20-2012, 11:13 PM   #173 (permalink)
Same crappy rear.
infamousnation is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 02:46 AM   #174 (permalink)
Precision CNC Steel Ball w/Pin Sleeve set (for MH-MCPX012/112/X)
Model #: MH-MCPX012AS
http://www.microheli.com/store/produ...roducts_id/697
Lynx Heli Innovations | HD Helicopters
ZyBeR is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 03:03 AM   #175 (permalink)
excellent... I guess that pic of the frame with the swash in must be with a prototype swash, because it sure looks like an aluminium extension in that pic. That had me slightly worried because it would have meant the pin STILL wash; in line with the balls, and instead of interaction when pulling elevator, you'd have interaction with aileron instead.
That listing however shows that it's an extension, which will be perfect! plus I can keep my old swash... good job microheli!
Now I just need stock of everything! To upgrade existing frame and swash, I see that the following would be required:
Precision CNC Steel Ball w/Pin Sleeve set $2.99
Delrin Main Board Mount w/Damper $5.99
Aluminum Main Bearing Hub (for MH-MCPX005/B/X) $19.99
Aluminum Servo Mount set (for MH-MCPX005FX) $7.99
Aluminum 3mm Tail Boom Mount $7.99
so that's (excluding the swash pin, since you wouldn't get that with the frame anyway) $41.96
So really, you'd be better off buying the whole frame for $54.99 as I imagine you can sell the old one for a good $20... that main bearing hub is EXPENSIVE lol.
I'm in though - really like the features, and unlike a couple of others here I've had no problems with the tail frame design.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 03:13 AM   #176 (permalink)
20 bucks should be what MH sells these things for. Bet they would sell way more.
litehawkdown is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 04:57 AM   #177 (permalink)
It doesn't look like they can keep up with stock selling them at $50.
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 08:05 AM   #178 (permalink)
Originally Posted by infamousnation View Post
Same crappy rear.
I'm sure that Dylan is already cutting MH style braces out of "real" carbon fiber.
And he'll probably be able to keep up with demand better.
And Dylan, if you're reading this...have you ever tried this stuff:
http://dragonplate.com/ecart/categories.asp?cID=27
I know its expensive, but I just wondered if its "all that".
boltsinneck is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 08:08 AM   #179 (permalink)
They're still busy making the THREE that they promised to give away in here!
Old 02-21-2012, 08:42 AM   #180 (permalink)
Originally Posted by salsaketchup View Post
Pleased to see the a/r guide at the rear I'm sold as well, just hope it is not delayed more
I'm new to the mCPX crowd. A small question, what's the advantage of having the A/R guide in the rear of the frame?
-Don T
Spektrum: DX7s, Blade: mSRX, mCPX, 130X, 180CFX
$$$ + Heli Hobby =
Dont155 is offline        Reply With Quote Quick reply to this message
