Old 03-05-2014, 12:48 PM   #1 (permalink)
Default Please help
Ok I tried looking for YouTube videos and searched google but everything I found didn't help much so I'm hoping someone can help here.
I'm trying to charge and or balance my nano cpx batteries on my thunder ac680. My first problem is I keep getting "connection break" on the screen. I've checked all connections over and over and plugged and unplugged them several times. Pretty soon HULK SMASH...
Next when I get that fixed could someone tell me the rates for charging and balancing?
My lectron batteries are 3.7 180 mah 45c with a 2c charge rate.
So would I charge them at .3amp 3.7 v?
And so far my balance screen will only go as low as 7.4v @ 2s why will it not allow me to balance at 3.7? This is driving me crazy....this manual sucks.
I don't understand this balance screen...
Edit: I've figured out the connection break. Apparently I have to charge 3 at the same time with this adapter.
TrAuMaChAsER is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 12:55 PM   #2 (permalink)
Default Please help
Ok let me just make this easy...how do I work the ac680 with nano cpx batteries lol
I plan to charge 3 at 1.4 amps at 3.7v is that right?
Anyone have a link that can help me? I can't find one.
Old 03-05-2014, 12:58 PM   #3 (permalink)
You do NOT use balance charge on a 3.7v battery...there is only one cell so it's auto-balanced
Use Lipo charge 1S 3.7v @ .2 per battery
Old 03-05-2014, 01:11 PM   #4 (permalink)
Default Please help
So if I'm charging 3 do I increase voltage?
So I could charge at .8 @ 11.1 volts?
Old 03-05-2014, 01:13 PM   #5 (permalink)
is that a series charging cable? it kinda looks like it from the photo (has a balance tap).
Easier to answer questions once we determine if that is parallel or series.
I had a series one like that, so I cut it apart and made it parallel
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 01:14 PM   #6 (permalink)
3.7v batteries are charged at 3.7v...
To charge more than one, add more amps
Like I said...3.7v @ .2 per battery
The slower you charge, the longer the battery will last
And you have a history of beating your batteries to death so heed well or spend $$
Old 03-05-2014, 01:15 PM   #7 (permalink)
Default Please help
The charger will not let me charge at 3.7 v only 11.1
This is why it's driving me crazy....
Old 03-05-2014, 01:16 PM   #8 (permalink)
Default Please help
Yes it has a balance tap
Old 03-05-2014, 01:16 PM   #9 (permalink)
It's series I think, so you charge it like a single 3S battery.
And if it's series, it wont work if only one or two cells are plugged in. (now you know why I made mine parallel).
Ok, i see your reply. Charge it like a 3cell battery, with 540mah rate = 1C... Is that right????? (180mah X3)
Look up how to series charge. I can't remember if you add the mah or not...
Old 03-05-2014, 01:18 PM   #10 (permalink)
Default Please help
Yeah it won't let me charge just one battery....I have to charge at least 3. Do you have a link to a cable that let's me charge just 1?
Old 03-05-2014, 01:19 PM   #11 (permalink)
yeah, get your soldering iron out and change that one over
No seriously, I'll find you one.
Hmm out of stock:
http://www.buddyrc.com/micro-paraboard-pico-ph2.html
I'll find a link on that place in Seattle. Here it is:
http://www.progressiverc.com/safe-pa...cp-x-pico.html
(WAHH out of stock...)
Old 03-05-2014, 01:19 PM   #12 (permalink)
It's a series cable, not parallel.
Charge as Balance Charge, 3S. I'd use 0.2A, that would be just a touch over 1C (0.2A/0.18Ah= 1.1C).
If you choose to charge them faster, you can, I'd do 0.3 or 0.4A. 0.4A would be 2.2C. But slower is better (0.2A).
Series cables are OK, but have their drawbacks, like only being able to charge 3 at a time. A parallel cable in your next parts order might make things simpler.
Old 03-05-2014, 01:21 PM   #13 (permalink)
Default Please help
So charge at .6 @ 11.1?
Is this the best way to charge for these batteries? I was under the impression I should be balancing them with all 3 connected. The insert with the batteries tells to balance before use that's why I'm so confused.
Old 03-05-2014, 01:22 PM   #14 (permalink)
Default Please help
Ok I got it now......damn foreign directions....
Old 03-05-2014, 01:31 PM   #15 (permalink)
LOL...
Makes no sense to even consider a series cable to charge 1S batteries, but oh well...
Other threads go on and on about different 12v to 120v inverters to power AC/DC chargers in a car while driving down the highway drinking coffee with one hand and texting with the other...and looking for a place to stop and fly
No wonder chargers have fail-safe features built into them
But I do agree...your next purchase really should be a parallel charging board or harness
This one will not only do your nano's, but will do mCPX batteries too if you decide to step up
http://www.ebay.com/itm/Common-Sense...item1e7ce68a71
Old 03-05-2014, 01:32 PM   #16 (permalink)
Default Please help
I'm still supper confused because it won't let me charge at 3.7 volts only 11.1
Plus all the different replies have me confused a little to. It seems once I figure it out the charger won't let me do it.
Would charging at .2 amp and 11.1 volts be ok or does it have to be 3.7? I thought this was the correct cable for this but obviously I was wrong....
Old 03-05-2014, 01:33 PM   #17 (permalink)
It will work...
Use 11.1v at .3 amps
Old 03-05-2014, 01:34 PM   #18 (permalink)
Default Please help
LOL...
Common Sense RC Parallel Charging Board for Blade MCP x and XCX MSR Batteries | eBay
Couldn't I just not plug in the balancer cable? That would pretty much be the same as a parallel cable right?
Old 03-05-2014, 01:35 PM   #19 (permalink)
No, you have a series board...
It needs 11.1v so it can separate into 3 - 3.7v taps
Old 03-05-2014, 01:37 PM   #20 (permalink)
Default Please help
Damn it all to hell
