Old 06-17-2010, 11:54 AM   #1261 (permalink)
Woody, as far as the floats, they fit REALLY tight on the carbon fiber tube I bought. I had a hard time getting them on. I used some rubbing alcohol as lubrication to get them on.
I suppose after some time they might loosen up and start to slip. If that happens I will just buy some new ones, or put a drop of glue on the ends.
I take off and land from asphalt so they are getting flat spots on the bottom, but that is no problem.
DT 520, 4025-1100, Ice 100, WR Hercules, DS610's, Robird/MKS DS-760
Blade 400, Blade 180CFX, Blade 130X
snooker43 is offline        Reply With Quote Quick reply to this message
Old 06-17-2010, 02:03 PM   #1262 (permalink)
Kyle
warriorzman is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 09:33 AM   #1263 (permalink)
Originally Posted by warriorzman View Post
Very nice, do you have your blades rotaring counter clock from the rest of us? it looks so by looking at your tail blades... as they look like they're spining the oposite direction as ours...
JoseReyes is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 11:22 AM   #1264 (permalink)
I didn't even notice that, how does he fly with them on backwards?
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 11:45 AM   #1265 (permalink)
Twist the belt the other way. But what about 'designed in' prop/rotor wash?
Blade 400, HS65's on cyclic, GY520, Fut 3157 on tail, CC ICE Lite 50, Align 325 Pro blades, TRex 500 struts
afterimages is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 12:36 PM   #1266 (permalink)
heres mine w 65mgs on cyclic and a cc 10 amp bec ,stock motor and gyro tail servo . It has trex 400 canopy mounts and a trex 400 canopy painted my favorite color. I
really should takeoff my training gear
Darkseacret is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 01:11 PM   #1267 (permalink)
even if you twist the belt they are still on backwards..they need to spin counterclockwise and leading edge wil be the fat side..the bird will stil fly with blades on backwards,,just not that good.
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote Quick reply to this message
Old 06-20-2010, 01:07 PM   #1268 (permalink)
Actually if you flip the belt the other way, and put the blades in backwards, it works pretty good... but if you try to do any flying with it, you get tail problems. I flew a few flights like that before I figure out what the problem was. It may be possible to get it to work perfectly like that - but yeah, the Blade is designed to have the leading edge of the blade go up at the front, and down in the back, which is the opposite on the picture.
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 06-25-2010, 05:52 PM   #1269 (permalink)
Default Latest build,,easiest one so far,,no mods and no cutting.
Old 06-25-2010, 06:31 PM   #1270 (permalink)
what did you use?
is that the blade400 in there, and what brand of fuse did you use?
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote Quick reply to this message
Old 06-26-2010, 07:28 AM   #1271 (permalink)
Originally Posted by fast400 View Post
what did you use?
Hey Larry,this fuse came from Hobbyking,,i was buying some batts and i noticed they started selling canopies and fuselages. i saw this fuse for like $45,,so i said wow ill give it a try.its made by SHENZHEN KDS MODEL,.it is a little thinner than the name brand stuff but it was totally worth the money and i couldnt believe how well the 400 fit in there. its like this fuse was made for the 400 i didnt even have to build a batt tray i can put the batt on the bird like normal. so ya thats my 400 with Sonix Tail and Head.
this fuse came with good directions the tail fin was all put together allready and even came with skid stops..i was even surprised how good the magnets are holding on the front. well worth every penny.i didnt cut one thing on this build,the tail was def made for sonix,it screwed right in..
the 450 canopy they are selling for $7 is well worth it too..im amazed,,pretty good quality and a really good paint job.
Old 06-26-2010, 01:35 PM   #1272 (permalink)
So I gave my blade a bit of "orientation" paint.. I got used to the stock yellow canopies and white blades.. havnt got a chance to fly it yet but, I think its going to help a ton.
verticalization is offline        Reply With Quote Quick reply to this message
Old 06-27-2010, 05:07 PM   #1273 (permalink)
Originally Posted by whoanelly View Post
Nice looking New Fuselage nelly.
Bryan AMA# 982814
"No-Neck R/C"
Old 06-27-2010, 05:25 PM   #1274 (permalink)
Thanks Bryan,,Apprecite it.
Old 06-27-2010, 05:45 PM   #1275 (permalink)
How hard is it to see once in the air with the flat paint?
Bryan AMA# 982814
"No-Neck R/C"
Old 06-27-2010, 06:16 PM   #1276 (permalink)
Its good,,adding the fuse makes the bird so much bigger. But orientation was no problem. I'm happy with it.
Old 06-28-2010, 09:50 AM   #1277 (permalink)
I really like that color.
Do the blades show up as well in flight as in the picture?
Did you paint the underside of them too? About how wide and far apart are the stripes?
KBDD makes some florescent tail blades and paddles too that you might be interested in.
Woody_99 is offline        Reply With Quote Quick reply to this message
Old 06-28-2010, 11:16 AM   #1278 (permalink)
Thanks Woody
The blades do show up as well in flight, I left the underside white for a bit more orientation help when its far away/under the tree line.
The stripes are an inch apart, and one inch wide.
I may have to check out those KBDD paddles/tail blades, that would add the las touch of color to it
Old 06-30-2010, 07:22 AM   #1279 (permalink)
Here's my blade 400, I've finally got out of my crashing phase (this one anyway) and have had 12+ flights with FFF, flips, dives etc. etc. and its flipping fantastic.....
T-rex 500 ESP 3G
Blade 400
Blade MSR
ginger-air is offline        Reply With Quote Quick reply to this message
Old 06-30-2010, 02:52 PM   #1280 (permalink)
Good work..very nice..i also like the 3 guides on the boom. where did u come up with that 1 ?
Tags
e-flite
