Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
05-13-2012, 04:41 AM | #21 (permalink) | |
Now it doesn't specify what 'lower' RPM values are - which is not very nice of them... From the manual - 'To realize a smoother RPM control at lower RPM, the P- value [Default 50%] of the ESC is reduced below the point X (adjustable via PROGDISC).' |
05-13-2012, 04:49 AM | #22 (permalink) |
it can be adjusted if you feel the need but default is already adjusted for low rpm so set it back to default, you'll be ok running under 50% no problem
05-13-2012, 04:51 AM | #23 (permalink) |
Thank you Stolla. I will do that then...
Is there anything else I should know about mode 6? I'm running it with a Pyro 700-52. |
05-13-2012, 06:26 AM | #24 (permalink) |
no, only thing to keep in check is to make sure you have enough headroom, at the lower percentage of course no problem but at max you need to be sure, usually you may need one size pinion bigger keep in mind mode 6 shows lower rpm at same thr percentage than m4, doesn't matter they give same max so its only a tx thing
05-13-2012, 06:47 AM | #25 (permalink) |
Shouldn't be a problem then. I'm not planning to use high headspeeds.
I've also set the helijive spool up time to 16 or 20 seconds - This for the TDR. Would that be OK? |
05-13-2012, 11:05 PM | #28 (permalink) |
Don't worry it won't spin at default, however there is a jump in mode 6 on spoolup, nothing to be concerned about, it's normal and won't spin heli around.
05-13-2012, 11:41 PM | #29 (permalink) | |
I also have a Goblin and will like to have a startup point before I tach the heli. So can you please tell me What % you have your tx on each mode and what RPM's are you running beside the 2150?
SAB Goblin 700 Scorpion4525-520LE Helijive 120 VBar JR8917HV / 8900JR Goblin 500 Scorpion4525-1200 HW 120 VBar MKS HV9767 Logo 600. Pyro 700-45 VBar Control "No Crash , No Gain" |
