Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 09-14-2009, 11:14 PM   #1 (permalink)
Default Another GAUI 550 Frame Mod ( Battery Mod)
Well I'm still learning to fly but, thought I would show off this mod to my GAUI
I was running 2 Lipo packs but that was a real pain to change out battery's .... as many of you know..
Here was my solution..' ..
1. Custom built tray
2. Outrage 550 Canopy
3. Trex 600 ESP Canopy Mount Bolts
I plan to run a 3700mAh battery.. it does come it a bit nose heavy but,
I was running two 4400mAh battery's before..
Solution turned out well...
Here are some photos..
ID:	115268   Click image for larger version
ID:	115269   Click image for larger version
ID:	115270   Click image for larger version
ID:	115271   Click image for larger version
ID:	115273   Click image for larger version
helinewbee300 is offline        Reply With Quote Quick reply to this message
Old 09-14-2009, 11:49 PM   #2 (permalink)
nice looking mod there!! can't believe how good of a fit that is. so did you cut that tray yourself?
bobbybe is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 12:04 AM   #3 (permalink)
Yeah...
I'm a long time builder.. (Planes) about 99% of my part I cut on CNC ..
This was my first attempt at cutting CF worked out well...
Just got into Heli's this Year...
one thing I always thought about heli's was " Na.. dont want to get into it... nothing I can build or make .. you have to buy everything...."
well the GAUI .. could use some mod's for sure :-)
I replaced the landing gear with TREX 600 Gear.. So then it made the tail fin look super small, ( so i made a Wal-Mart cutting board tail fin )
then this battery Issue ..I still have a bit of space under the canopy..
This is the second canopy mod ( I cut up a TREX 600 canopy to fit 2 (4400) Lipos in before.. but that was over sized even after cutting it smaller.. ( here are some pics of that.. mod )
but I really like that Outrage 550 Canopy, Have to think of some pain scheme..
ID:	115289   Click image for larger version
Old 09-15-2009, 01:30 AM   #4 (permalink)
Very impressive Helinewbie - nice mod, would the battery fit with the standard canopy ?
Looks very professional
Mikej is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 08:17 AM   #5 (permalink)
Bro, that's sharp! I'd pay for that! Great work!
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 09:02 AM   #6 (permalink)
Nice work!
rstacy is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 09:23 AM   #7 (permalink)
Good choice to allow bigger batteries. Nice work.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 09:57 AM   #8 (permalink)
Default WOW..
WO.... I had not even though of using that canopy..
Looks like it will fit the.... battery touched at the very top..but does go over with no problem..
Could not do a complete fit as I replaced the canopy mounting bolts with (TREX 600) they are longer maybe .25" + .. so cannot open the canopy wide enough..
This is the stock ( Plastic Canopy) .. that I dont plan to use.. if anyone wants it .. they can have it for $4 + Shipping..
Old 09-15-2009, 10:17 AM   #9 (permalink)
Scott
You know I was looking around and found some people doing there own mod's to make it work.
If there is a interest by anyone send me a PM.
Old 09-15-2009, 10:21 AM   #10 (permalink)
Default Second look
Had to take a second look..
Here is what it looks like with the stock canopy..
its pulled up from the bottom.. maybe about 3/4 of an inch...
maybe if I had 2 ( 3S Lipos) and staggered them .. so one is high one is lower.. it would fit better..
ID:	115353   Click image for larger version
ID:	115354   Click image for larger version
Old 09-15-2009, 11:38 AM   #11 (permalink)
Nice mod...and work....now you need to make a new Horizontal fin......and get rid of that "Tiny" fin on the boom.....I use the trex 600 fin set.....it's cheap and you get both fins and mounting hardware for $9.95
Blade 500x , dx8
Two retired Gaui 550 hurricanes (Sold)
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 09-15-2009, 11:53 AM   #12 (permalink)
Bigger canopies are nice. Make real easy to see.
https://www.helifreak.com/showthread.php?t=113262
Old 09-15-2009, 03:02 PM   #13 (permalink)
That would have been nice to make but just had enough CF to make that Battery Tray...
I have a few other project in mind .. been hooked on this heli stuff now ..
:-) started with the GAUI 550 ..
Since then have added.. a 250 and 600 ..
I keep having to tell myself.. "Do I really need another Heli" .. I keep wanted to add a 450 ..
Old 09-15-2009, 11:24 PM   #14 (permalink)
The Outrage canopy is sweet! Looks like my two piece plastic halves will be used as parts cups.
vteknical is offline        Reply With Quote Quick reply to this message
Old 09-16-2009, 03:15 PM   #15 (permalink)
I took a chance with the Outrage Canopy.. but it worked out really nice, fits nice..
well after I replaced the Canopy Bolts
But cant wait to paint it.. ( to many project so little time)
Old 10-24-2009, 06:50 PM   #16 (permalink)
I had Luis make one of these for me. I just finished installing it. I was a little hesitant to cut the frame, but no worries, I cut it and I have to say, Luis' work is outstanding. The parts fit together perfectly! I did have to recut the battery strap slots, but that's no biggie because I use the stock Gaui straps.
The canopy, a Fusuno, fit perfectly with either my Turnigy or Hyperion 3300 batteries attached. I should clarify "perfectly". Normally, I would put the upward facing arm on the skids toward the bottom. It made installing the canopy much quicker (Jerrymac suggested that when I first got my Hurricane). Now, it's in the normal position, but the canopy would need to be redrilled to fit. I opted instead to try one part velcro hook and one part Scotch fastener. The velcro hook would be on the canopy and the Scotch fastener would be on the normal mounting arm. Prior to doing that I wanted to make sure they would hold. God, did they hold. It was impossible to get the two to separate. I don't have the loop side of velcro handy so I just put another Scotch fastener on the canopy and tried that. Perfect. The Scotch Fastener is easy to lock and easy to remove.
All in all, a great addition! Thanks Luis!
Scott
PS Earlier in the thread I wrote I'd pay money for the mod... I did.. at $26 it was a great buy. A couple of dollars for M3 x 40mm bolts, washers, and Nylock nuts and it was done!
KBDD Team Pilot ):>
Old 11-12-2009, 02:16 PM   #17 (permalink)
Is Luis taking orders?
Because I'll have two.
alfy77 is offline        Reply With Quote Quick reply to this message
Old 11-12-2009, 04:28 PM   #18 (permalink)
Send him a PM. I'm sure he'll respond.
Scott
KBDD Team Pilot ):>
Old 11-12-2009, 05:00 PM   #19 (permalink)
Awesome, I'll get on to him.
As you can see I've been going to do the same thing to my 425 even got some CF board to do it but thanks to my time working on Seahawk composite panel repairs I get a very bad skin reaction to CF dust and I hadn't yet worked myself up for the itch. That and I doubt mine would have looked as good.
I planing on using Trex 500 canopies on mine with a adapter from Infinty Hobby made for the Protos.
http://www.infinity-hobby.com/main/p...oducts_id=4156
ID:	124150   Click image for larger version
Old 12-02-2009, 11:38 PM   #20 (permalink)
Default check post
Hey guys.
I just dont long on as much to helifeak as I did when I started..
Still learning but.. with winter here and trying not to spend money..
i'm staying away a bit :-)
but drop me a PM I'll get back to you ..
