Brand Specific Charger and Battery Support Brand Specific Charger and Battery Support |
02-08-2013, 03:21 PM | #1 (permalink) |
pl8 max amp setting for combined power supplies
Hello I have the pl8 and I am setting the power settings in the software I have two server supplies that are 12volts supplying 24 volts combined my question is do I
combine the max amps out of each supply. Each supply can supply 47 amps output max. Combined they are 94 amps so I would set the max amps at say 59 just below the pl8 max input of 60 or are the amps not combined and I would set the max amps at say 46. I dont want to start charging until the basic paremiters are set. Thanks Jim |
02-08-2013, 03:43 PM | #2 (permalink) |
Re: pl8 max amp setting for combined power supplies
No, still 47A total. When you wire things in series (as yours are, for 24 V),the voltage increases, the current does not.
When you wire things in parallel (not what you're doing here), the current increases, the voltage does not. Sent using Tapatalk.
Gaui X5, iKon, Edge 100, CC BEC Pro. Tarot 450 Pro FBL, Mini VBar, Ice Lite 50. BL mCP X, Nano QX, FrSky Taranis, iCharger 308Duo. |
02-08-2013, 04:05 PM | #3 (permalink) |
Thanks? I really thought I could have set it for the full 60 amp capacity and would have toasted my supplies. Jim
02-08-2013, 04:25 PM | #4 (permalink) |
Remember, the Powerlab only needs about 46 amps to completely max out charging 6s packs. Unless you are charge 7s, 8s, you won't need more current.
Revolectrix Ambassador - Charger Specialist Revolectrix.com 10% discount for Batteries GCAM16 |
02-08-2013, 05:44 PM | #5 (permalink) |
Doubt you would have toasted the power supplies. Sounds like you are using converted server power supplies. They have great protection and would have just shut down. That is why I love using them.
Sent from my DROID3 using Tapatalk 2
DX6i (with back light), Mini Titan E325 V1 converted FBL w/ SK-720, Mini Titan V1 converted FBL w/ ZYX-S, mCPx V2 converted BL with HK parts, Phoenix |
