Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 11-17-2013, 09:09 PM   #21 (permalink)
appreciate the link Gregor. It was not user error, oh no. I am perfect. thank you very much. It is my para board. I have a new one on order. one side is not getting power. I am NOW testing each pack before flight. Stick packs have both cells tested.
Thank you for the information and help.
Bubba
Goblin 700
Jeti DS-16
Bubbasanjohn is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 09:55 PM   #22 (permalink)
Originally Posted by Gregor99 View Post
Thanks for the update, glad you got it sorted. The cell that was deeply discharged will likely never be the same. However, it may still perform well for a long time to come. As the pack ages, expect that cell to go first.
On to the next step. What kind of parallel board is it? It might be worth to check the continutity betwee all the main lead connectors to the connectors that go into the charger. Some times traces get burned or fuses get blown. These are hard to see since most are inside the plastic housing.
I'm not saying this was your issue. But its another helpful device to prevent putting a discharged pack into the model. I've done it, got lucky and it ended well. I plan on getting some of these in my next HK order.
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
I would save the money. I am just in the habit of checking my packs every time I put a new one in with one of my meters. You can even check the pack voltage right before you put the canopy on if you want with it already hooked up. Cant go wrong that way.
Tachead is offline        Reply With Quote Quick reply to this message
Old 11-18-2013, 12:52 AM   #23 (permalink)
Definitely the superior way to approach this. The HK sliders provide an additional tool to help out.
Gregor99 is offline        Reply With Quote Quick reply to this message
Old 11-18-2013, 05:14 AM   #24 (permalink)
Default Re: Dead cell. Why?
I am working on checking every time as well. I have started strapping the pack down, THEN checking it. Should help avoid having 2 packs in front of me, checking the fresh one, then accidentally reinstalling the flown one
Sent using Tapatalk.
Old 11-18-2013, 07:51 PM   #25 (permalink)
Originally Posted by Bubbasanjohn View Post
I think my para board is bad
That has happened to me as well! The internal balance leads can't handle a lot of current (at least in my case), and I have 2 crappy batteries (turnigy ) that are always out of balance after flight. As soon as I plug them both on that board (yes the main leads first!) one of the connections in the parallel board fries.
I'm glad I have the soldering skills to fix it... But yes be careful with that! To check easily if the board is still fine, hook up just 1 battery and see if you get a balance error .
JR 11X, Trex250 DFC&SE, 450pro DFC&FBL, 550FBL, Goblin 700 HPS
Bimbo is offline        Reply With Quote Quick reply to this message
Old 11-18-2013, 08:19 PM   #26 (permalink)
Check at each location, however. It's possible for only certain ports to fail. If you only test port A, and assume they are all good, but port B has disconnected somehow, you might not find out until something bad happens.
Old 11-18-2013, 08:36 PM   #27 (permalink)
Very true.
Old 11-18-2013, 09:14 PM   #28 (permalink)
If you are going to use a parallel board, make sure to use one that has fuses on the main leads and the balance leads.
