Like Tree2Likes
Old 05-05-2014, 06:59 PM   #1 (permalink)
Default Torque Tube Shims
Stripping the front umbrella gears. Seen some folks have shimmed the umbrella gears in the TTs. Where to buy the shims?
FNFAL is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 05:19 AM   #2 (permalink)
Here for example: http://www.miracle-mart.com/store/in...oducts_id=4800
UFOking is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 07:54 AM   #3 (permalink)
Thanks, just what I was looking for. Wish I could find a domestic seller. When I search for "Tarot" I get a lot of junk fortune telling sites - strange to name a product line after such a cabalistic practice.
I also have some 10mm OD shims from a previous build I might try and use between the bearings in-lieu of those 6mm ID under the gear.
Old 05-06-2014, 07:57 PM   #4 (permalink)
I got mine from amain hobbies, they were for rc car diff shimming, same idea. Think I just typed the dimensions and shim in search box and they came up. Or maybe I search for a few hours, I forget
Bendero is offline        Reply With Quote Quick reply to this message
Old 05-07-2014, 01:13 AM   #5 (permalink)
Before I bought these shims, I used an old bearing that goes onto the umbrella gear, cut it apart, took out the inner part, cut it in half, sand it a bit till I got the right thickness and done.
gene2197 likes this.
Old 05-07-2014, 06:39 AM   #6 (permalink)
Thanks both. You guys did some work
Old 05-07-2014, 07:15 AM   #7 (permalink)
Why putting shim to front umbrella gears in the TT ?
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 05-07-2014, 07:22 AM   #8 (permalink)
Due to manufacturing tolerances, there may be more backlash (i.e. poorer gear meshing) between bevel gears than preferred. This can be of issue especially if higher power applications or more abusive tail movements are used, therefore causing teeth to jump and then in time even strip.
Shimming either/both gears can get the gear faces in better alignment. But if I were to do it all over again, me thinks I would go for a belt drive for at least the tail, as those bevels are the most prone to overloading.
But I'm hoping a move to the newer black gears and a tighter mesh will solve my problem.
Old 05-07-2014, 10:03 AM   #9 (permalink)
Thanks for the explanation. Do you use black gears in both front and rear ? I tried to use black gears in front of TT and kept white gears in rear of TT. The end result was no good. Tail hit grass when landing and stripped from black gears immediately. Rear white gears had no problem at all.
Then I replaced stripped front black gears with original white gears and had another grass touching during landing. Front white gears were fine with just a very tiny damage to the gear. I flew my heli on Sunday with the very tiny damage front white gear, no problem at all.
Old 05-07-2014, 10:08 AM   #10 (permalink)
I agree with your observation about black gear vs white gear. I too had black fail b/4 white in an assembly containing both on my 550 when the tail bearings seized. I so much want to believe the hype, so I will give black one more try. Being the black is more brittle, it may be more fragile in the colder temps. But with summer here, I hope it will be a non-issue.
Old 05-07-2014, 10:09 AM   #11 (permalink)
I see....
Old 05-08-2014, 09:11 PM   #12 (permalink)
http://www.valuehobby.com/helicopter...er-tl2365.html
Steve
///-------TEAM FLYBAR-------///
ERRATIC is offline        Reply With Quote Quick reply to this message
Old 05-09-2014, 06:50 AM   #13 (permalink)
Will order today.
Ended up adding 3x (0.1mm) shims to the umbrella gear. Could have added more, but the out-of-round bevel gear on the vertical shaft caused binding in one spot. Also upgraded the bearings.
Old 06-17-2014, 03:29 AM   #14 (permalink)
Will order today.
Hi,
where did you buy these bearings?
Thanks!
Old 06-17-2014, 08:09 AM   #15 (permalink)
Unfortunately, there's only one major player in the hobby bearing market (hint, hint! - anyone want to give'em a little competition?) and that's Boca Bearing.
http://www.bocabearings.com/
Good service , good selection, but some items can be a little pricey.
I like to use the ABEC 7 ceramic hybird non-contact orange seal with AF2 oil for most non-motor full rotation applications. But really any ABEC 5 or even 3 are better than stock (which usually are ABEC 1 unless you have a Goblin or something). ABEC rating doesn't tell the whole story, but it does let you know the level of matched components. Sure we're only talking about fractions of in-oz of drag torque but just the drive train alone in the 450 uses 16 bearings.
Bearings ABEC 3 VS ABEC 7 (1 min 18 sec)
Hi,
Thanks!
Old 06-17-2014, 09:12 AM   #16 (permalink)
Default Re: Torque Tube Shims
Also consider AvidRC.com. $1 each for their bearings, I've been buying stuff from them for several years, I've been happy.
Sent using Tapatalk.
Old 06-17-2014, 09:21 AM   #17 (permalink)
The two big Tarot players in the US are Tarot-RC-Heli.com and ClubHeli.com... both are very reputable!
Walkera 4#3B, 4G6
Align 250SE, Gaui 200
Tarot 450PRO
Align 550L Dominator
Steve Joblin is offline        Reply With Quote Quick reply to this message
Old 08-31-2015, 03:42 AM   #18 (permalink)
Hey FNFAL, what is the exact size of the shim that fits the TT?
Im gonna need some. I've been a 450 Pro belt guy for 3550 flights and I'm sick and tired of it slipping. A belt survives 99.999% of crashes but I simply can't make it hold. Unless my tail servo is slowly dying and acting up now and then.
I've got my TT conversion done, still working out some bugs and vibes but its obvious that I'm going to need to shim the unbrella gears.
Wouldn't it be nice if folks would send you about 10 of those with your umbrella gears even if you had to pay a buck more? They know your gonna need them.
That's like feathering shaft shims you can hardly find them anywhere.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 09-02-2015, 08:10 AM   #19 (permalink)
Default Fast-Forward one year
I don't recall exact dimensions - as I don't have any examples here any more. But they work nicely under the umbrella. Looks like Value does not sell these shims any more. Shucks. Linky no worky. In fact I don't see them offered now anywhere.
Something about 0.1mm thick is good (can used multiples). And if you choose under the umbrella, then a 6mm ID with perhaps say a 8mm OD.
Or if you shim in-between bearing stack, then say a 8x10x0.1mm
I think Amain might have something close.
Old 09-02-2015, 09:42 PM   #20 (permalink)
Tmkrc.com has tt shims for the pro
(I.Y.A.O.Y.A.S.)
