Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Old 01-05-2017, 03:35 PM   #1 (permalink)
Default BK cyclic horn
Anybody here using the BK servos? I was wondering what horns you are using for cyclic. Thanks
tacomaster is offline        Reply With Quote Quick reply to this message
Old 01-05-2017, 04:59 PM   #2 (permalink)
I use the mks horns.
cquillen is offline        Reply With Quote Quick reply to this message
Old 01-05-2017, 05:16 PM   #3 (permalink)
On the "other" brand 380, I ended up using BK horns. I thought the BK's were too flimsy, but they have held up well with the splines not developing play over 100's of flights yet stripped in the real hard crashes, which I think they should. Much better than the SAB horns which look beefy but developed play in the spline quickly.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 01-05-2017, 06:02 PM   #4 (permalink)
I ended up just getting the BK horns. I took my servos off of a G380 that had the SAB horns and they were too thick to fit the P380.
Synergy E5s 12S!
Minicopter Diabolo 550
Mikado 480 eXXtreme
GauiX3 350mm 6S
TucsonFlyer is offline        Reply With Quote Quick reply to this message
Old 01-05-2017, 06:42 PM   #5 (permalink)
Ok guys thanks. I got these servos used with sab horns and read they won't work. Do the BK horns have the 15mm hole?
Old 01-05-2017, 07:42 PM   #6 (permalink)
I found some. My buddy had aligns. 15mm on the outer hole. Happy camper now :)
Old 01-06-2017, 11:21 AM   #7 (permalink)
Mine has SAB horns but not with BK servos. I bought the heli used and it came with KST.
Has anyone confirmed that the BK servos and SAB horns won't work?
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 05:42 PM   #8 (permalink)
Yep, with the BK's and the SAB horns the horn hits the middle bearing block when the arm moves down. It's cause the SAB arm's back is almost flush with the servo face. You could almost certainly just grind down the bearing block a little but I just went with the BK's.
Synergy E5s 12S!
Mikado 480 eXXtreme
GauiX3 350mm 6S
Old 02-19-2017, 10:31 PM   #9 (permalink)
I'm using the BK 3001's with the horns that came with them, as I remember. They seem to project a little too far from the servo. They sometimes bump the frame as they go up and down. It's certainly noticeable on the bench, but doesn't seem to have any effect on flight as they don't hang up, but they are hitting. Just wondering if anyone else has noticed this and if I should be concerned? I suppose I could try different horns or use washers to back out the servo a mm or two.
Protos EVO770, Logo 550SE, Protos EVO380, Oxy3, Oxy3 SPEED, BKJeti, Citizen 655, AMA 1086988
billc55 is offline        Reply With Quote Quick reply to this message
Old 02-19-2017, 10:55 PM   #10 (permalink)
I'm running the stock ones at the 14mm hole with no problems. I'll post a pic of mine and see if it's the same
Old 02-20-2017, 09:42 AM   #11 (permalink)
I had the same problem Billc55 had. Especially worrisome was that the servo to swash link can rotate to the point where the plastic ball link was hanging up against the frame.
My solution was to use a fine file on the carbon fiber frame to increase the clearance a bit. It doesn't take much.
Sent from my iPad using Tapatalk Pro
lgordon is offline        Reply With Quote Quick reply to this message
Old 02-20-2017, 03:53 PM   #12 (permalink)
You could try putting spacers behind servo mounts
tshelby73 is offline        Reply With Quote Quick reply to this message
