Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree1Likes
Old 08-24-2016, 11:53 AM   #21 (permalink)
deleted
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
Old 08-24-2016, 12:29 PM   #22 (permalink)
Originally Posted by slikwrik View Post
Because fixed wing mode makes the ESC power the motor like it would an airplane - Linear throttle curve and instant power change.
So if you go from 0 - 100% throttle instantly, the motor will spin to 100% as instantly as physically possible. You want this if you're using FBL gov because the FBL provides all the throttle input - like slow spoolup, etc.
If you have the ESC in heli mode or other, the ESC will be controlling slower spool-up functions or other mechanisms that moderate throttle input into the motor.
For obvious reasons you dont want your heli to go from 0 to 100% headspeed instantly.
Perfect, that's what I needed to know. Thanks, Dave
Sent from my SM-N920V using Tapatalk
Gaui X5 Formula - Ikon
Trex 450 SE V2 - Tarot DFC, AR7200BX
Nano CPS
R6 Pilot is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 11:22 AM   #23 (permalink)
Is there a motor pole count like in vbar gov? Or just ratios? 120/21 etc.
If using stock tail not speed up what ratio is suggested in the software.
Steve
smittylube is online now        Reply With Quote Quick reply to this message
Old 01-23-2017, 12:00 PM   #24 (permalink)
Are you busing brain gov or hobbywing gov?
4.27 stock 4.47 speed up pulley
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 02:20 PM   #25 (permalink)
brain 2 was my intention for gov
That ratio question was in the gov setup screen
Steve
Old 01-23-2017, 05:39 PM   #26 (permalink)
The sensor divisor is half the pole count. There is really good instructions to the left on every page. The gov page explains all this in very good detail FYI. You'll need to setup flat throttle curves as well as calibrate the throttle to the esc. Doing so with the gov turned off then you must turn it back on after that.
Old 01-23-2017, 09:11 PM   #27 (permalink)
Thanks I saw the comment about gov off in the next page, but didn't see the 1/2 pole count, 890 kv says 10p so set will the pole count to 5.
I did see the 40/60/100 throttle curve settings - sounds a lot like castle- easy enough.
Steve
Old 01-23-2017, 09:14 PM   #28 (permalink)
So if you have bank switching separate from idle up 1 and 2 the head speed is set by throttle curve you can now tweak each bank at will.
Very nice
Steve
Old 01-23-2017, 09:49 PM   #29 (permalink)
Very nice
That is correct, banks and gov head speeds are separate channels as is tail gain as well and rescue if you have enough channels that is. Or you can get creative.
Old 01-24-2017, 02:08 PM   #30 (permalink)
Ok searching all over first time with brain gov- yellow sensor wire goes to gov port on brain right?
Steve
Old 01-24-2017, 02:26 PM   #31 (permalink)
That is correct.
Old 01-24-2017, 02:56 PM   #32 (permalink)
thanks Nick
Steve
