Old 03-18-2016, 06:01 PM   #21 (permalink)
It can still be clean, i have everything inside the frame on mine even the full receiver / FBL and tail servo see pic of my receiver / FBL / tail servo mountings
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super
Toocool4 is offline        Reply With Quote Quick reply to this message
Old 03-18-2016, 06:04 PM   #22 (permalink)
Originally Posted by gimbleguy View Post
Yeah I read that somewhere too, not to put the phase sensor close to the esc/motor or shield it somehow.
I wish i knew that before i cut and soldered the cables in, i found out the hard way
Old 03-18-2016, 08:15 PM   #23 (permalink)
Some more pics
I can now officially confirm nothing is being governed, but the motor is powerful enough that it doesn't seem to really be a problem. I'll still fix it eventually, but I'm not in a huge hurry.
Best thing about it?
Talon 15 and motor come down *barely* warm after a decent smackdown
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is offline        Reply With Quote Quick reply to this message
Old 03-19-2016, 04:52 AM   #24 (permalink)
100% throttle, flat line. You know you want to :-D
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 03-19-2016, 10:09 AM   #25 (permalink)
With the belt the way it is, I'm not so sure
On the bright side, infinity belt should be here today
Old 03-19-2016, 04:15 PM   #26 (permalink)
Found some Lynx dampers in stock in the US (a hard thing to do it seems these days...) so I ordered them to give them a shot
Hopefully they'll help with my wobbles and delayed collective.
Also, switched to the Talon 15 governor and it's really good, so as of now I'm just not even gonna bother with the Vbar gov. In fact once I replace the battery leads I might just remove the sensor... might get it down to 268g
Old 03-19-2016, 05:50 PM   #27 (permalink)
Tis nice and smooth now
Trex 250 DFC - New Belt (3 min 18 sec)
Old 03-19-2016, 05:56 PM   #28 (permalink)
yep sounds much nicer. Did you find the cause of the Collective Lag? Was it the damaged belt???
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 03-19-2016, 05:56 PM   #29 (permalink)
Nope, I think it's just the dampers. Rather, I hope it's just the dampers
Old 03-19-2016, 06:02 PM   #30 (permalink)
I was using the Talon 15 governor before and it works very well, but after switching to the Spartan governor I will not go back unless the hobbywing sensor fails or something.
The small weight penalty from using the RPM sensor is well worth it, the improvement I get from using the Spartan governor makes it worthwhile.
I think if you can move the sensor away from the ESC you should give your vbar governor a try.
Old 03-19-2016, 06:04 PM   #31 (permalink)
Sure, I know Vgov is better, I loved it on my X3 vs internal gov but this one works well enough. I might do something about it once I get my wire and replace my battery wires, but honestly I'm not too motivated to
Old 03-19-2016, 06:17 PM   #32 (permalink)
Nice flying Number, you should give the Zeal blades a try it makes the 250 fly so much better
I let a friend of mine fly my 250 with the Zeal blades, then I loaned him a spare set to try on his 250. He went straight out and bought some for his 250.
Old 03-19-2016, 06:30 PM   #33 (permalink)
I'd like to, just wish they weren't $23 lol
Old 03-19-2016, 06:37 PM   #34 (permalink)
Yes pricy but they do fly well.
I have given away both sets of my Align carbon ones as i like the Zeals so much.
I always keep spare blades in the T-Rex250 carry case, as i don't like being down for long when i do have a crash.
Old 03-19-2016, 07:53 PM   #35 (permalink)
Where did you find the lynx dampners???
Trex 450L 6S-BX, Trex 550L(To Build), Trex 450 Pro BX, Trex 450SE-Robird, Trex 250 DFC-Robird, Blade 4503D-X-BX, Blade 230s, 180 CFX, (2)130x, MCPX BL, Nano CPX
Spektrum DX6 & DX8
wildhorseheli is offline        Reply With Quote Quick reply to this message
Old 03-19-2016, 08:47 PM   #36 (permalink)
I just searched eBay. "Lynx Ultra Dampers 250" and HeliDirect had them. It appears I got the last ones though
These people have them though, a bit pricey but free shipping
http://www.ebay.com/itm/LYNX-LX1164-...8AAOSwQJhUmaET
Old 03-19-2016, 08:49 PM   #37 (permalink)
Well some unfortunate news, I went ahead and tried to fix the RPM sensor issue, I shielded it with alu foil and checked all soldering, to no avail: Vbar still doesn't see the RPM.
So I gave up and removed the sensor altogether. Sad, but there's not much I can do. I may try again some day. The sensor may just be dead.
On the bright side, I'm down to 269g
Old 03-19-2016, 09:07 PM   #38 (permalink)
Let us know if they are stiffer than the align 250 dfc dampers.
Old 03-19-2016, 09:12 PM   #39 (permalink)
With my experience with Lynx dampers, they are almost completely solid.
Old 03-20-2016, 10:00 AM   #40 (permalink)
Yup, they're definitely stiffer.
