Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-21-2012, 02:37 PM   #1 (permalink)
Default Scorpion 4525LE Ultimate
So they finally decided to go with a YY winding!!!
http://campaign.r20.constantcontact....rVvtMtsuUjw%3D
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 03:41 PM   #2 (permalink)
Oooow, perhaps I should not sell my spare Helijive now!
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 04:19 PM   #3 (permalink)
Done, ordered and i am ready now to order the Diabolo for this motor
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 04:35 PM   #4 (permalink)
in the text of that page it says that it has a 9 turn delta.. so i think the spec is wrong. .do we know what the actual wind is? like a 5+4 or something?
spdntckt is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 04:40 PM   #5 (permalink)
I noticed that, but guessed that was the original specs for the first 4525LE
Old 02-21-2012, 06:41 PM   #6 (permalink)
so did I make a mistake by ordering this one would it work with helijive
_____________
Old 02-21-2012, 06:50 PM   #7 (permalink)
I read it that there will be no more 4525LE Delta wound motors. If you place an order now, or on a back order, you will get the new YY wound motor.
This should be fine with the HeliJive, as the 4530 and 4535 LE's are YY, and run fine on the Kon.
Old 02-21-2012, 07:18 PM   #8 (permalink)
so my understanding it is more powerful than pyro 520, they both cost the same. I may try it on a second TDR kit if I decided to build that one, I am also thinking of Diabolo too, can't really make up my mind.
_____________
Old 02-21-2012, 08:57 PM   #9 (permalink)
The Diabolo is a better choice for powerful LE motors. It has much more bracing than TDR, it is made to handle more power.
Diabolo build thread with good pics:
https://www.helifreak.com/showthread.php?t=382529
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 11:27 PM   #10 (permalink)
Next up let's hope they do a 4035 yy will have more power and better for likes of the tdr
Old 02-21-2012, 11:40 PM   #11 (permalink)
Will the YY work with the Kontronik Jive 120 for 3D flight?
I would like to have a larger motor for XFC.
The current 4525 will shut down with the Jive 120, im not intrested in changing ESC just for this motor.
(´・ω・`)
Blink 182 is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 04:00 AM   #12 (permalink)
In a word, yes.
YY terminated Scorp motors run very very well on Kontronik Jives, no matter whether during 3D flight or speeding.
Cheers,
Simon.
Nexus665 is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 06:02 AM   #13 (permalink)
Not always. I run 4525s on my TDR and JOker3 with Jive 120 - never had a shut down.
John
Old 02-22-2012, 11:47 AM   #14 (permalink)
Thing is with yy no need to run ksa and yes while you can get away with running the d non ksa etc, flying hard on a warm day you run very big risk of failure, very well documented.
Old 02-22-2012, 01:01 PM   #15 (permalink)
Is that because the helijive 120 is not enough amperage wise or it is a thermal shutdown, if it was the later do you think the soon to come Kosmic 160A will help?
_____________
Old 02-22-2012, 01:37 PM   #16 (permalink)
Possible issue with low resistance motor, it is not temp or amperage problem.
Basically the Jive could "loose timing" so it stops working correctly in flight with possible damage for components inside Jive.
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 02:21 PM   #17 (permalink)
The IR of this motor is very close to my pyro 520 black edition, I would not think Kontronik will miss something like that, I started worrying now I will have the same problem as the black edition has low resistant wiring
_____________
Old 02-22-2012, 02:37 PM   #18 (permalink)
Default I doubt very seriously that your k motor will have problems with a k jive.
My power jive worked great with my pyro and my 4525le. You will be fine.
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 03:41 PM   #19 (permalink)
I understand the PowerJives are OK with the 4525LE, in fact I know 2 people running that combo with no problem.
The problem as I know it is the HeliJive with the 4525LE. Something to do with low IR delta wind motors and back EMF popping a diode in the HJ.
Old 02-22-2012, 04:03 PM   #20 (permalink)
That is new for me, it is only HeliJive problem, not PowerJive??
I thought it does not matter.
I have 4525LE in a box over a year and i do not want to use it with any Jive (and possibly loose a heli) so i save it for new build with YGE (probably).
- TDSF in a box...
