Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 07-29-2014, 02:10 PM   #1 (permalink)
Exclamation N5c TT Auto Gear Mesh issue
Howdy,
I'm nearing completion of my N5c TT build and I'm stuck. Once I complete the main transmission install (pg 40), the auto gear can barely turn. I loosened all bolts in the front transmission block and the main shaft bearing blocks to no avail. It appears that the auto gear is out of round and/or too large.
Is this something that will "wear in" or do I need to get this fixed?
Brandon Gaither is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 04:36 PM   #2 (permalink)
Count the teeth on the auto spur gear. Wonder if you got a 54t rather than a 52
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 06:34 PM   #3 (permalink)
You should also ensure that the boom is flush with the rear boom mount no farther. If it is farther than flush it will push the mushroom gear in to the other gears causing them to bind.
Synergy 4eva
ChapaWolf is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 08:06 PM   #4 (permalink)
Are you sure that you have the top bearing block for the spur gear facing the correct way?
Its actually slightly curved. The top of the arch in the curve faces backwards.
I ran into this a couple of days ago myself. You cannot tell from the manual without very close examination that the block is curved or which way it faces
Gaui X5 FBL w BeastX! yesssssss!
"The Big T" TRex600N OS 50 +Flybar!
Synergy N5 O.S.55 Spartan Vortex
Himilou is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 08:11 PM   #5 (permalink)
Thanks Chris.
It's a 54t. Manual calls for a 54t. Is that wrong?
Old 07-29-2014, 08:12 PM   #6 (permalink)
Thanks ChapaWolf.
Boom isn't installed yet.
Old 07-29-2014, 08:53 PM   #7 (permalink)
Default Re: N5c TT Auto Gear Mesh issue
Originally Posted by Brandon Gaither View Post
Thanks Chris.
Your right. Was thinking e5. My apologies
Old 07-29-2014, 11:53 PM   #8 (permalink)
Thanks Himilou.
Yep. It's going the right way. If not, the front transmission assembly can't be mounted in the frame...
Old 07-30-2014, 03:02 AM   #9 (permalink)
I actually got to where all the screws were started but noticed binding. The I turned the bearing block arund.
BTW are you going to use a robird on yours? I'd love to know how it goes, I have a spare robird sitting around.
Old 07-30-2014, 11:21 AM   #10 (permalink)
That's exactly what I did too.
I've had really good success with iKon on nitro so I'm sticking with it.
Old 07-30-2014, 01:04 PM   #11 (permalink)
Im using Ikon on my N5c TT also. I had to turn my gov gain way up to get it to work. I think its around 80 something with align sensor and os 55 Hz hyper once I got it turned up though it was night and day. Its like I woke up the beast inside my OS55. If you like Nitro you will love this bird. It is THE 50 class nitro to own.
~Synergy N7, YS91-3DS, IKONV2/BT XPERT SERVOS
~Synergy N5c TT, OS55-H, IKONV2
~Blade 180cfx
~Futaba T14SG
TeamXpertServos
Frequency is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 09:47 PM   #12 (permalink)
I've got the ikon on a Velocity 50N2 and an NX4. Really pleased with it so far...
Old 07-31-2014, 09:49 PM   #13 (permalink)
not to derail your thread. Did you fix your issue? I'm trying out a Spartan on mine. Maiden this weekend!
Old 08-01-2014, 11:01 AM   #14 (permalink)
Cool, good luck with that... saw one on a G4 at HoD last weekend... looked really good.
As for the gear mesh problem. Success! I had done the tail speed-up on my E5 so I had another 54T auto gear and spur hub. I pulled it from the E5 and installed it on the N5c... As I suspected, the known good gear from the E5 is butter smooth compared to the original. Keeping my fingers crossed that I'll be able to finish this bird in time for IRCHA... I need help from a nitro tuning god.
I'm going to test the bad gear in the E5 in the next few days. The tail case can move so its probably more forgiving than the N5c... hopefully it works.
