01-10-2019, 12:14 AM
#2 (permalink)
Originally Posted by Dustin Mustangs
Just about to maiden one of these(!) that has been sitting on a shelf for the last 15 years. I think I have everything sorted but can't figure a good way to level the swash and I didn't find where that is gone over in the manual. The only adjustable links I see below the swash are the ones directly off the servo horns. I initially adjusted them for proper linkage geometry which did not get me a level swash (although it is close).
Do I mess up my geometry and level it with the servo pushrods, use subtrim, or fly with it slightly off?
wow old thread but I will comment anyways. If I remember correctly, these had Z bends on the rods going into the servos so you could only adjust the other end. You have limited threads on one end so it all depends on how far off it is. adjust the link ends till its level but make sure the links are not hanging on by 2 threads.
