Old 10-18-2009, 04:05 AM   #1 (permalink)
Default tail is drifting copilot 2 raptor 30 v2
i have the gyro is plugged into ch4 on the cp2 computer and the rcv4 is in the rx ch4
i have turned the cp2 output ch4 to zero and when i turn the gain to zero on my transmitter
the drifting stops but then im in rate mode.
seems like this problem comes and goes could it be because im setting the heli up in my bedroom ?
and we were going to the field in the morning to show the guys sorry i posted to late.
i have a futaba 7c tx and 7 channel rx
1 channel aileron
2 channel elevator
3 channel throttle
4channel rudder
5 channel gyro aux
6 channel /blank
7 channel align governor aux wire yellow
For CCPM helicopter
n
Cyclic roll (aileron)
n
Cyclic pitch (elevator)
n Collective
my collective is in channel 6 its plugged into rcv 3 hope that is correct placement .
wc_wickedclown is offline        Reply With Quote Quick reply to this message
Old 10-18-2009, 04:14 AM   #2 (permalink)
If your routing your gyro through the CPII on the 4th channel, you'll need to input the gyro gain through the CPII programmer while doing quick setup.
The 4th lead out does not get used...so disconnect it from your Rx. this is used for a 4 servo cyclic setup.
When the gyro gain is operated through the CPII your Tx will no longer have any effect on it.
side note: do not attempt any adjustments indoors as the CPII will react oddly if not outside in the open.
nightflyr
JR9303 / JR9503 / Futaba10CHP
Old 10-18-2009, 05:22 AM   #3 (permalink)
i dsconnected #4 from rx now the rudder does not function from the stick
rudder is connected to gyro then 2 wires from gyro one wire is gain #5 guess number 4 on my rx is rudder
Old 10-18-2009, 05:30 AM   #4 (permalink)
Originally Posted by wc_wickedclown View Post
idsconnected #4 from rx now the rudder does not function from the stick
you need to plug the gyro gain lead from your gyro into the CPII avionics computer into the 4th slot the rudder servo will stay connected to the gyro, and the Rx lead from the gyro needs to be installed into the rudder channel of your Rx
Old 10-18-2009, 05:34 AM   #5 (permalink)
* You only run the Gyro HH to the CPII avionics computer when you need to free up a channel on your transmitter, so you can remotely turn CPII on/off.
Old 10-18-2009, 05:44 AM   #6 (permalink)
unplugged gyro gain and heli stays in rate mode
Old 10-18-2009, 06:00 AM   #7 (permalink)
give me a min
Old 10-18-2009, 06:08 AM   #8 (permalink)
quote: You only run the Gyro HH to the CPII avionics computer when you need to free up a channel on your transmitter, so you can remotely turn CPII on/off.
i thought you said for 3dmode the gyro had to be connected to te cp2
disconnted the gyro from the cp2 no more tail drift.
all looks ok
but when i plug the gyro gain into the cpll how do i turn the gyro on and off ? or will i just be left with rate mode and heading hold from the irc remote ?
Old 10-18-2009, 07:30 AM   #9 (permalink)
all looks ok
3D mode is for airplane , the CPII when setup for a helicopter only allows it fly inverted with stabilization , it doesn't understand 3D for a helicopter.
it tells the sensors that they are functioning upside down on a helicopter.
The gyro gain setting is fixed through the programmer to what ever % you give it.
So say you tell the CPII to give 32% to the gyro, no matter if the unit is on or off the gyro will still see 32%. there is no way I know of to switch it between rate and HH during flight.
nightflyr
Old 10-19-2009, 04:41 PM   #10 (permalink)
Hmmm - I remember when we unplug the gyro gain, the gyro will stay in locked mode... It does for mine GP750, Logictech, GY401...did I do something different?
tks
rcjpth
rcjpth is offline        Reply With Quote Quick reply to this message
Old 10-21-2009, 08:43 PM   #11 (permalink)
if the gyro is working the light is green and your in heading hold if the light is red your in rate mode
