RealFlight Flight Sim All versions of RealFlight Sim |
07-07-2008, 02:02 PM | #81 (permalink) |
trex450SEV2 on a G3.5?
I have a Realflight G3.5. I am looking at a 450SEV2. Is there any way to install this heli on my sim? If so how difficult is this?
07-07-2008, 03:38 PM | #82 (permalink) |
Download and save the file to a location you can find later.
http://www.knifeedge.com/forums/down...o=file&id=3417 Use Realflight's "Import" function from the simulation menu. After succesful import it will be available under aircraft selection. |
08-10-2008, 03:55 AM | #83 (permalink) |
G 3.5 screenshots
Goofing around.
09-27-2008, 01:59 PM | #84 (permalink) |
I have lost the Trex 450 SE V2 from the sim. When I try to reinstall it from my documents it tells me it's already in but when I try to put it in it tells me I don't have that heli. It seems I lost it from my list. It's been working for several months with no problem. If you can explain why I would be very thankful.
10-23-2008, 07:21 PM | #85 (permalink) |
no blades ???
I installed one of the trex 450,s and it says unable to locate rotor blades 325 ????
were do I find these blades ??? |
11-03-2008, 05:38 PM | #86 (permalink) |
when I installed the link provided by phrank the heli bounces around and wont take off how do i fix this?
11-03-2008, 06:09 PM | #87 (permalink) |
This is a side-effect of using G4.5. (I'm assuming you have upgraded to G4.5 and are now experiencing this?)
Temporary workaround here: http://www.knifeedge.com/forums/showthread.php?t=21809 |
11-05-2008, 07:21 PM | #89 (permalink) |
still having a problem it stoped bouncing on the ground but now the tail of the heli swings back and fourth? how do i fix that?
11-05-2008, 08:30 PM | #90 (permalink) |
Complete fix coming soon, the guys are doing some final tweaks on the G4.5 version.
If you can't wait, Post#7 on that same link I gave above has someone else's tweak that solved the problem for them. |
11-07-2008, 02:32 PM | #91 (permalink) |
Credit to trexflyer02, based on what he said to do for the TRex500, I found indeed the value of Skid stiffness of 2% stopped the bouncing.
The tail wag issue goes away by reducing the gyro gain setting to 40. Until the official tweaked version for 4.5 is released the model flies well with these settings in the interim. Hope this helps. |
11-07-2008, 03:40 PM | #92 (permalink) |
Thanks Heli1R, that's a great suggestion.
Release of the 4.5 version of the Trex is almost here with some minor visual tweaks to take advantage of G4.5's new rendering. Stay Tuned. Frank.... |
11-27-2008, 11:20 AM | #93 (permalink) |
ATTENTION ALL G4.5 USERS!
The new CDT Trex 450SE V2 for G4.5 is available for download. Please click HERE to go to the download page, and make sure to download your favorite colorscheme too! |
11-30-2008, 06:42 AM | #94 (permalink) |
THANKS TREXFLYER YIPPIE
"So What is 3D Flying" Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place. |
12-18-2008, 04:59 AM | #96 (permalink) |
THANKS CDT and TEAM
