Old 08-31-2015, 05:53 AM   #1 (permalink)
Default Os 105 bad liner locating pin
Doing a routine bearing change on my os 105,when assembling the motor I noticed the split rolling pin that locates the piston liner is actually flush and not locating anything. Should I try and drill this out and replace with a new pin or will the clamping of the head be ok. This must have been a manufacturing fault because I've never had a motor with this issue.
TEAM REDGUM RC - Compass 7HV NITRO- 7HV ULT - 6HV ULT - Warp 360
conetica is offline        Reply With Quote Quick reply to this message
Old 09-11-2015, 08:40 AM   #2 (permalink)
That pin is there to make sure the liner does not move . The exhaust ports need to be lined up , if it shifts some bad things will likly hapen., whether it be loss of power or the engine gernades is anybodys guess., if you have the means try and replce the pin if not just by a new engine case.
MSH mini-p VBar ,G380, Goblin 500, TREX 600N LE VBar, Trex 700N 91hz FB, Whiplash 105HZR VBAR, Nitro Citizen 414
mr008 is offline        Reply With Quote Quick reply to this message
Old 09-11-2015, 09:13 PM   #3 (permalink)
Yeah i managed to put the case in the mill at work and drill the roll pin out. Ended up using some 1mm Stanless wire as the pin, was hard to find a 1mm roll pin.
Old 10-05-2015, 08:46 PM   #4 (permalink)
are you able to do this with the piston ring pin? many people having issues with those on 105 and 91s lately
blue92ehsi is offline        Reply With Quote Quick reply to this message
Old 10-06-2015, 12:31 AM   #5 (permalink)
Yes it's possible as long as you could get your hands on a new roll pin.
Old 10-06-2015, 05:00 AM   #6 (permalink)
the rolled pin in he problem to begin with. some people have used 1mm wire and set it in with sleeve retainer.
