Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 12-31-2009, 04:18 PM   #61 (permalink)
Thanks. I'll be sure to build it this way.
Scott
KBDD Team Pilot ):>
Old 12-31-2009, 04:21 PM   #62 (permalink)
The Capi
If the arms arnt 90 degrees all that happens is the + and - cyclic pitch range isnt equal, which isnt the end of the world.
Old 01-01-2010, 12:37 PM   #63 (permalink)
I just took a look at the manual, very cool. Thanks for pointing this out. I probably would have made that mistake, based on previous builds.
Scott
KBDD Team Pilot ):>
Old 01-01-2010, 04:13 PM   #64 (permalink)
The Capi
Its not really a night and day difference so its not the end of the world if you get them parallel.
Old 01-01-2010, 05:36 PM   #65 (permalink)
LOL! Let's hope not... Mayan calendar notwithstanding!
KBDD Team Pilot ):>
Old 01-01-2010, 08:26 PM   #66 (permalink)
Two more years for that end to come....
All I can say is "WOW!!"
billbill242000 is offline        Reply With Quote Quick reply to this message
Old 02-25-2010, 01:10 PM   #67 (permalink)
Hey the ball links are very tight, now should I size them or just put a few flights thru them seeing that this stuff (Outrage Links) have a tendency to loosen up quick. Any thoughts on this issue?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 02-25-2010, 01:13 PM   #68 (permalink)
The Capi
Put a gallon thro the machine first.
Old 02-25-2010, 01:15 PM   #69 (permalink)
Cool that's what I thought too, I am just building my bird now!
Angelo
Old 02-25-2010, 01:16 PM   #70 (permalink)
The Capi
I sized my PP linkages as they dont really move that much, but anything above the swash DO NOT SIZE.
Old 02-25-2010, 01:18 PM   #71 (permalink)
PP linkages ?
Not bit on the acronyms
Angelo
Old 02-25-2010, 01:21 PM   #72 (permalink)
The Capi
PP = Push Pull, basically the linkages connecting the servo horns to the swash plate.
Old 02-25-2010, 01:50 PM   #73 (permalink)
K will do this will be a fist for me, I never had to do this with my Trex 250,450,500,600 or the 700...I need to get the tool next what size is needed?
Angelo
Old 02-25-2010, 02:05 PM   #74 (permalink)
The Capi
They are basically all the same size.
Old 02-25-2010, 02:06 PM   #75 (permalink)
Ok thanks.
Angelo
Old 03-05-2010, 05:55 PM   #76 (permalink)
Can anyone post close up photos on how you are passing wires for the Gyro and servos?
Angelo
Old 03-11-2010, 11:32 PM   #77 (permalink)
Default gyro wire routing
I dremeled a notch out of the radio tray right in front of the servo mount that I mounted my Align 750 gyro on. This alows me to feed the tail servo wire up to the gyro, and and the wires from the gyro down to receiver easily. Results in a very clean install. I'll try to post pics when I get back home from a buisness trip.
Here are some pics that don't show it well though:
https://www.helifreak.com/showthread.php?t=192411
, Eflite 450 X, DJI F550 Hexacopter, custom built carbon 650 size quadcopter
cbcelectech is offline        Reply With Quote Quick reply to this message
Old 03-12-2010, 07:11 AM   #78 (permalink)
Same here... I have my gyro installed in front on the servo mount, between the frames. I ground a bit from the front of the servo mount and the battery tray. Servo wires are fun internally, except the elevator servo which penetrates the frame in the slot under the servo (you should put some heat shrink or wrap on the wires at that point). The wires then run straight forward and do not come in contact with the frame at all.
Clyde (Foxden) in another thread said routing the wires behind the battery tray was a good idea, so I pulled the tray, bundled the wires in pairs, then tucked them under the servo trays and behind the battery tray. They emerge in the gap between the servo and battery tray. Additionally, there are two slots on either side of the servo and battery trays for wires to emerge, if necessary.
Scott
KBDD Team Pilot ):>
Old 06-27-2010, 01:35 AM   #79 (permalink)
1. use a small round file or carefully with a dremel, open the holes for the canopy break away tabs so that the post bolt does not bind in the frame (it will save frames)
i wanna do this mod but am i making the actual break away tab whole bigger or make the hole on the frame bigger?
cause it seems it makes sence to make the hole on the frame a little bigger so when the break away tab flexes the screw head doesn't catch on the frame..
burton8012 is offline        Reply With Quote Quick reply to this message
Old 06-27-2010, 07:03 AM   #80 (permalink)
I used my canopy reamer and very lightly a couple of turns to the holes in the frame so the head of the bolt cleared, don't take too much, just enough for the bolts to clear
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote Quick reply to this message
