Flight Stabilization Flight Stabilization |
05-30-2011, 02:55 PM | #1 (permalink) |
CPII & Forward Flight
I have cpII installed on my 500
I'm starting to learn forward flight. If I wanted to tame down the cyclic a little so it's not so sensitive can I do that by putting in say about 70% of dual rate in the TX? That wouldn't have any effect on cpII right? In the preferences menu under Set Gains For Stability mine were set at Pitch Gain 70% Roll Gain 50% shouldn't they both be the same setting? Does Set Gains For Stability determine how fast cpII respones Thanks Ken
EXI/Align 500, HDX 450SE-V5, DJI F450 w/Naza lite, GPS & SkyLark Trace IV OSD, 3DR Quad APM 2.6, SimpleCopter V-Tail , Ken |
05-30-2011, 03:26 PM | #2 (permalink) |
I'm starting to learn forward flight. If I wanted to tame down the cyclic a little so it's not so sensitive can I do that by putting in say about 70% of dual rate in the TX? Might try 70% D/R with 20 - 25% expo that should calm down your cyclic That wouldn't have any effect on cpII right? CPII runs on its own gain settings In the preferences menu under Set Gains For Stability mine were set at Pitch Gain 70% Roll Gain 50% shouldn't they both be the same setting? Those are the default settings, you may need to increase or decrease them depending n your machine Does Set Gains For Stability determine how fast cpII respones More like how much it responds.. too much gain and you will get oscillation in the cyclic, too little and it won't function correctly. Thanks Ken
MSR x1 / mCPX x2 / 450 x4 / Chaos600 test bed / Chaos600 Air-Wolf / American WereWolf 800 / KFrame800/900/1000 / Assorted Fixed Wing JR9303 / JR9503 / Futaba10CHP |
05-30-2011, 03:44 PM | #3 (permalink) |
Thanks night
next time out I'm going to try 70% D/R and then try adding some expo I didn't think it would effect cpII's operation
