Old 09-14-2013, 11:31 AM   #381 (permalink)
What about flight time on each?
michael88997 is offline        Reply With Quote Quick reply to this message
Old 09-14-2013, 12:32 PM   #382 (permalink)
Originally Posted by Surfrjeff View Post
I have both and finally just got the X3 dialed in today. The 450L has insane power and flies great, the X3 feels a little cleaner in the air all around. Im probably just going to keep both.
cleaner, that's how I feel about the x5. sounds like the x3 will be the ticket. i did 3s with that one though so might like both
wingbreaker is offline        Reply With Quote Quick reply to this message
Old 09-14-2013, 12:40 PM   #383 (permalink)
Default Flight times
I am running 4min flights at 100% on both and they both draw about the same out of the pulse 1350's I have.
Surfrjeff is offline        Reply With Quote Quick reply to this message
Old 09-14-2013, 07:21 PM   #384 (permalink)
Got to see the 450L Dominator in person once again, this time flying. No video (couldn't hardly see it) but got some pics
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 09-19-2013, 02:50 PM   #385 (permalink)
YES!!!
Trex 470LP / Beastx / Align BL50X / Align 470MX
Trex 500X / Beastx / Align RCE-BL80X / Align 520MX
smaze17 is offline        Reply With Quote Quick reply to this message
Old 09-19-2013, 03:41 PM   #386 (permalink)
Originally Posted by smaze17 View Post
YES!!!
Nice one man
you are going to love it
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote Quick reply to this message
Old 09-19-2013, 03:52 PM   #387 (permalink)
I love it, but I'm worried about the less flight time. Also do not understand why you have to fly with more rpm being larger blades.
The bigger the helicopter and blades less rpm are needed.
Example:
My 450 pro 3200rpm (325mm blades)
My 550 2400 rpm (520mm blades)
My 700 2200 rpm (690mm blades)
Why the Dominator with 360mm blades need more rpm?, I read in several threads that fly with 3400-3600rpm.
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 09-19-2013, 04:11 PM   #388 (permalink)
it doesn't need it, it wants it ... it makes it have insane power. im sure you can get a smaller pinion if you dont want all the power
Old 09-20-2013, 05:47 AM   #389 (permalink)
Why does a dog lick his balls?
Old 09-20-2013, 06:09 AM   #390 (permalink)
Will a mini vbar fit? thats what i want to use, mine is sitting here for 2 weeks, no time!
helicraze is offline        Reply With Quote Quick reply to this message
Old 09-20-2013, 06:15 AM   #391 (permalink)
Yep
BOOGIE is offline        Reply With Quote Quick reply to this message
Old 09-20-2013, 03:34 PM   #392 (permalink)
Yes, vbar fits and works very well
HorizonHobbyFreak is offline        Reply With Quote Quick reply to this message
Old 09-20-2013, 04:51 PM   #393 (permalink)
BECAUSE HE CAN
LoL
Greetings from Israel
Trex 700e dfc pro HV\Ikon FBL\CC Edge 160
Trex 450L\Ikon FBL\CC talon 35
Gaui X3\Ikon\Talon 35\460MX
bendisar is offline        Reply With Quote Quick reply to this message
Old 09-20-2013, 05:37 PM   #394 (permalink)
Here is a picture of mine
Old 09-20-2013, 07:08 PM   #395 (permalink)
Finally got mine dialed in today, was having issues setting up my AR7200BX as I'm only used to setting that up for a larger heli.
Man this thing has power ... put her inverted and go full negative collective and watch her turn into a dot ...
This is the Heli I've been wanting for a while, small enough to fly in a park, large enough to not have to fly it right in my face and crashes (when parts become readily available) won't be min of $140!!!
Chopper Crew: T-Rex 250 DFC, T-Rex 550e DFC, Goblin Black Thunder 700 T-Line
Multi Chop Crew: US75 Whoop, Martian II 250, Scratch V-Tail 355
Planks: Too Dayam Many
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 12:30 AM   #396 (permalink)
Originally Posted by bendisar View Post
BECAUSE HE CAN
LoL
Exactly
Old 09-21-2013, 01:13 AM   #397 (permalink)
Trex 450L and Warp 360 size comparison
Life is like a helicopter! What you get out of it depends on how you fly it!
wlvn is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 05:28 AM   #398 (permalink)
Nice table
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 10:50 AM   #399 (permalink)
Very nice!
Old 09-24-2013, 12:33 AM   #400 (permalink)
I agree. Just because it's a 6s setup doesn't mean it's more efficient. Watts is watts. 1100mah battery at 22.2 volts is the same wattage as 2200mah at 11.1 volts (volts x amps = watts). If it has more torque it will use more power, so flight time will be less. The main advantage to a higher voltage is you use less amps for the same wattage and your wire size can be smaller.
Blade 450 3D (X2), Align T-rex 450L Dominator 3gx, Blade 500X 3gx, Align T-rex 550E V2 3gx, Align T-rex 600 pro DFC 3gx, Align T-rex 700E DFC 3gx, Phoenix sim, DX6i, DX8
mknj is offline        Reply With Quote Quick reply to this message
