SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support |
11-23-2011, 12:04 AM | #141 (permalink) |
They said it is not necessary
Apparently it is not an issue on the goblin.
TDR, Srimok N x 2, Banshee 31, Dune! |
11-23-2011, 12:40 AM | #142 (permalink) |
The reason many belt drive heli's have a problem with static is the boom block is made of plastic that is not conductive, this leads to the boom building up a charge. An example was the Protos which had some issues initially but then a conductive boom block was then released, pretty much solving the issue.
In the case of the Goblin, from what I have seen in the pictures so far, the carbon boom has an alloy insert molded into it, and this alloy inserts into a matching piece in the main frame. As these are all conductive peices then a charge is not able to build up and in effect the tail through to the motor mount will be electrically connected. This should mean no major static issues. //Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades |
11-23-2011, 01:17 AM | #143 (permalink) | |
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE |
11-28-2011, 04:57 AM | #144 (permalink) |
What is the maximum blade length that will fit on the 700? Will the SAB 720 FAI blades fit?
//Dennis.
11-28-2011, 05:02 AM | #145 (permalink) |
I think SAB need to learn some marketing and release some photos/videos/bits and pieces every now end then to keep interests alive. It's been deserted here and feels like there's not much attention to the thing anymore. Sigh ....
11-28-2011, 05:07 AM | #146 (permalink) |
Lynx Oxy Team Pilot |
11-28-2011, 05:14 AM | #147 (permalink) |
Yeah, they really need to go to marketing school. Imagine, they build their first heli, price at the top end of the market, it sells out two production runs in a matter of weeks. What a bunch of bad businessmen...
SAB Goblin 500 SAB Goblin 700 Jeti DS-16 |
11-28-2011, 05:21 AM | #148 (permalink) | |
Hey btw I've preordered too so I'm a supporter here. |
11-28-2011, 05:33 AM | #149 (permalink) | |
//Dennis.
11-28-2011, 11:38 AM | #151 (permalink) |
Are you kidding? That's exactly what they've been doing. Manual comes out on the 30th. The first production run was 75, and that sold out in about a week and a half. Surely, bad business!
-Goblin 700: Crashed but re-building, still needing electronics -Goblin 630: CC Ice 120HV, vBar |
11-28-2011, 12:01 PM | #152 (permalink) |
Active in the forum Videos, Pictures. Actually the best Heli Launch I have seen Sent from my iPhone using Tapatalk
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... |
11-28-2011, 12:46 PM | #153 (permalink) | |
-Klaus
11-28-2011, 01:14 PM | #154 (permalink) | |
In Goblin 700 can be used up to 720mm blades.
Goblin Helicopters |
11-28-2011, 01:26 PM | #155 (permalink) |
Plus 10
This is the most support I have seen for a launch. Great job SAB!
11-28-2011, 09:51 PM | #157 (permalink) |
There's plenty of photos and videos already available. You just need to search.
MSH Protos 500, SAB 630 |
11-28-2011, 10:01 PM | #158 (permalink) |
Is the date for helidirect shipment still december for the first batch, will it be on time?
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once. Sponsored by : KONTRONIK, OPTIPOWER, PRC, CANOMOD |
11-29-2011, 08:48 PM | #159 (permalink) |
No. The way I understand everything is pushed back to January/February and there will be enough to cover both preorders at that time.
Nikon D4/Sony Fs700/Cinestar 8/8FG super/Dx8 |
11-30-2011, 06:32 PM | #160 (permalink) |
New gear technology
So I received an email today from SAB, explaining the delay in shipment of Goblin 700's. It contained the following excerpt:
"To offer the best performance that can be attained, we have chosen a new gear technology that will allow the SAB Goblin to harness the most brutal brushless power systems available, allowing you to push the Goblin harder & faster than ever thought possible." Can you (goblinhelicopter) explain what exactly the difference is, and how it affects performance? Curious what has changed, and if it may impact what equipment I have chosen and purchased for my 700. Grazie! Cris |
