Old 03-18-2014, 09:10 PM   #1 (permalink)
Default telemetry choice for dx9 volt\cell and mah consumed
Hi guys. I would like to use telemetry on the dx9 to see the voltage per cell and consumed mah. Is it possible?
Thank!!
jean-michael is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 09:13 PM   #2 (permalink)
I believe that you'll need to install the telemetry module(optional)...but not sure if it will give the details you are asking for...I have the stock DX9, no module
Old 03-18-2014, 10:22 PM   #3 (permalink)
Nope, there are no sensors that will provide that information. I doubt we'll ever see one that reports individual cells, but I'm hoping we'll see a mAh sensor.
HeliFreak Support
Graupner MZ-32
Old 03-18-2014, 10:43 PM   #4 (permalink)
They already have an Amp sensor... They just won't give us the ability to see the consumed mAh. Been discussed over on RCG before for years... All they need to do is the calculation inside the radio. No idea why they won't do it.
SAB / Thunder TIger
Bavarian Demon / Spirit Pro
Jeti DS-16 / OpenTx
RCHN #63 C.W.B
Thorvald is offline        Reply With Quote Quick reply to this message
Old 03-19-2014, 05:22 PM   #5 (permalink)
Its disapointed that the dx9 not have this technology because its possible with quanum lcd screen at hobby king. I think if quanum at hobby king can give the voltage per cell and the mah consumme the dx9 will be able.
Old 03-19-2014, 06:28 PM   #6 (permalink)
The accuracy of mAh measurements is heavily dependent on sample rate. Just because other telemetry systems support it doesn't make it accurate.
Ideally, the mAh accumulation calculations need to be done in the sensor, not only for higher sample rates but also to guard against lost telemetry transmission frames. It's no small feat, as it requires a very fast processor.
HeliFreak Support
Graupner MZ-32
Old 03-19-2014, 07:11 PM   #7 (permalink)
OK, so the hobbyking quanum LCD is not accurate?
Old 03-19-2014, 10:54 PM   #8 (permalink)
Good points all around. Im not as concerned so much with mAh in realtime..
Minimum voltage is what I care about.
I log everything.I use the robo-software and look at all the data closer later.It has a calculator built in that will graph the mAh .
Works fairly well for me.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 07:14 PM   #9 (permalink)
Im sorry if i dont well understand, but what you say is you can view your flight after your flight on robo-software or its in realtime?
Old 03-21-2014, 07:23 PM   #10 (permalink)
The robo-software only supports post-flight analysis. The only real time telemetry you can get is what the DX9 reports.
HeliFreak Support
Graupner MZ-32
Old 04-05-2014, 07:52 AM   #11 (permalink)
This works very good, using in my 800 Xxtreme: http://www.rctronix.de/wp/?p=163
Invidual cell-voltages is still a dream tho. There's ways to log those but not to use them in real-time telemetry to TX as far as I know.
RC-Thoughts.com - TeroS formerly known as CP-Geek
TeroS is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 04:21 PM   #12 (permalink)
Sorry for the simplistic thought, and hope I don't get flamed by the experts here, but couldn't some sort of logging sensor from the telemetry plug in to the balance leads on the batt to get individual cell counts real time, for example?
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 04:27 PM   #13 (permalink)
I have two of these sensors and I'm quite happy with the readings.
CZorzella is offline        Reply With Quote Quick reply to this message
Old 05-10-2015, 01:13 AM   #14 (permalink)
Maybe since I'm on my phone I can't get the conversion to English for that site. Is the item there a mah telemetry unit?
fazy is offline        Reply With Quote Quick reply to this message
Old 05-10-2015, 01:14 AM   #15 (permalink)
Exactly that, yes.
Old 05-10-2015, 04:33 AM   #16 (permalink)
I too been using this , check out this : vid1 or vid2
but Spektrum is comming soon with its own mah sensor which was supposed to be out early this month but looks like its been delayed
http://www.horizonhobby.com/radios/t...ensor-spma9605
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 05-10-2015, 04:38 AM   #17 (permalink)
SPMA9604
SPMA9605
HELIFREAK !!!
Old 05-10-2015, 04:54 AM   #18 (permalink)
Originally Posted by aerocal View Post
SPMA9604
SPMA9605
any idea of the release date
Old 07-12-2015, 05:31 AM   #19 (permalink)
Default Aircraft Telemetry Flight Pack Batt Energy Sensor (SPMA9605)
whats up with this sensor , was supposed to be released in May , then was June , July and now
Due Early August, 2015
is this ever coming out , other radio campanies have this sensor for sometime why don't SPEKTRUM do the same
Old 07-13-2015, 06:06 PM   #20 (permalink)
Perhaps they don't think their user base has enough demand for it.
I'm currently waiting for a version of a sensor to arrive from Sweden. If I cannot get it to work, then I will sell off my DX9, all the sats, TM1000, and switch to Jeti which has had all of this perfected years ago.
Fauropitotto is offline        Reply With Quote Quick reply to this message
