Old 07-22-2015, 04:27 PM   #1 (permalink)
Default Tail wag issue need help
Im having forward flight and hard positive pitch tail wag issues. I've tried all the gain settings and Stlill the wag persist.
FreakonaTx is offline        Reply With Quote Quick reply to this message
Old 07-23-2015, 07:53 AM   #2 (permalink)
You need to give more info.
If you tried all the possible gain settings then maybe you have a mechanical tail issue (binding, pushrod setup wrong etc)
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote Quick reply to this message
Old 07-23-2015, 09:23 AM   #3 (permalink)
What he said, if you've already tried ALL the gain settings than it's most likely a mechanical issue, mechanical gain could be too high, try moving ball link in one hole, check for binding in your tail grips and push rod, good place to start!
MallenP is offline        Reply With Quote Quick reply to this message
Old 07-27-2015, 12:25 PM   #4 (permalink)
Default tail Wag Solved! Microbeast Beastx
Well I finally had time to implement some of the suggestions this weekend. I'm happy to report that the issue has gone away. Thanks Guys!
Solution:
*Moved the Ball joint one hole closer to the Center of the servo arm
*Adjusted the Push rod so that I had 90 degrees angle at zero Tail pitch
# set the tail servo frequency to 270, it was originally at 333 DS215MG
# used the supplied thick white foam to mount the unit. Initaly I went with a thin white 3m tape
# loosened the tail belt. This will cause some strange resonances when too tight
Old 07-27-2015, 02:50 PM   #5 (permalink)
