Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
05-08-2016, 04:32 PM | #1 (permalink) |
Tail blades size
I am thinking of increasing the tail blades size while lower the RPM. Using 610mm main blades, could I use 105mm tail blades?
05-09-2016, 05:58 AM | #2 (permalink) |
Yes you can. You might have issues with the blades hitting the ground sometimes if you fly off of grass. Add a spacer to the back skids to elevate the tail and you should be fine.
05-09-2016, 04:47 PM | #3 (permalink) |
I did the same with my fusion, goblin 630 blades, and 105 mm in tail. It runs nice.
As the friend said, be careful with the blades hitting de ground. I made a custom tail with a dremel, a cm longer than the original. Regards. |
05-10-2016, 11:11 AM | #4 (permalink) |
Once upon a time, OnTheSnap countered with this argument:
https://www.helifreak.com/showpost.p...45&postcount=4 |
05-10-2016, 12:04 PM | #5 (permalink) |
OTS can strip a tt gear by looking at it.
You mentioned lower head speed so also not as much of an issue. I changed my tail grips and hub to an Align one which uses 3mm bolts. Don't use the KBDD @ 105mm. Those will be super heavy and may cause issues. |
05-10-2016, 12:16 PM | #6 (permalink) |
Interesting that I can change the tail grips. I was hoping to use the Halo 105mm tail blades. For the Align parts, are they from the 600? If yes, which model specifically?
05-10-2016, 02:28 PM | #7 (permalink) |
600N or E grips. Same part. A bit of mod is needed for the links but easy to file down. You need the hub as well.
05-10-2016, 11:47 PM | #8 (permalink) |
I just checked, and the tail grip cap screw is actually M3. I won't need Align parts.
05-11-2016, 04:58 AM | #9 (permalink) |
Huh! And your tail grips are Outrage?
05-11-2016, 07:47 AM | #10 (permalink) |
Yes sir! Maybe it was upgraded at some point. I got the kit at the end of their existence. I probably maiden flew mine after they officially went out of business.
