450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
06-22-2015, 11:34 AM | #1 (permalink) |
450 Pro v2 or 450 Sport V2
I am getting back into flybarred helis (I've been flying FBL helis untill now), so was wondering which 450 Trex FB to get?
I recently bought a new in box Trex 450 Pro V2 (p/n KX015082). I want to get a 2nd one either as a 2nd heli or for spares. Or should I get the 450 Sport V2 (# KX015081) ? BTW, these are not going to be upgraded to FBL (I have other FBL helis for that). The Sport has a wider 4-piece frame, on-boom servo, belt vs torq tube, more plastic, etc, etc. As far as the head -- which one is the latest design -- the Pro v2 or Sport v2? On the other hand, I really don't want to have to stock 2 sets of spare parts -- one for the Pro and one for Sport. So, what's the consensus: get a 2nd Pro V2 or a get a Sport V2 ? thanks
mcpx BL, 180cfx, 450 X, 500 X, Logo 480xx, Gaui X3, X5, Protos 500, HD Cell 500, phoenix, RF7 Last edited by helirifick; 06-23-2015 at 03:10 AM.. |
06-23-2015, 01:38 AM | #2 (permalink) |
Hello, I have had both, and, to be honest, the Pro just flies better, just my 2 cents.
I dont crash, I just land unconventionally 500 A109. 500 AS350. 450 Bell 206. Oxy 4, Oxy 4 Stretch and Synergy 516. |
06-23-2015, 07:18 AM | #3 (permalink) |
I personally like the pro much better. Only thing that some people don't like is the torque tube. I see it as a positive myself because I don't care for belts.
Trex 700L Ikon 2 / Trex 700L Ikon V. 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2 It isn't about if, it is about when! |
06-23-2015, 07:30 AM | #4 (permalink) |
I would get another pro, I have two 450 pros right now. I fly one and switch to the other after a crash. I like that they share the same parts and I can swap whole components if I'm having issues after a rebuild.
06-24-2015, 02:34 AM | #5 (permalink) |
Thanks everyone.
Ok, I got another 450 Pro V2 (p/n KX015082) -- flybarred!! My place looks like a damn hobby store -- there are heli things/kits/stuff everywhere !! From what I managed to gather, the diff between the Pro V2 and Sport V2 are that the Sport has a wider body, 4 part frame, more plasticky parts, belted tail, all 400 series Align servos and tail boom mounted tail servo, and better head than the Pro ? Are these things stretchable to 360 size & 6s or just leave them alone? I am not going to upgrade them to FBL, by the way.
mcpx BL, 180cfx, 450 X, 500 X, Logo 480xx, Gaui X3, X5, Protos 500, HD Cell 500, phoenix, RF7 |
06-26-2015, 12:25 AM | #6 (permalink) |
I bought a set of KST DS215MG cyclic servos to replace one of my 450 Pro V2's 410M servos and a KST DS525MG servo for the tail.
I may run them all on 6V with the stock ESC's BEC (can it take it?) or put a Hobbywing 50 V3 with its great BEC and run it on 7.4V or more. Speaking of the stock ESC -- mine is RCE-BL35P -- do I need to do the Finless heatsink mod or whatever its called? Also, what 7 or more channel receiver from Spektrum or Futaba is good to run on these? I was thinking of the Futaba R7008SB (came with my 14SGH) or Spektrum AR8000 (came with my DX8). thanks again!
06-26-2015, 05:09 AM | #7 (permalink) |
The Pro is great on 4S!
Instead of building a new Sport 450, Align should have shelved the SE and given the Pro a belt, put a boom clamp on it so the boom stays put and keeps the belt belt tight, give it a sliding adjustable stock motor mount, Increase the Feathering shaft to 5mm, increase the main shaft to 6mm like Blade CFX 360 and X3. They should have given it a dual control tail with affordable individual parts like Gaui did their X3. This describes my Pro to a tee except the Feathering shafts and main oh and motor mount. I had the Rakon http://www.rakonheli.com/cnc-adjusta...450pro-v2.html motor mount and it was sweet while it lasted but it wasn't worth a damn. Only days old It broke in flight under normal use the day before I took the heli on vacation and almost ruined my flying. It was too late to order a mount so I ended up driving an hour and a half to get a stock Align Trex 450 motor mount while on vacation.
If its fixed don't break it! |
06-26-2015, 08:26 AM | #8 (permalink) |
You can get an aftermarket tail shaft to make it a belt drive. My pro was originally belt when I bought it. As for the motor mount, it is adjustable, so don't understand that one. As for the feathering shaft, it works just fine, so I don't see what the problem is.
06-26-2015, 09:32 PM | #9 (permalink) |
I'd ditch the flybar and just go fbl all the way. For a decent electronic 3S setup the sport fbl is wonderful to fly. I got my 450 pro on fbl and 4S. Both PRO and Sport are awesome. Thinking of putting them all on 4S one day, once my 3S electronics claps out.
Just a guy, tryin to Fly |
06-27-2015, 03:50 AM | #10 (permalink) |
You should read the OP's original post a bit better. He said he is NOT converting these to FBL because he already has a few FBL helis and wants to experience FLYBARRED helis.
Trex 550e•Blade Fusion 480•Blade 330s•Blade 230s Smart•MSH Protos 380 Evo •OMP M2 Explore•OMP M2 V1•(2)OMP M1• Goblin Fireball•Blade Fusion 180• Spektrum NX8 Victory Motorcycles:2013 Victory Cross Country•2007 Victory Jackpot |
06-28-2015, 08:21 PM | #11 (permalink) |
I would go with the Pro and do a Tarot belt conversion. I have several flybars and love them so much better then my FBL's, they waltz around the sky.
Curious, why do you want a 7 or more channel RX? Steve
///-------TEAM FLYBAR-------///
06-28-2015, 09:48 PM | #12 (permalink) | |
Did you miss the OP's second post??? I've had many flybarred helis, the problem I found with them the more moving parts, the more prone it is for slop.
06-28-2015, 10:12 PM | #13 (permalink) | ||
06-29-2015, 04:56 PM | #14 (permalink) | |
Touch'e Steve
06-30-2015, 04:06 AM | #15 (permalink) |
Sometimes they just don't get it.
06-30-2015, 10:20 PM | #16 (permalink) |
I am the OP, and I am not converting these to flybarless.
Why? Because I have other helis in my fleet that are flybarless already and I wanted to check out flybarred helis -- like these 450 Pro V2's and 500E & 500E Pro I got.
07-01-2015, 05:00 PM | #17 (permalink) | |
I support your decision not to convert to FBL as I myself have 2 flybarred 450's and love the way they fly. Good luck on your quest and happy flying.
07-06-2015, 08:19 PM | #18 (permalink) | |
07-07-2015, 05:32 PM | #19 (permalink) |
I've seen people use the servo mounts to prevent the boom from slipping in and loosening the belt. They took one and tightened it up right against the boom block. There is a link below. You can also wrap a layer of tape around the boom where it goes in the block to give it more to grab.
Align does loosely assemble the tail and head parts but as you learned, you must go through and loctite it!! http://www.ebay.com/itm/like/2812062...3D862899773517 |
07-07-2015, 06:37 PM | #20 (permalink) | |
