Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 06-22-2012, 06:22 PM   #1 (permalink)
Default Turnigy HeliDrive SK3 Competition Series - 4962-560kv (700/.90 size heli)
purchased motor and Dlux ESC 160 hv let see how it turns out?
honestly it looks like really good quality but still need to put it through it's passes to see if it can handle a good lik'in.
ID:	326379   Click image for larger version
ID:	326380   Click image for larger version
ID:	326381   Click image for larger version
ID:	326383   Click image for larger version
DALE-PABAJO69 is offline        Reply With Quote Quick reply to this message
Old 06-23-2012, 06:58 AM   #2 (permalink)
please can you take the motor apart, usually only needs removal of circlip and show us close up of stator, also placement of magnets in the bell to see if they're mounted equidistant. Looks interesting but pics will show if its more than that. Also please measure length and width of stator
Old 06-23-2012, 11:31 AM   #3 (permalink)
I have the 450 size version of that motor, magnet are well equal, the winding is well made, it's supposed to be a copy of the 2221 scorpion, stator measure exactly 22 x 21mm, but bearing size are not the same, they are smaller, and they use 3 bearing, one at the top and two at the bottom, and motor not balanced of course.
Very very easy to remove the stator from the holder as well as the wire, looks like only weak locktite is used.
T-rex 600E pro
T-rex 450L
Coaxial Collective Pitch 550
martin_ is offline        Reply With Quote Quick reply to this message
Old 06-23-2012, 12:49 PM   #4 (permalink)
Thats why i want to see inside, it may be a good candidate for rewinding,
Old 06-24-2012, 10:23 AM   #5 (permalink)
this here would be my power system for my trex700E,sure hope this works and it doesnt catch on fire.
the quality looks really good but you never know.
stolla I would take the motor apart but it aint broke yet so why take apart a perfectly good motor?
ID:	326746   Click image for larger version
Old 06-24-2012, 01:45 PM   #6 (permalink)
I'm really sorry stolla but naaaaaa!!!!!!!!!!!!!!! no can do!
I understand you'r point you want measurements and such! but it's my!!!!! brand new motor not you'rs, and at this point I can't do that mabe latter but not now sorry dude!
the motor is not that expensive mabe u can get you'r own and do al the rewindining you please?
Old 06-25-2012, 03:07 AM   #7 (permalink)
you wimp! , I understand don't worry, only when you get used to doing this it gets second nature. But let us know how it goes. If you can see from outside whether stator is coated under the wire, and maybe see magnets if they are spaced perfect it would help. Also maybe you can measure stator size from outside by guessing from what you can see the width and length, that will help thanks
Old 06-26-2012, 12:07 AM   #8 (permalink)
Stolla,
Looks like it is a clone of the Hacker Turnado.
http://slowflyworld.de/artikeldetail...HeliDrive+T700
fly big, fly fast, fly hard....
don-dadda is offline        Reply With Quote Quick reply to this message
Old 06-26-2012, 01:34 AM   #9 (permalink)
thanks dd very interesting, what I really like is what I suggested a while ago, slots both ends for magnet spacing,! This looks like a winner
Old 06-26-2012, 01:46 AM   #10 (permalink)
Pity about the small bearings! Got one on the way, so will see how it rewinds!!!
VControl
Old hand at Planks
Peter
Vinger is online now        Reply With Quote Quick reply to this message
Old 06-26-2012, 04:26 PM   #11 (permalink)
thanks don,stolla I would have dissasembled the motor cause I'm also curious but com'on man it's a brand new motor dude! I wanna fly it not spend time disassembling and assembleing a motor.
Old 06-27-2012, 01:10 AM   #12 (permalink)
It's really easy to do. Takes about 1 minute to take apart and 1 minute to put back together. I do it on every new motor just to inspect the quality of the windings. You could catch something that could cause an ESC failure.
Old 06-27-2012, 08:53 AM   #13 (permalink)
+1 to that, and with a cheap motor like this it's just normal routine to inspect it, I would also have put decent bearing in it before any flying to replace those crunchy one.
T-rex 600E pro
T-rex 450L
Old 07-02-2012, 07:59 AM   #14 (permalink)
don't run that deluxe esc from HK. I had one last 3 flights before fireball. True POS esc.
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 10:43 PM   #15 (permalink)
Has anyone flown this motor yet? It's got me curious.
karl k is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 10:28 AM   #16 (permalink)
I'd be interested to know too if someone had done any test flight with this motors.
Thanks,
Rico.
ricoalonso is offline        Reply With Quote Quick reply to this message
Old 07-30-2012, 08:56 PM   #17 (permalink)
Anyone flown it yet? Anyone......anyone.....Bueller.....Bueller?
Trex250 Super Combo/ EXI 250 Super combo with Align F3C fuse/ HK450V2 FBL w/ BEAST X/ EXI 500 FBL w/ BEASTX/ COMPASS 7HV w/ AR7200BX/ MKS HV Servos/ YEP120HV/ Turnigy SK3 HelidriveKBDD on everything
DVUSHELI is offline        Reply With Quote Quick reply to this message
Old 08-03-2012, 10:45 AM   #18 (permalink)
I saw one fly at a local field. The 480kv version in a Chaos 600. Flew great.
I've got mine in my E640. Will let you know how it goes once I get it maidened. Click image for larger version
Please excuse me if my post looks like it was typed by a teenager. It was sent from my phone.
Old 08-03-2012, 11:41 AM   #19 (permalink)
I've got mine in my E640. Will let you know how it goes once I get it maidened. Attachment 337529
karl,
You say you have the SK3 480Kv? Have you tried to let it spin with no load and observed how it sounds? Just wondering since I received mine and the first thing I did was install it my E640 airframe and let it spin with no load at all and I seem to not like the sound while it is still at low RPM. I don't know, maybe I was just expecting a quiet motor. I understand the whining sound but it's something like a grinding sound that I don't like. I turn it by hand and it feels smooth. Only when I apply power into it and while it is at low rpm.
Old 08-03-2012, 01:31 PM   #20 (permalink)
Originally Posted by ricoalonso View Post
karl,
I haven't noticed any weird noises myself. I've only spun it up in the heli with just the main shaft and gear in.
The ESC will change the way the motor sounds. Which one are you using?
