| MSH Protos MSH Protos Helicopter Support Forum |
I used the hub that came with the FBL kit. It has a grub screw where the original (MSH51021) does not. The problem is the threads in this plastic unit all got stripped...the one for the grub screw and both washout/mixing arms.
The only washout unit available for purchase is MSH51021 which doesn't even have set screw hole. This whole unit doesn't seem to see a lot of load and all three screws seem to be holding well but if you turn them they will, to no end. I wonder if it is OK to fly in this condition. Plus, I do not see how I can replace it where the only way to get my hands on one is to buy the whole FBL kit!!! Any ideas?
mCPx, B450FBL w/ TarotZYX & Savox 255 MSH PRÔTOS CF FBL: YGE, Scorpion, JR3717HV, SK-720 w/ HBL980 JR X9503, TH SBach, Telink Edge, 3DHSExtra300SHP Last edited by asasan; 05-28-2012 at 03:15 AM.. |
Low hub.
Sent from my Tapatalk using iPhone.
Mini Prôtos AR7200BX Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116 mCPx stretch uHeli head DX18 AMA# 448427 |
#3 |
The low hub is for stretch. There is a chance of main blades on low hub hitting the tail blades. Plus that's a $45 solution to stripped plastic. Is there a picture of the assembled low hub I can look at?
mCPx, B450FBL w/ TarotZYX & Savox 255 MSH PRÔTOS CF FBL: YGE, Scorpion, JR3717HV, SK-720 w/ HBL980 JR X9503, TH SBach, Telink Edge, 3DHSExtra300SHP Last edited by asasan; 05-28-2012 at 04:04 AM.. |
#4 |
I used CA on mine it's holding
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar SAB G500 Savox 4050 KST/MKS HV YGE HC3SX Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8 |
#5 |
You could drill a new one on the opposite side slightly smaller than the grub screw and just insert the screw allowing it to cut new threads into the block, or use some CA glue and fill the stripped hole then retap with the screw. The block is just a swash follower now and does not ride up and down , so you dont need to torque the screw down so hard to cause it to strip.
#6 |
The low hub doesnt use a washout, the arms are mounted directly to the head. I think I may have a hub I can give you if it's the correct one. PM me if you want.
The part number for the hub I have is MSH40083, let me know if this is what you need. Last edited by jfluegel; 05-22-2012 at 07:05 AM.. Reason: Added part number |
#7 |
Mine did the same thing. Honestly, I don't think there was ever really any material for the threads to grab. A little CA and it pulled up ok
Prôtos 500CF FBL Vbar Blade 450FBL Tarot ZYX
2003 SVT Cobra 538RWHP 2010 Corvette ZR1 all stock To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blade 450FBL, PRÔTOS 500CF FBL |
#8 | |
Going with the CA solution for now.
mCPx, B450FBL w/ TarotZYX & Savox 255 MSH PRÔTOS CF FBL: YGE, Scorpion, JR3717HV, SK-720 w/ HBL980 JR X9503, TH SBach, Telink Edge, 3DHSExtra300SHP |
#9 |
Sorry I gave you the wrong part number. The one I have came out of the fbl upgrade kit. The kit number is MSH51115. Can't find the specific number for the hub but the kit is for the 500.
#10 |
grazie mille, jfluegel. staying true to the origin of the machine.
I got it in the mail and its awaiting CA showing weakness.
#11 |
i have the same problem, fast lad has an upgrade for it..
going to order it tomorrow for mine.. http://www.fast-lad.co.uk/store/wash...08-p-6813.html |
