Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Genius CP
Genius CP Walkera Genius CP Helicopter Support
Old 11-04-2012, 05:03 AM   #1 (permalink)
Default brushless motor and devo question...
can anyone tell me.... is there any changes i should have made with my devo6 settings when i installed my brushless kit that would help with the tail blowouts? i know about the mcpx tail rotor, and extending the boom... was more wondering if there was radio/ gyro gain settings i should be changing as well.... i have a small amount of throttle to rudder in the program mix, just to offset that nose left drift that always seem to happen... any thoughts?
Rockin' the world and flying... that's where i live..
oxide1 is offline        Reply With Quote Quick reply to this message
Old 11-04-2012, 11:48 PM   #2 (permalink)
I am not sure if this would work but have you tried to increase your gyro settings at all?
PaulsBA is offline        Reply With Quote Quick reply to this message
Old 11-05-2012, 01:02 AM   #3 (permalink)
no haven't tried that, but will tonight... was going to have another fiddle with it, see if i can smooth it out a little, hadn't changed the gyro from the factory settings... quite liked it the way it was.... will give it a go... let you know the results!
Old 11-07-2012, 06:54 PM   #4 (permalink)
adjusting the gyro settings definitely helped a bit!!! the tail still blows out a bit if i start to push it a bit...am hoping extending the boom and a different tail rotor will fix that last little bit!!! (looks out the window and checks for the postman)
Old 11-07-2012, 11:44 PM   #5 (permalink)
That HP05 has a lot of torque. Adjusting your throttle curve down may help. I use the WK 2801 PRO with 5 point curves. This tames it down a bit. You have 7 point curves... Sweeeeet!
Sent from Mars. Using Mars Rover.
When you are lying on the floor there is no place to go but up!
Trex 480 Pro DFC, RoBird, Devo 10 Deviation 3.0,
Trex 450 Pro DFC, AR7200BX, Devo 10 Deviation 3.0
HeliIntervention is offline        Reply With Quote Quick reply to this message
Old 11-07-2012, 11:53 PM   #6 (permalink)
getting rid of my mix program setting helped alot too... willl try adjusting the throttle curve to make it a bit tamer.. and see if that helps too... if nothing else... i should get slightly longer flight times!!!
