Old 01-15-2017, 08:33 AM   #1 (permalink)
Default 450l upgrade metal tail pitch linkage with sleeves
My tail on my 450l is binding even with a brand new tail. It seems to be a common problem. I narrowed it down to the black tail pitch linkage the part without the brass sleeve inside. It looks like everywhere I look the upgrade metal ones are discontinued. Does anyone know where I can find this I don't feel comfortable loosening it to where there is no binding as it is very loose. Thanks
bmanc42 is offline        Reply With Quote Quick reply to this message
Old 01-16-2017, 04:02 PM   #2 (permalink)
That's a common spot where people get binding. Either from over tightening or from getting loctite in the pitch link. The best way I've found to get it smooth is to put the loctite in the hole, instead of on the screw. Use a little needle or something to get it on the threads and don't put too much in there. You won't be able to crank down on the screw but it shouldn't be super loose. Slowly tighten it up while checking for binding. If there is loctite in the black link clean it out first.
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 01-16-2017, 05:00 PM   #3 (permalink)
I'm pretty sure I did as mentioned above and locktited the screw a little loose on the 450L. The 550X required a little spacer in the screw hole so I could crank it down. I didn't want that one to bind or come out.
https://www.helifreak.com/showpost.p...5&postcount=58
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 01-21-2017, 11:16 AM   #4 (permalink)
that what you are looking for if upgrade is wanted. they are discontinued but not impossible to find my lhs still have few in stock. use tis on my 450l for 3 complet season no issue
trex 800e pro dfc, trex 700n dfc, trex 450l 6S, trex 150
darknight736 is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 07:54 PM   #5 (permalink)
Default KDE Option (Discontinued)
Hmmm, you're right? A lot of the tail assembly parts for the Trex 450 have been discontinued...I was going to recommend a KDE Direct option part.
I wonder if a new tail linkage is in the works...
ACTIVE FLEET: GAUI X4 II, OXY 2/3/4 >< Align >< BLADE >< Walkera
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote Quick reply to this message
Old 01-27-2017, 07:49 AM   #6 (permalink)
I ended up not buying this heli with the binding tail. I received a 450 pro dfc for free from a very generous member on this site and the tail is smooth as butter. So this problem has resolved itself. Thanks for the replies tho everybody
