Like Tree3Likes
Old 12-29-2014, 11:21 PM   #341 (permalink)
Nice piro flips CH. The stick movements were a nice touch.
SAB Black Thunder Sport
SAB Goblin 570 // 500 Sport
SAB Goblin 420
OXY 3, LYNX Heli Innovations Team Pilot
Teeyo is offline        Reply With Quote Quick reply to this message
Old 12-31-2014, 01:08 AM   #342 (permalink)
Thanks. Weather was better today so I re-did the vids with better flying.
Human Slow-mo piro flips
Piro Flip Stick Movements Human Slow-Mo (3 min 52 sec)
Stronger pack (too bad cams stopped mysteriously missing the hard flying parts so I had to restart)
Piro Flip Stick Movements with My Strong Pack (3 min 38 sec)
mCPx'es/130X/3D-foamie: ugly mods
300X: fast beater/trainer, Protos stretched: trainer but can also go fast
FPV250 5.8G, nQx FPV, Oh also Trex 450DFC
Old 02-17-2015, 03:32 PM   #343 (permalink)
Default Mr Tailhappy Protos Max flight
Friend of mine is getting used to the protos max,
https://www.youtube.com/watch?v=fAc5zetRkjg
I hope you like it.
B
Balazs is offline        Reply With Quote Quick reply to this message
Old 03-22-2015, 05:30 AM   #344 (permalink)
Mr TailHappy's crazy demo flight at Rotor Live 2015
Awesomeee!!
MSH Protos 700 Holonatix Slot 3D Flight Tamas Levardi Zeal Energy Rotor Live 2015 *1080p50fpsHD* (1 min 50 sec)
Qwert0 is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 10:52 AM   #345 (permalink)
Talking about visibility mod, this started off as a worth-some-laugh activity but after a few iterations (the GOBLINg, the Ribblin, and now) "Jasmin" actually turns out pretty good.
Really helps visibility from afar. Keeping it on for longer than I originally expected.
My Stretched Protos "Jasmin" with Nanotech 25C [1080p Mobius] (4 min 19 sec)
My Stretched Protos "Jasmin" with Nanotech 25C [720p60 Mobius] (4 min 18 sec)
Old 05-03-2015, 01:06 AM   #346 (permalink)
...and then there's "Pistachio". More lightweight solution, 12g vs 40g.
Here's an interesting comparison of the same flight shot with 2 different cameras from different perspective. My cap-cam has a longer zoom which shows more details on the heli and its attitude. But because of the longer zoom, often times the stationary object background is not in frame which means you lose the sense of speed and change of speed of the heli. My friend shot the flight from farther away with wider zoom (mainly to test the higher than full HD resolution). And because of the wider zoom, it's more of a stationary aim which means stationary objects are always in view for easy reference to speed and change of speed. Different perspective but both have the merits for enjoyment.
My Stretched Protos "Pistachio" Prototype [cap-cam with Mobius] (4 min 8 sec)
My Stretched Protos "Pistachio" Prototype [Note 4 1440p crop] (4 min 6 sec)
Old 05-10-2015, 11:00 PM   #347 (permalink)
For curiousity I flew my Revolution 430mm blades with my setup/settings for 470 blades today. That means only 2450rpm HS with 13T. Definitely not punchy or responsive as with 470 blades but flyable, good for practice flying.
430 blades at 2450
My Stretched Protos Trying 430mm Blades with 13T (4 min 20 sec)
Back to 470 blades at 2300
My Stretched Protos Start Practicing Piro-Tic-Tocs (4 min 25 sec)
Old 08-20-2015, 09:18 PM   #348 (permalink)
First flight filmed on my Protos, nothing too amazing. I need to spend some time on the cyclic it is really mushy feeling and in the wind dolphins. I also need to up my auto bail out spool up rate it's way too slow at the moment.
Protos 500 (4 min 20 sec)
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 08-20-2015, 10:20 PM   #349 (permalink)
Regarding auto bailout, your problem is with the YGE heli soft-start which is always triggered once it sees zero throttle. I don't know about the Brain but vBar has the "idle" option for auto bailout. When you auto vBar doesn't cut throttle all the way. It'll maintain motor speed at the lowest possible so the YGE won't trigger soft-start when vBar resume throttle. another option is to set auto at 10% throttle or whatever the lowest for the YGE to not trigger soft-start.
Old 08-20-2015, 11:46 PM   #350 (permalink)
I have my esc set to airplaine mode :-) I just have my ramp set way too low in the fbl, my x3 starts back up great at this setting and it was my first go with the protos which will need much more till I'm happy with it.
Old 08-21-2015, 12:47 AM   #351 (permalink)
It's weird that the Brain will even allow setting bailout ramp up speed this slow. Soft-start speed this slow makes sense, but bailout ramp up speed this slow? vBar can't even set bailout ramp up speed just soft-start spoolup speed. I wish vBar sllows adjustable bailout ramp up speed. Pre-set is too fast.
Old 08-21-2015, 01:08 AM   #352 (permalink)
I wish vbar had a separate bailout setting too. But IMO it's too slow. Bailout ramp-up is scaled off the spool-up rate. So to get a faster or slower bailout, you have to adjust the initial spool up rate.
Nick, crank that sucker up. This thing is a belt not a gear/pinion. So you aren't going to melt your main gear
jmtyndall is offline        Reply With Quote Quick reply to this message
Old 08-21-2015, 08:45 AM   #353 (permalink)
It has a scale from 0-100% for the ramp and default is 25% I'm currently at 34% so I have quite a ways before I'm maxed out. I really should pull the blades off and bench test like a castle but my time is so limited on work nights I just wanted to fly so I did guess and check. Next time I'll just up each bank 10% and find out much quicker.
I don't want to do the death piro like you have seen first hand haha maybe if I tuned at a field like a normal person it would be ok.
Old 08-21-2015, 08:54 AM   #354 (permalink)
Good old Castle! I think Alex starts around 50? And we're running stupid high numbers on the Max. But the drivetrain there is more robust
Old 08-21-2015, 02:13 PM   #355 (permalink)
Just crank up spool up rate for vBar. It's belt not gear/pinion. Here's my spool up rate but my bailout rate (not shown in the vid) is too fast that it'l swing the tail 90-180 degrees.
My Stretched Protos After Overhaul (4 min 28 sec)
Old 08-22-2015, 10:02 AM   #356 (permalink)
Sweet flight doublech! I need to work on my funnel transitions as they stink. Love the way this P500 flies, but I'm switching to an iKon on it.
Protos500 flight (3 min 25 sec)
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote Quick reply to this message
Old 09-26-2015, 10:25 PM   #357 (permalink)
Another geriatric p500 flight today. Wonderful weather for flying and the now iKon equipped heli is flying great.
p500flight 9-26-15 (3 min 34 sec)
Old 02-08-2016, 05:43 AM   #358 (permalink)
years keep going so the mighty protos 500
Protos 500 Stretch - Stress Test by Seba Argenti (3 min 17 sec)
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
Old 04-22-2016, 09:15 PM   #359 (permalink)
Nothing special, but I'm excited to get it in the air! Got the maiden flight in today and all seems to be good. Was just hoverin it around for the first pack.
Unboxing the Used Stretched Protos 500 Carbon (1 min 13 sec)
Stretched Blade 270CFX w/Custom Scorpion+3Digi
MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1
https://www.youtube.com/c/RCBound#699RCHN
RCBound is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 12:12 AM   #360 (permalink)
Again, nothing special. Just hovering it around and listening, watching for anything that may be obviously setup wrong. No clue what head speed I'm running, I did a Gov Store with a 4V/cell pack and set a flat throttle curve to 65% for this flight.
Flight starts around 2:45
What you see happen at about 4:10 is an issue with the OrangeRX sat I believe. I'm also running a Spektrum sat so I fully expected this issue to go away. So far the issue is strictly when running at 11ms and with the 3Digi failsafe turned on. The engineers/programmers have already implemented a change that should solve the issue. I need to get the updated firmware.
I will be switching to 22ms to avoid the issue in the mean time.
Stretched Protos 500 Carbon Maiden Flight (7 min 0 sec)
