Register | FAQ | PM | Events | Groups | Blogs | Calendar |
Hurricane 255 Discussion and support of the Gaui Hurricane 255 |
08-11-2011, 11:02 PM | #1 (permalink) |
X2 / 255 Build threads
Here I will compile links to any good build threads you guys do. this will be a great place for new owners to come and see this bird from start to finish. keep em coming boys, and PM me if you have a thread you think should be in here and I will add them to this first post.
X2 Build thread Thunder Fighter X2 FES Super Combo kit build stevenfox905 My Gaui 255 flybarless & BeastX Picofly
Gaui 200 •Gaui 550 •Gaui X5 BeastX Castle Scorpion Hyperion Spektrum JR The Front Porch, Nexgens Lounge Last edited by nexgen; 08-12-2011 at 03:39 AM.. |
08-12-2011, 02:23 AM | #2 (permalink) |
Thanks nexgen
Your the man, I'm sure it will come in good use soon |
08-12-2011, 03:03 AM | #3 (permalink) |
Yep thanks for that, they tend to get lost if not made sticky.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades |
08-05-2021, 11:14 AM | #4 (permalink) |
255 gyro question
Hi all, i have just received a 255 Hurricane (FB) without receiver or gyro. The receiver is not an issue but i would like some advise on gyro's if you can help.
I have in my toolkit 2 un-used and still in the box gyro's but i also have a larger trex 450 FB that i am building up as well (my kit is from 9-10 years ago and had to give up learning due to life etc). The Gyro's are as follows: Assan GA250 Mems Gyro Inertia 860 Gyro (was touted as a Spartan clone for a while) If i recall correctly (this was 10ish years ago) the Inertia was able to handle bigger heli's with ease, and the GA250 would be able to handle the Gaui 255. Am i correct in this assumption ? Thanks for any advise, i know its all old tech but consider this a trip down memory lane |
