Belt CP E-Sky Belt CP |
06-04-2015, 12:35 PM | #61 (permalink) |
OH and kit 1 will use an original Belt CP tail push rod for the rudder! The Reaktor uses a string pull/pull normally but I am going to use custom push rods instead on both kits.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious! Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range! |
06-05-2015, 05:43 AM | #62 (permalink) |
Let's see the goods then!!
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades TRex600N, Kasama Head, OS50SX |
06-05-2015, 02:01 PM | #63 (permalink) |
Nooo, no, no, no, no, yes.
but would be even better with videos.
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1 Pro, FBL Trex600ESP VX1e, Parkzone P51D, QRX350Pro |
06-05-2015, 08:14 PM | #64 (permalink) |
Well I got zero done yesterday plank-wise, but thanks to todays rain, I got some pics of the goods, then I got to work. I soldered both ESC's and the motor, glued servos in place installed the motor conected RX, and propped and ran the motor on 2/3s to test. NEXT cut a hole in the fuse to put in the Atom and work on setting that up and building custom push rods. the glue will take 12hrs to cure so thats on hold for now. I can start building/painting kit 2 now since it will need to cure also and I have all needing glue for it.
06-05-2015, 10:08 PM | #65 (permalink) |
The weather is shitty so i wont be going to a wifi and uploading the pics tonight. Im stuck inside a pizza joint now. Its been hailing for a half hour relentlessly. At least there are dollar beers!!
06-06-2015, 07:28 AM | #66 (permalink) |
Tell me about it! I got my prop, but can't fly,,, only 12 days left.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel, PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv. |
06-06-2015, 11:31 AM | #67 (permalink) |
Well I got the 2nd kit built and I can start adding the electronics minus the motor and Atom which will arrive Monday. Kit 1 servos are dried and ready for horns/rods and the Atom setup. Now I gotta go mow yesterdays lawns.
06-08-2015, 12:18 AM | #68 (permalink) |
So here's the goods! you can see the paint job I've given the first kit and contrast of top and bottom for easy orientation. There is also a close up of the CC3D Atom next to an 8" prop. I also realized I forgot servo lead extensions and just ordered them. Ive made some more progress than pictured but wanted to get these pics up since it's not raining tonight.
